Lake Jersey Refinement Example ABD
Example Menu |
1. Introduction |
2. Lake Jersey AB |
4. Lake Jersey AC |
3. Lake Jersey AD |
5. Lake Jersey ABD |
7. Lake Jersey ADE |
6. Lake Jersey ABDC |
8. Lake Jersey ACDE |
Description
This example is a refinement application with three grids: coarse (a) and two fine grids(b and d). There are two nesting layers because two different time-step sizes are required in ocean_lake_jersey_nested_2g_abd.in:
- Number of grid nesting layers. This parameter is used to allow refinement and composite grid combinations.NestLayers = 2
- Number of grids in each nesting layer, [1:NestLayers] values are expected.GridsInLayer = 1 2
- Time-stepping parameters.
- Nesting grids connectivity data: contact points information. This NetCDF file is special and complex. It is currently generated using the script matlab/grid/contact.m from the Matlab repository.NGCNAME = ../Data/lake_jersey_ngc_2g_abd.nc
- Notice that since the coarse grid (a) is an enclosed basin, all lateral boundary conditions on that grid are set to closed (Clo) while the refined grids (b abd d), which are entirely enclosed by the coarse grid, have nested (Nes) lateral boundary conditions.LBC(isFsur) == Clo Clo Clo Clo \ ! free-surface, Grid 1
Grid Information | |||||
Grid | ng | Mesh Size |
Refinement Factor |
Δx Δy |
dt (s) |
a | 1 | 100x80x8 | - | 500.0 m | 120.0 |
b | 2 | 66x99x8 | 1:3 from a | 166.6 m | 40.0 |
d | 3 | 114x60x8 | 1:3 from a | 166.6 m | 40.0 |
cr | dg | rg |
1 | 1 (a) | 2 (b) |
2 | 2 (b) | 1 (a) |
3 | 1 (a) | 3 (d) |
4 | 3 (d) | 1 (a) |
>> Gnames = {'lake_jersey_grd_a.nc', 'lake_jersey_grd_b.nc', 'lake_jersey_grd_d.nc'};
>> Cname = 'lake_jersey_ngc_2g_abd.nc';
Results
The plots below show the results after 2 days of simulation for one-way and two-way nesting configurations. They are plotted with Matlab using the script plot_nesting.m. The refined solutions (grids b and c) are overlayed on top of the coarse grid (a). The color map is rendered using shading flat, meaning there is no interpolation between pixels in the color maps. Click the figure to see a more detailed image. On the resulting page a link to the full resolution image is provided.
>> Anames = {'lake_jersey_avg_a.nc', 'lake_jersey_avg_b.nc', 'lake_jersey_avg_d.nc'};
>> Hnames = {'lake_jersey_his_a.nc', 'lake_jersey_his_b.nc', 'lake_jersey_his_d.nc'};
One-way -
Two-way
- Surface Salinity
One-way -
Two-way
- Free-surface (m)
One-way -
Two-way
One-way -
Two-way
