Lake Jersey Refinement Example ADE
Example Menu |
1. Introduction |
2. Lake Jersey AB |
4. Lake Jersey AC |
3. Lake Jersey AD |
5. Lake Jersey ABD |
7. Lake Jersey ADE |
6. Lake Jersey ABDC |
8. Lake Jersey ACDE |
Description
This example is a double refinement application with three grids: coarse (a) and two telescoping refinements (d and e). There are four contact regions (cr) and three nesting layers because three different time-step sizes are required in ocean_lake_jersey_nested_3g_ade.in:
- Number of grid nesting layers. This parameter is used to allow refinement and composite grid combinations.NestLayers = 3
- Number of grids in each nesting layer, [1:NestLayers] values are expected.GridsInLayer = 1 1 1
- Time-stepping parameters.
- Nesting grids connectivity data: contact points information. This NetCDF file is special and complex. It is currently generated using the script matlab/grid/contact.m from the Matlab repository.NGCNAME = ../Data/lake_jersey_ngc_3g_ade.nc
- Notice that since the coarse grid (a) is an enclosed basin, all lateral boundary conditions on that grid are set to closed (Clo) while the refinement grids (d and e), which are entirely surrounded by the grids they refine, have nested (Nes) lateral boundary conditions.LBC(isFsur) == Clo Clo Clo Clo \ ! free-surface, Grid 1
Grid Information | |||||
Grid | ng | Mesh Size |
Refinement Factor |
Δx Δy |
dt (s) |
d | 2 | 114x60x8 | 1:3 from a | 166.6 m | 30.0 |
e | 3 | 132x60x8 | 1:3 from d | 55.5 m | 10.0 |
cr | dg | rg |
1 | 1 (a) | 2 (d) |
2 | 2 (d) | 1 (a) |
3 | 2 (d) | 3 (e) |
4 | 3 (e) | 2 (d) |
>> Gnames = {'lake_jersey_grd_a.nc', 'lake_jersey_grd_d.nc', 'lake_jersey_grd_e.nc'};
Results
One-way -
Two-way
- Surface Salinity
One-way -
Two-way
- Free-surface (m)
One-way -
Two-way
One-way -
Two-way
