Land Sea Masking Scripts
Matlab: Land/Sea Masking Scripts
This page describes several Matlab scripts in the matlab/landmask repository sub-directory, which are used to process ROMS Land/Sea mask.
- add_coastline.m
- Adds coastline data to ROMS Grid NetCDF file. This is the coastline data used to facilitate Land/Sea masking editing.
- add_coastline (ncfile, Clon, Clat)
- On Input:
ncfile: ROMS Grid NetCDF file name (string) Clon: Coastline longitude (1D array, degree_east) Clat: Coastline latitude (1D array, degree_north)
- editmask.m
- GUI for manual editing of ROMS Land/Sea mask on RHO-points. To accelerate the processing, the Land/Sea mask is edited in (I,J) grid coordinates. If the (I,J) coordinates are not provided, it will compute and write them into a file. If called without one or both arguments, it will prompt for the needed file name(s). If the coastline data is in grid_file, it will read it and convert to (I,J) fractional coordinates.
- editmask (grid_file, coast_file)
- On Input:
grid_file: ROMS Grid NetCDF file name containing the grid and mask arrays (string) coast_file: Matlab file name containing the coastline (lon, lat) or (I,J) fractional coordinates (string; optional)
- Mouse shortcuts:
double click: zoom in right click: zoom out middle click: change editing mode
- editscope.m
- GUI for manual editing of ROMS adjoint sensitivity scope mask on RHO-points. To accelerate the processing, the Land/Sea mask is edited in (I,J) grid coordinates. If the (I,J) coordinates are not provided, it will compute and write them into a file. If called without one or both arguments, it will prompt for the needed file name(s). If the coastline data is in grid_file, it will read it and convert to (I,J) fractional coordinates.
- editscope (grid_file, coast_file)
- On Input:
grid_file : ROMS Grid NetCDF file name containing the grid and mask arrays (string) coast_file: Matlab file name containing the coastline (lon, lat) or (I,J) fractional coordinates (string; optional)
- Mouse shortcuts:
- ijcoast.m
- Converts coastline data to ROMS (I,J) fractional coordinates to facilitate Land/Sea masking editing with editmask.
- C = ijcoast (ncfile, coast_file)
- On Input:
ncname: ROMS grid NetCDF file name (string) coast_file: Coastline file name (string)
- On Output:
C: Coastline data (struct array)
C.grid ROMS Grid NetCDF file name C.coast Coastline file name C.indices Coastline indices file name C.lon Coastline longitudes C.lat Coastline latitudes C.Icst Coastline I-grid coordinates, (0:L) C.Jcst Coastline J-grid coordinates, (0:M)
- landsea.m
- Computes the Land/Sea mask for an application grid atomatically and writes it into an input NetCDF file. The Land/Sea mask is computed from closed coastlines polygons extracted from the GSHHS data set if the (clon, clat) coastline data is not provided.
- F = lansea (ncfile, clon, clat)
- On Input:
ncname: ROMS grid NetCDF file name (string) clon: Coastline longitude (1D array; degrees_west) clat: Coastline latitude (1D array; degrees_north)
- On Output:
F: Land/Sea mask data (struct array)
F.mask_rho Mask on ρ-points (2D array) F.mask_psi Mask on ψ-points (2D array) F.mask_u Mask on u-points (2D array) F.mask_v Mask on v-points (2D array)
- read_mask.m
- Reads in ROMS grid bathymetry and Land/Sea mask at ρ-point from NetCDF file.
- [spherical, x, y, bath, rmask] = read_mask (ncfile)
- On Input:
- On Output:
spherical: Spherical switch (logical) x: X-location of ρ-points y: Y-location of ρ-points bath: Bathymetry at ρ-points rmask: Land/Sea mask at ρ-points
- read_scope.m
- Reads in ROMS grid bathymetry and adjoint sensitivity scope mask at ρ-points from NetCDF file.
- On Input:
- On Output:
- uvp_masks.m
- Computes the Land/Sea masks at u-, v-, and ψ-points from the mask on ρ-points.
- [umask, vmask, vmask] = uvp_masks (rmask)
- On Input:
rmask: Land/Sea mask on ρ-points (2D array)
- On Output:
umask: Land/Sea mask on u-points (2D array) vmask: Land/Sea mask on v-points (2D array) rmask: Land/Sea mask on ψ-points (2D array)
- uv_scope.m
- Computes the adjoint sensitivity scope masks at u- and v-points from the scope mask on ρ-points.
- [Uscope, Vscope] = uvp_masks (Rscope)
- On Input:
Rscope: Scope mask on ρ-points (2D array)
- On Output:
Uscope: Scope mask on u-points (2D array) Vscope: Scope mask on v-points (2D array)
- write_mask.m
- Writes out Land/Sea mask data into ROMS Grid NetCDF file.
- status = write_mask (ncfile, rmask, umask, vmask, pmask)
- On Input:
ncname: ROMS grid NetCDF file name (string) rmask: Land/Sea mask on ρ-points (2D array) umask: Land/Sea mask on u-points (2D array) vmask: Land/Sea mask on v-points (2D array) pmask: Land/Sea mask on ψ-points (2D array)
- On Output:
status: Error flag
- write_scope.m
- Writes out adjoint sensitivity scope mask data into ROMS Grid NetCDF file.
- status = write_mask (ncfile, Rscope, Uscope, Vscope)
- On Input:
ncname: ROMS grid NetCDF file name (string) Rscope: Adjoint sensitivity scope mask on ρ-points (2D array) Uscope: Adjoint sensitivity scope mask on u-points (2D array) Vscope: Adjoint sensitivity scope mask on v-points (2D array)
- On Output:
status: Error flag
