Nested Grids
Nested Grids Menu | |
1. Introduction | |
Nested Grids Classes
- Mosaic Grids Sub-Class
- Single Refinement Sub-Class
Hence, there are several possibilities and combinations. The design is flexible enough to allow complex nested grid configurations in coastal applications. These capabilities are better illustrated with diagrams of the different Sub-Classes. The diagrams are all in terms of computational coordinates ($\xi$, $\eta$) or fractional ($i$, $j$) coordinates. Therefore we have squares and rectangles that may map to physical curvilinear coordinates. Here, Ngrids is the number of nested grids, NestLayers is the number of nested layers, GridsInLayer is a vector with the number of grids in each nested layer, and Ncontact is the number of nesting contact regions, (Ngrids-1)*2.
- Composite Grids
Mosaic Sub-Class:
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2 -
Composite Overlap Sub-Class:
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2 -
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2 -
Ngrids = 6
NestLayers = 1
GridsInLayer = 6
Ncontact = 10
- Refinement Grids
Single Refinement Sub-Class:
Ngrids = 2
NestLayers = 2
GridsInLayer = 1 1
Ncontact = 2 -
Ngrids = 4
NestLayers = 3
GridsInLayer = 1 2 1
Ncontact = 6
Ngrids = 3
NestLayers = 2
GridsInLayer = 2 1
Ncontact = 4 -
Ngrids = 3
NestLayers = 2
GridsInLayer = 1 2
Ncontact = 4
</wikitex>
<wikitex> A contact region is an extended section of the grid that overlays or is adjacent to a nested grid. A contact point is a grid cell inside the contact region. The contact points are located according to the staggered Arakawa C-grid horizontal positions. Therefore, we have contact points at the ρ-, ψ-, u-, and v-points. However, the ψ-points are only used to define the physical grid perimeters within a contact region. ROMS does not have state variables located at ψ-points; vorticity is not explicitly specified in the governing equations. In a nested application, there are (Ngrids-1)*2 contact regions. Each contact region has a receiver grid and donor grid. The contact points of the receiver grid are processed using the donor grid cell containing the contact point. The contact points are coincident if the receiver and donor grids occupy the same position, p = q = 0 in diagram below. If coincident grids, the receiver grid contact point data is just filled using the donor data. Otherwise (if not coincident) the receiver grid data is linearly interpolated from the donor grid cell containing the contact point.
- Hweight(3,:) = p * q
- Hweight(1,:) = 1.0
- Hweight(2,:) = 0.0
- Hweight(3,:) = 0.0
- Hweight(4,:) = 0.0
and
TYPE T_NGC
END TYPE T_NGC
- Mosaic Sub-Class
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Receiver Grid = red -
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Receiver Grid = blue
- Composite Overlap Sub-Class
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Ngrids = 6
NestLayers = 1
GridsInLayer = 6
Ncontact = 10
Donor Grid = blue
Ngrids = 6
NestLayers = 1
GridsInLayer = 6
Ncontact = 10
Donor Grid = red
Ngrids = 2
NestLayers = 2
GridsInLayer = 1 1
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 2
GridsInLayer = 1 1
Ncontact = 2
Donor Grid = red
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = blue
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = red
Receiver Grid = blue -
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = red
Receiver Grid = green -
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = green
Receiver Grid = red
Ngrids = 3
NestLayers = 2
GridsInLayer = 2 1
Ncontact = 4
Donor Grid = blue
Ngrids = 3
NestLayers = 2
GridsInLayer = 2 1
Ncontact = 4
Donor Grid = red
Ngrids = 3
NestLayers = 2
GridsInLayer = 1 2
Ncontact = 4
Donor Grid = blue
Ngrids = 3
NestLayers = 2
GridsInLayer = 1 2
Ncontact = 4
Donor Grid = red
Ngrids = 3
NestLayers = 2
GridsInLayer = 1 2
Ncontact = 4
Donor Grid = red
Ngrids = 3
NestLayers = 2
GridsInLayer = 1 2
Ncontact = 4
Donor Grid = green
Receiver Grid = red
</wikitex>
Nesting Test Cases
<wikitex>
- RHO-MASK
RHO-MASK Whole Grid -
RHO-MASK Composite Grids
- Contact Points, Composite
Donor Grid = blue
Donor Grid = red
Donor Grid = blue
Donor Grid = red
- RHO-MASK
RHO-MASK Refinement Grid
- Contact Points, Refinement
Donor Grid = red (coarse)
Receiver Grid = blue (fine) -
Donor Grid = blue (fine)
Receiver Grid = red (coarse)
</wikitex>
</wikitex>
Contact Points Metadata
dimensions:
Ngrids = 2 ;
Ncontact = 2 ;
Nweights = 4 ;
datum = 350 ;
variables:
int spherical ;
int Lm(Ngrids) ;
int Mm(Ngrids) ;
int coincident(Ngrids) ;
int composite(Ngrids) ;
int mosaic(Ngrids) ;
mosaic:flag_values = 0, 1 ;
int refinement(Ngrids) ;
int refine_factor(Ngrids) ;
int interpolate(Ncontact) ;
int donor_grid(Ncontact) ;
int receiver_grid(Ncontact) ;
int NstrR(Ncontact) ;
int NendR(Ncontact) ;
int NstrU(Ncontact) ;
int NendU(Ncontact) ;
int NstrV(Ncontact) ;
int NendV(Ncontact) ;
int contact_region(datum) ;
int on_boundary(datum) ;
on_boundary:flag_meanings = "other western southern eastern northern" ;
int Idg(datum) ;
int Jdg(datum) ;
int Irg(datum) ;
Irg:coordinates = "Xrg Yrg" ;
int Jrg(datum) ;
Jrg:coordinates = "Xrg Yrg" ;
double Xrg(datum) ;
Xrg:units = "meter" ;
double Yrg(datum) ;
Yrg:units = "meter" ;
double h(datum) ;
h:units = "meter" ;
h:coordinates = "Xrg Yrg" ;
h:_FillValue = 1.e+37 ;
double f(datum) ;
f:units = "second-1" ;
f:coordinates = "Xrg Yrg" ;
f:_FillValue = 1.e+37 ;
double pm(datum) ;
pm:units = "meter-1" ;
pm:coordinates = "Xrg Yrg" ;
pm:_FillValue = 1.e+37 ;
double pn(datum) ;
pn:units = "meter-1" ;
pn:coordinates = "Xrg Yrg" ;
pn:_FillValue = 1.e+37 ;
double dndx(datum) ;
dndx:units = "meter" ;
dndx:_FillValue = 1.e+37 ;
double dmde(datum) ;
dmde:units = "meter" ;
dmde:_FillValue = 1.e+37 ;
double angle(datum) ;
angle:units = "radians" ;
angle:_FillValue = 1.e+37 ;
double mask(datum) ;
mask:flag_values = 0., 1. ;
global attributes:
:grid_files = " \n",
</wikitex>
