Nested Grids
Nested Grids Menu | |
1. Introduction | |
Nested Grids Classes
- Mosaic Grids Sub-Class
- Single Refinement Sub-Class
- Composite Grids
Mosaic Sub-Class:
Ngrids = 2
NestLayers = 1
GridsInLayer = 1
Ncontact = 2 -
Composite Overlap Sub-Class:
Ngrids = 2
NestLayers = 1
GridsInLayer = 1
Ncontact = 2 -
Ngrids = 2
NestLayers = 1
GridsInLayer = 1
Ncontact = 2 -
Ngrids = 6
NestLayers = 1
GridsInLayer = 6
Ncontact = 10
- Refinement Grids
Single Refinement Sub-Class:
Ngrids = 2
NestLayers = 2
GridsInLayer = 1 1
Ncontact = 2 -
Ngrids = 4
NestLayers = 3
GridsInLayer = 1 2 1
Ncontact = 6
Ngrids = 3
NestLayers = 2
GridsInLayer = 2 1
Ncontact = 4 -
Ngrids = 3
NestLayers = 2
GridsInLayer = 1 2
Ncontact = 4
</wikitex>
- Hweight(3,:) = p * q
- Hweight(1,:) = 1.0
- Hweight(2,:) = 0.0
- Hweight(3,:) = 0.0
- Hweight(4,:) = 0.0
and
TYPE T_NGC
END TYPE T_NGC
- Mosaic Sub-Class
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Receiver Grid = red -
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Receiver Grid = blue
- Composite Overlap Sub-Class
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Ngrids = 2
NestLayers = 2
GridsInLayer = 1 1
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 2
GridsInLayer = 1 1
Ncontact = 2
Donor Grid = red
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = blue
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = red
Receiver Grid = blue -
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = red
Receiver Grid = green -
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = green
Receiver Grid = red
Ngrids = 3
NestLayers = 2
GridsInLayer = 2 1
Ncontact = 4
Donor Grid = blue
Ngrids = 3
NestLayers = 2
GridsInLayer = 2 1
Ncontact = 4
Donor Grid = red
</wikitex>
Metadata
dimensions:
Ngrids = 2 ;
Ncontact = 2 ;
Nweights = 4 ;
datum = 98 ;
variables:
int spherical ;
int Lm(Ngrids) ;
int Mm(Ngrids) ;
int coincident(Ngrids) ;
int composite(Ngrids) ;
int mosaic(Ngrids) ;
mosaic:flag_values = 0, 1 ;
int refinement(Ngrids) ;
int refine_factor(Ngrids) ;
int interpolate(Ncontact) ;
int donor_grid(Ncontact) ;
int receiver_grid(Ncontact) ;
int NstrR(Ncontact) ;
int NendR(Ncontact) ;
int NstrU(Ncontact) ;
int NendU(Ncontact) ;
int NstrV(Ncontact) ;
int NendV(Ncontact) ;
int contact_region(datum) ;
int on_boundary(datum) ;
int Idg(datum) ;
int Jdg(datum) ;
int Irg(datum) ;
Irg:coordinates = "Xrg Yrg" ;
int Jrg(datum) ;
Jrg:coordinates = "Xrg Yrg" ;
double Xrg(datum) ;
Xrg:units = "meter" ;
double Yrg(datum) ;
Yrg:units = "meter" ;
double h(datum) ;
h:units = "meter" ;
h:coordinates = "Xrg Yrg" ;
h:_FillValue = 1.e+37 ;
double f(datum) ;
f:units = "second-1" ;
f:coordinates = "Xrg Yrg" ;
f:_FillValue = 1.e+37 ;
double pm(datum) ;
pm:units = "meter-1" ;
pm:coordinates = "Xrg Yrg" ;
pm:_FillValue = 1.e+37 ;
double pn(datum) ;
pn:units = "meter-1" ;
pn:coordinates = "Xrg Yrg" ;
pn:_FillValue = 1.e+37 ;
double dndx(datum) ;
dndx:units = "meter" ;
dndx:_FillValue = 1.e+37 ;
double dmde(datum) ;
dmde:units = "meter" ;
dmde:_FillValue = 1.e+37 ;
double angle(datum) ;
angle:units = "radians" ;
angle:_FillValue = 1.e+37 ;
double mask(datum) ;
mask:flag_values = 0., 1. ;
global attributes:
:grid_files = " \n",
Notice that the variable dimensions (Hweight) are in row-major order since this is the output from ncdump. However, the data is stored in column-major order because this file will be processed by ROMS in Fortran-90. The strategy here is to pack the contact points information for each contact region in a long vector. Several indices are available to unpack the data into the Fortran-90 contact structures for ρ-, u-, and v-points. Although NetCDF-4 supports derived type structures via the HDF5 library, a simpler Metadata model is chosen for interoperability. Notice that the contact points NetCDF file also contains the values for the various grid metrics needed in ROMS numerical kernel. Only the horizontal interpolation weights are provided here since they are always the same for a particular configuration. The vertical interpolation weights are computed internally in ROMS at each time step because of the time dependency of the vertical coordinates to the evolution of the free-surface.
</wikitex>
