Nested Grids
Nested Grids
Nested Grids Menu
  1. Introduction
  2. Matlab Processing Scripts
  1. Phase I, released on April 2011 as ROMS version 3.5, included major updates to the nonlinear (NLM), perturbation tangent linear (TLM), finite-amplitude tangent linear (RPM), and adjoint (ADM) models numerical kernels to allow different horizontal I- and J-ranges in the DO-loops to permit operations on various nested grid classes (refinement, mosaics, and composite) and nesting layers (refinement and composite grid combinations). This facilitates the computation of any horizontal operator (advection, diffusion, gradient, etc.) in the nesting contact regions and avoids the need for cumbersome lateral boundary conditions on the model variables and their associated flux/gradient values. The advantage of this approach is that it is generic to any discrete horizontal operator. The contact region is an extended section of the grid that overlays an adjacent grid. The strategy is to compute the full horizontal operator at the contact points between nested grids instead of specifying boundary conditions.
  2. Phase II, released on September 2011 as ROMS version 3.6, included a major overhaul of lateral boundary conditions. All their associated C-preprocessing options were eliminated and replaced with logical switches that depend on the nested grid, if any. This facilitates, in a generic way, the processing or not of lateral boundary conditions in applications with nested grids. In nesting applications, the values at the lateral boundary points are computed directly in the contact region by the numerical kernel. Partial lateral boundary conditions are allowed by combining specified conditions (like closed, gradient, and others) with nested contact points. In addition, the logical switches allow different lateral boundary conditions types between active (temperature and salinity) and passive (biology, sediment, inert, etc.) tracers. The lateral boundary condition switches for each state variable and boundary edge are now specified in ROMS input script file, ocean.in.
  3. Phase III, to be released soon as ROMS version 3.7, includes the nesting calls to ROMS main time-stepping routines, main2d and main3d. The routine main2d is only used in shallow-water 2D barotropic applications whereas main3d is used in full 3D baroclinic applications. Several new routines will be added to process the information that it is required in the contact region, what information needs to be exchanged from/to another grid, and when to exchange it.
    In grid refinement applications, the information is exchanged at the begginning of the full time-step (top of main2d or main3d). Contrarily, in composite grids applications, the information is exchanged between each sub-time step call in main2d or main3d. That is, the composite donor and receiver grids need to sub-time step the 2D momentum equations before any of them start solving and coupling the 3D momentum equations. Therefore, the governing equations are solved and nested in a synchronous fashion. The concept of nesting layers is introduced to allow applications with both composite grids and refinement grid combinations, as shown in the diagram below for the Refinement and Partial Boundary Composite Sub-Class. Here, two nesting layers are required. In the first nesting layer, the composite grids 1 and 2 are synchronously sub-time stepped for each governing equation term. Then, in the second and last nesting layer, the refinement grid 3 is time stepped and the information between donor (1) and refinement (3) grids are exchanged at the beginning of the time step for both contact regions: coarse to fine and fine to coarse. The exchange between grids is two-way.
Nested Grids Classes
    • Mosaic Grids Sub-Class
    • Single Refinement Sub-Class
Warning Warning 1: The order of nested grids in ROMS is extremely important. We need to follow such order when specifying parameters in all ROMS standard input scripts: ocean.in, biology.in, sediment.in, and so on. The numeric order is shown above for all nested grid Sub-Classes. It depends on a particular configuration topology, number of nested layers, and on the physical circulation. Generally, the larger/coarser grid is first in the order list. Therefore, users need to order their grids wisely...
Warning Warning 2: In composite grids, it is assumed that the donor and the receiver grids have the same time-step size. This is done to avoid the time interpolation between donor and receiver grids. Only spatial interpolations are possible and carried out. This is due to the fact that composite grids need to solve the governing equations in a synchronous fashion, as explained in above. In refinement grids, it is assumed that the donor and receiver grids are an integer factor (RefineScale) of the grid-size and time-step size. Therefore, time interpolation and time integration is possible between donor and receiver grids.
Note Usually, finer resolution is required to resolve estuary regions or other coastal features in a particular. In this case, we should consider a refinement grid with Land/Sea masking in such areas. This case is illustrated in the Complex Estuary Refinement-Composite Sub-Class diagram above. Notice that the refinement grid 2 has an adjacent composite grid 3 of similar spatial resolution, so all the grids in the second nested layer have the same time step! As you can see, ROMS nesting capabilities are powerful but it requires knowledge and expertise. We highly recommend users to acquire this knowledge before configure their own nested grid applications. This knowledge is difficult to explain in words, but easier to show with the diagrams in this page.
