Nested Grids
Nested Grids
Nested Grids Menu
  1. Introduction
  2. Matlab Processing Scripts
  1. Phase I, released on April 2011 as ROMS version 3.5, included major updates to the nonlinear (NLM), perturbation tangent linear (TLM), finite-amplitude tangent linear (RPM), and adjoint (ADM) models numerical kernels to allow different horizontal I- and J-ranges in the DO-loops to permit operations on various nested grid classes (refinement, mosaics, and composite) and nesting layers (refinement and composite grid combinations). This facilitates the computation of any horizontal operator (advection, diffusion, gradient, etc.) in the nesting contact regions and avoids the need for cumbersome lateral boundary conditions on the model variables and their associated flux/gradient values. The advantage of this approach is that it is generic to any discrete horizontal operator. The contact region is an extended section of the grid that overlays an adjacent grid. The strategy is to compute the full horizontal operator at the contact points between nested grids instead of specifying boundary conditions.
  2. Phase II, released on September 2011 as ROMS version 3.6, included a major overhaul of lateral boundary conditions. All their associated C-preprocessing options were eliminated and replaced with logical switches that depend on the nested grid, if any. This facilitates, in a generic way, the processing or not of lateral boundary conditions in applications with nested grids. In nesting applications, the values at the lateral boundary points are computed directly in the contact region by the numerical kernel. Partial lateral boundary conditions are allowed by combining specified conditions (like closed, gradient, and others) with nested contact points. In addition, the logical switches allow different lateral boundary conditions types between active (temperature and salinity) and passive (biology, sediment, inert, etc.) tracers. The lateral boundary condition switches for each state variable and boundary edge are now specified in ROMS input script file, ocean.in.
  3. Phase III, to be released soon as ROMS version 3.7, includes the nesting calls to ROMS main time-stepping routines, main2d and main3d. The routine main2d is only used in shallow-water 2D barotropic applications whereas main3d is used in full 3D baroclinic applications. Several new routines will be added to process the information that it is required in the overlap region, what information needs to be exchanged from/to another grid, and when to exchange it. The exchange between grids can be one-way or two-way.
Nested Grids Classes
    • Mosaic Grids Sub-Class
    • Single Refinement Sub-Class
</wikitex>
TYPE T_NGC
END TYPE T_NGC
The diagrams below show the contact regions and contact points for each nesting Sub-Class. Each diagram shows the contact region and its contact points colored purple as a transition between the blue and red grids. Color is used to illustrate the nesting role between donor and receiver grids. It also shows the number of nesting layers (NestLayer) and number grids in each nested layer (GridsInLayer). Notice that there is an extra contact point to the left and bottom of the nested grid. This is due to ROMS indices enumeration system for staggered, Arakawa C-grids. A left-bottom enumeration system is used: the i-index for u-points to the left of the ρ-point have the same value; the j-index for v-points to the bottom of the ρ-point have the same value.
</wikitex>
Metadata
  dimensions:
variables:
int spherical ; spherical:long_name = "grid type logical switch" ; spherical:flag_values = 0, 1 ; spherical:flag_meanings = "Cartesian spherical" ; int Lm(Ngrids) ; Lm:long_name = "number of interior RHO-points in the I-direction" ; int Mm(Ngrids) ; Mm:long_name = "number of interior RHO-points in the J-direction" ; int coincident(Ngrids) ; coincident:long_name = "coincident donor and receiver grids logical switch" ; coincident:flag_values = 0, 1 ; coincident:flag_meanings = "false true" ; int composite(Ngrids) ; composite:long_name = "composite grid type logical switch" ; composite:flag_values = 0, 1 ; composite:flag_meanings = "false true" ; int mosaic(Ngrids) ; mosaic:long_name = "mosaic grid type logical switch" ; mosaic:flag_values = 0, 1 ; mosaic:flag_meanings = "false true" ; int refinement(Ngrids) ; refinement:long_name = "refinement grid type logical switch" ; refinement:flag_values = 0, 1 ; refinement:flag_meanings = "false true" ; int refine_factor(Ngrids) ; refine_factor:long_name = "refinement factor from donor grid" ; int interpolate(Ncontact) ; interpolate:long_name = "vertical interpolation at contact points logical switch" ; interpolate:flag_values = 0, 1 ; interpolate:flag_meanings = "false true" ; int donor_grid(Ncontact) ; donor_grid:long_name = "data donor grid number" ; int receiver_grid(Ncontact) ; receiver_grid:long_name = "data receiver grid number" ; int NstrR(Ncontact) ; NstrR:long_name = "starting contact RHO-point index in data vector" ; int NendR(Ncontact) ; NendR:long_name = "ending contact RHO-point index in data vector" ; int NstrU(Ncontact) ; NstrU:long_name = "starting contact U-point index in data vector" ; int NendU(Ncontact) ; NendU:long_name = "ending contact U-point index in data vector" ; int NstrV(Ncontact) ; NstrV:long_name = "starting contact V-point index in data vector" ; int NendV(Ncontact) ; NendV:long_name = "ending contact V-point index in data vector" ; int contact_region(datum) ; contact_region:long_name = "contact region number" ; int on_boundary(datum) ; on_boundary:long_name = "contact point on receiver grid physical boundary" ; on_boundary:flag_values = 0, 1, 2, 3, 4 ; on_boundary:flag_meanings = "false western southern eastern northern" ; int Idg(datum) ; Idg:long_name = "I-left index of donor cell containing contact point" ; int Jdg(datum) ; Jdg:long_name = "J-bottom index of donor cell containing contact point" ; int Irg(datum) ; Irg:long_name = "receiver grid I-index of contact point" ; Irg:coordinates = "Xrg Yrg" ; int Jrg(datum) ; Jrg:long_name = "receiver grid J-index of contact point" ; Jrg:coordinates = "Xrg Yrg" ; double Xrg(datum) ; Xrg:long_name = "X-location of receiver grid contact points" ; Xrg:units = "meter" ; double Yrg(datum) ; Yrg:long_name = "Y-location of receiver grid contact points" ; Yrg:units = "meter" ; double Hweight(datum, Nweights) ; Hweight:long_name = "horizontal interpolation weights" ; Hweight:coordinates = "Xrg Yrg" ; double h(datum) ; h:long_name = "bathymetry at RHO-points" ; h:units = "meter" ; h:coordinates = "Xrg Yrg" ; h:_FillValue = 1.e+37 ; double f(datum) ; f:long_name = "Coriolis parameter at RHO-points" ; f:units = "second-1" ; f:coordinates = "Xrg Yrg" ; f:_FillValue = 1.e+37 ; double pm(datum) ; pm:long_name = "curvilinear coordinate metric in XI" ; pm:units = "meter-1" ; pm:coordinates = "Xrg Yrg" ; pm:_FillValue = 1.e+37 ; double pn(datum) ; pn:long_name = "curvilinear coordinate metric in ETA" ; pn:units = "meter-1" ; pn:coordinates = "Xrg Yrg" ; pn:_FillValue = 1.e+37 ; double dndx(datum) ; dndx:long_name = "XI-derivative of inverse metric factor pn" ; dndx:units = "meter" ; dndx:coordinates = "Xrg Yrg" ; dndx:_FillValue = 1.e+37 ; double dmde(datum) ; dmde:long_name = "ETA-derivative of inverse metric factor pm" ; dmde:units = "meter" ; dmde:coordinates = "Xrg Yrg" ; dmde:_FillValue = 1.e+37 ; double angle(datum) ; angle:long_name = "angle between XI-axis and EAST" ; angle:units = "radians" ; angle:coordinates = "Xrg Yrg" ; angle:_FillValue = 1.e+37 ; double mask(datum) ; mask:long_name = "land-sea mask of contact points" ; mask:flag_values = 0., 1. ; mask:flag_meanings = "land water" ; mask:coordinates = "Xrg Yrg" ;
global attributes:
The strategy here is to pack the contact points information for each contact region in a long vector. Several indices are available to unpack the data into the Fortran-90 contact structures for ρ-, u-, and v-points. Although NetCDF-4 supports derived type structures via the HDF5 library, a simpler Metadata model is chosen for interoperability. Notice that the contact points NetCDF file contains also the values for the various grid metrics needed in ROMS numerical kernel. Only the horizontal interpolation weights are provided here since they are always the same for a particular configuration. The vertical interpolation weights are computed internally in ROMS at each time step because of the time dependency of the vertical coordinates to the evolution of the free-surface.
</wikitex>
