Vertical Mixing Parameterizations
K-Profile Parameterization
Surface boundary layer
(1) |
Surface Boundary layer depth
(2) |
(3) |
(4) |
The turbulent velocity shear term in this equation is given by LMD as,
(5) |
Turbulent velocity scale
(6) |
(7) |
for momentum and,
for scalars. The non dimensional flux profiles in this regime are,
(8) |
(9) |
The shape function
(10) |
with the coefficients specified to match surface boundary conditions and to smoothly blend with the interior,
(11) |
Countergradient flux term
(12) |
(13) |
for temperature and
(14) |
The interior scheme
The interior scheme of Large, McWilliams and Doney estimates the viscosity coefficient by adding the effects of several generating mechanisms: shear mixing, double-diffusive mixing and internal wave generated mixing.
(15) |
Shear generated mixing
The shear mixing term is calculated using a gradient Richardson number formulation, with viscosity estimated as:
(16) |
where is , .
Double diffusive processes
(17) |
(18) |
for temperature. For other scalars,
!--\eqno{(19)}-->
(19) |
(20) |
Mellor-Yamada 2.5
The turbulent kinetic energy equation is:
(21) |
(22) |
The vertical boundary conditions are:
- top (:
- and bottom ():
(24) |
(25) |
(26) |
(27) |
(28) |
(29) |
(30) |
(31) |
Generic Length Scale
(32) |