</wikitex>
Hweight(2,:) = p * (1.0 - q)
Hweight(3,:) = p * q
Hweight(4,:) = (1.0 - p) * q
These horizontal interpolation weights are computed outside ROMS and read from contact points NetCDF file. Then, the contact point for a 2D state variable in the receiver grid is computed from the donor grid as:
Hweight(1,:) = 1.0
Hweight(2,:) = 0.0
Hweight(3,:) = 0.0
Hweight(4,:) = 0.0
and
TYPE T_NGC
END TYPE T_NGC
</wikitex>
Metadata
  dimensions:
variables:
int spherical ; spherical:long_name = "grid type logical switch" ; spherical:flag_values = 0, 1 ; spherical:flag_meanings = "Cartesian spherical" ; int Lm(Ngrids) ; Lm:long_name = "number of interior RHO-points in the I-direction" ; int Mm(Ngrids) ; Mm:long_name = "number of interior RHO-points in the J-direction" ; int coincident(Ngrids) ; coincident:long_name = "coincident donor and receiver grids logical switch" ; coincident:flag_values = 0, 1 ; coincident:flag_meanings = "false true" ; int composite(Ngrids) ; composite:long_name = "composite grid type logical switch" ; composite:flag_values = 0, 1 ; composite:flag_meanings = "false true" ; int mosaic(Ngrids) ; mosaic:long_name = "mosaic grid type logical switch" ; mosaic:flag_values = 0, 1 ; mosaic:flag_meanings = "false true" ; int refinement(Ngrids) ; refinement:long_name = "refinement grid type logical switch" ; refinement:flag_values = 0, 1 ; refinement:flag_meanings = "false true" ; int refine_factor(Ngrids) ; refine_factor:long_name = "refinement factor from donor grid" ; int interpolate(Ncontact) ; interpolate:long_name = "vertical interpolation at contact points logical switch" ; interpolate:flag_values = 0, 1 ; interpolate:flag_meanings = "false true" ; int donor_grid(Ncontact) ; donor_grid:long_name = "data donor grid number" ; int receiver_grid(Ncontact) ; receiver_grid:long_name = "data receiver grid number" ; int NstrR(Ncontact) ; NstrR:long_name = "starting contact RHO-point index in data vector" ; int NendR(Ncontact) ; NendR:long_name = "ending contact RHO-point index in data vector" ; int NstrU(Ncontact) ; NstrU:long_name = "starting contact U-point index in data vector" ; int NendU(Ncontact) ; NendU:long_name = "ending contact U-point index in data vector" ; int NstrV(Ncontact) ; NstrV:long_name = "starting contact V-point index in data vector" ; int NendV(Ncontact) ; NendV:long_name = "ending contact V-point index in data vector" ; int contact_region(datum) ; contact_region:long_name = "contact region number" ; int on_boundary(datum) ; on_boundary:long_name = "contact point on receiver grid physical boundary" ; on_boundary:flag_values = 0, 1, 2, 3, 4 ; on_boundary:flag_meanings = "false western southern eastern northern" ; int Idg(datum) ; Idg:long_name = "I-left index of donor cell containing contact point" ; int Jdg(datum) ; Jdg:long_name = "J-bottom index of donor cell containing contact point" ; int Irg(datum) ; Irg:long_name = "receiver grid I-index of contact point" ; Irg:coordinates = "Xrg Yrg" ; int Jrg(datum) ; Jrg:long_name = "receiver grid J-index of contact point" ; Jrg:coordinates = "Xrg Yrg" ; double Xrg(datum) ; Xrg:long_name = "X-location of receiver grid contact points" ; Xrg:units = "meter" ; double Yrg(datum) ; Yrg:long_name = "Y-location of receiver grid contact points" ; Yrg:units = "meter" ; double Hweight(datum, Nweights) ; Hweight:long_name = "horizontal interpolation weights" ; Hweight:coordinates = "Xrg Yrg" ; double h(datum) ; h:long_name = "bathymetry at RHO-points" ; h:units = "meter" ; h:coordinates = "Xrg Yrg" ; h:_FillValue = 1.e+37 ; double f(datum) ; f:long_name = "Coriolis parameter at RHO-points" ; f:units = "second-1" ; f:coordinates = "Xrg Yrg" ; f:_FillValue = 1.e+37 ; double pm(datum) ; pm:long_name = "curvilinear coordinate metric in XI" ; pm:units = "meter-1" ; pm:coordinates = "Xrg Yrg" ; pm:_FillValue = 1.e+37 ; double pn(datum) ; pn:long_name = "curvilinear coordinate metric in ETA" ; pn:units = "meter-1" ; pn:coordinates = "Xrg Yrg" ; pn:_FillValue = 1.e+37 ; double dndx(datum) ; dndx:long_name = "XI-derivative of inverse metric factor pn" ; dndx:units = "meter" ; dndx:coordinates = "Xrg Yrg" ; dndx:_FillValue = 1.e+37 ; double dmde(datum) ; dmde:long_name = "ETA-derivative of inverse metric factor pm" ; dmde:units = "meter" ; dmde:coordinates = "Xrg Yrg" ; dmde:_FillValue = 1.e+37 ; double angle(datum) ; angle:long_name = "angle between XI-axis and EAST" ; angle:units = "radians" ; angle:coordinates = "Xrg Yrg" ; angle:_FillValue = 1.e+37 ; double mask(datum) ; mask:long_name = "land-sea mask of contact points" ; mask:flag_values = 0., 1. ; mask:flag_meanings = "land water" ; mask:coordinates = "Xrg Yrg" ;
global attributes:
Notice that the variable dimensions (Hweight) are in row-major order since this is the output from ncdump. However, the data is stored in column-major order because this file will be processed by ROMS in Fortran-90. The strategy here is to pack the contact points information for each contact region in a long vector. Several indices are available to unpack the data into the Fortran-90 contact structures for ρ-, u-, and v-points. Although NetCDF-4 supports derived type structures via the HDF5 library, a simpler Metadata model is chosen for interoperability. Notice that the contact points NetCDF file contains also the values for the various grid metrics needed in ROMS numerical kernel. Only the horizontal interpolation weights are provided here since they are always the same for a particular configuration. The vertical interpolation weights are computed internally in ROMS at each time step because of the time dependency of the vertical coordinates to the evolution of the free-surface.
</wikitex>
