Nested Grids
Nested Grids Menu | |
1. Introduction | |
ROMS has a nested design structure for the temporal coupling between a hierarchy of parent and child grids. All the state model variables are dynamically allocated and passed as arguments to the computational routines via Fortran-90 dereferenced pointer structures. All private arrays are automatic; their size is determined when the procedure is entered. This code structure facilitates computations over nested grids of different topologies. There are three types of nesting capabilities in ROMS:
- Phase I, released on April 2011 as ROMS version 3.5, included major updates to the nonlinear (NLM), perturbation tangent linear (TLM), finite-amplitude tangent linear (RPM), and adjoint (ADM) models numerical kernels to allow different horizontal I- and J-ranges in the DO-loops to permit operations on various nested grid classes (refinement, mosaics, and composite) and nesting layers (refinement and composite grid combinations). This facilitates the computation of any horizontal operator (advection, diffusion, gradient, etc.) in the nesting overlap regions and avoids the need for cumbersome lateral boundary conditions on the model variables and their associated flux/gradient values. The advantage of this approach is that it is generic to any discrete horizontal operator. The overlap region is an extended section of the grid that overlays an adjacent grid. The strategy is to compute the full horizontal operator at the contact points between nested grids instead of specifying boundary conditions.
- Phase II, released on September 2011 as ROMS version 3.6, included a major overhaul of lateral boundary conditions. All their associated C-preprocessing options were eliminated and replaced with logical switches that depend on the nested grid, if any. This facilitates, in a generic way, the processing or not of lateral boundary conditions in applications with nested grids. In nesting applications, the values at the lateral boundary points are computed directly in the overlap region by the numerical kernel. In addition, the logical switches allow different lateral boundary conditions types between active (temperature and salinity) and passive (biology, sediment, inert, etc.) tracers. The lateral boundary condition switches for each state variable and boundary edge are now specified in ROMS input script file, ocean.in.
- Phase III, to be released soon as ROMS version 3.7, includes the nesting calls to ROMS main time-stepping routines, main2d and main3d. The routine main2d is only used in shallow-water 2D barotropic applications whereas main3d is used in full 3D baroclinic applications. Several new routines will be added to process the information that it is required in the overlap region, what information needs to be exchanged from/to another grid, and when to exchange it. The exchange between grids can be one-way or two-way.
Nested Grids Classes
- Mosaic Grids Sub-Class
- Single Refinement Sub-Class
- Complex Estuary Refinement Grids Sub-Class
- Composite Grids
Mosaic Sub-Class:
Ngrids = 2
NestLayers = 1
GridsInLayer = 1
Ncontact = 2 -
Composite Overlap Sub-Class:
Ngrids = 2
NestLayers = 1
GridsInLayer = 1
Ncontact = 2 -
Ngrids = 2
NestLayers = 1
GridsInLayer = 1
Ncontact = 2 -
Ngrids = 6
NestLayers = 1
GridsInLayer = 6
Ncontact = 10
- Refinement Grids
Single Refinement Sub-Class:
Ngrids = 2
NestLayers = 2
GridsInLayer = 1 1
Ncontact = 2 -
Ngrids = 4
NestLayers = 3
GridsInLayer = 1 2 1
Ncontact = 6
Refinement & Partial Boundary Composite Sub-Class:
Ngrids = 3
NestLayers = 2
GridsInLayer = 2 1
Ncontact = 4 -
Complex Estuary Refinement Sub-Class:
Ngrids = 3
NestLayers = 2
GridsInLayer = 1 2
Ncontact = 4
</wikitex>
<wikitex> A contact region is an extended section of the grid that overlays or is adjacent to a nested grid. A contact point is a grid cell inside the contact region. The contact points are located according to the staggered Arakawa C-grid horizontal positions. Therefore, we have contact points at the ρ-, ψ-, u-, and v-points. However, the ψ-points are only used to define the physical grid perimeters within a contact region. ROMS does not have state variables located at ψ-points; vorticity is not explicitly specified in the governing equations. In a nested application, there are (Ngrids-1)*2 contact regions. Each contact region has a receiver grid and donor grid. The contact points of the receiver grid are processed using the donor grid cell containing the contact point. The contact points are coincident if the receiver and donor grids occupy the same position. If coincident grids, the receiver grid contact point data is just filled using the donor data. Otherwise, if not coincident, the receiver grid data is linearly interpolated from the donor grid cell containing the contact point.
TYPE T_NGC
END TYPE T_NGC
- Mosaic Sub-Class
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Receiver Grid = red -
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Receiver Grid = blue
- Composite Overlap Sub-Class
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 1
GridsInLayer = 2
Ncontact = 2
Donor Grid = red
Ngrids = 2
NestLayers = 2
GridsInLayer = 1 1
Ncontact = 2
Donor Grid = blue
Ngrids = 2
NestLayers = 2
GridsInLayer = 1 1
Ncontact = 2
Donor Grid = red
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = blue
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = red
Receiver Grid = blue -
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = red
Receiver Grid = green -
Ngrids = 4
NestLayers = 3
Ncontact = 6
Donor Grid = green
Receiver Grid = red
Ngrids = 3
NestLayers = 2
GridsInLayer = 2 1
Ncontact = 4
Donor Grid = blue
Ngrids = 3
NestLayers = 2
GridsInLayer = 2 1
Ncontact = 4
Donor Grid = red
</wikitex>
Metadata
dimensions:
Ngrids = 2 ;
Ncontact = 2 ;
Nweights = 4 ;
datum = 98 ;
variables:
int spherical ;
int Lm(Ngrids) ;
int Mm(Ngrids) ;
int coincident(Ngrids) ;
int composite(Ngrids) ;
int mosaic(Ngrids) ;
mosaic:flag_values = 0, 1 ;
int refinement(Ngrids) ;
int refine_factor(Ngrids) ;
int interpolate(Ncontact) ;
int donor_grid(Ncontact) ;
int receiver_grid(Ncontact) ;
int NstrR(Ncontact) ;
int NendR(Ncontact) ;
int NstrU(Ncontact) ;
int NendU(Ncontact) ;
int NstrV(Ncontact) ;
int NendV(Ncontact) ;
int contact_region(datum) ;
int on_boundary(datum) ;
int Idg(datum) ;
int Jdg(datum) ;
int Irg(datum) ;
Irg:coordinates = "Xrg Yrg" ;
int Jrg(datum) ;
Jrg:coordinates = "Xrg Yrg" ;
double Xrg(datum) ;
Xrg:units = "meter" ;
double Yrg(datum) ;
Yrg:units = "meter" ;
double h(datum) ;
h:units = "meter" ;
h:coordinates = "Xrg Yrg" ;
h:_FillValue = 1.e+37 ;
double f(datum) ;
f:units = "second-1" ;
f:coordinates = "Xrg Yrg" ;
f:_FillValue = 1.e+37 ;
double pm(datum) ;
pm:units = "meter-1" ;
pm:coordinates = "Xrg Yrg" ;
pm:_FillValue = 1.e+37 ;
double pn(datum) ;
pn:units = "meter-1" ;
pn:coordinates = "Xrg Yrg" ;
pn:_FillValue = 1.e+37 ;
double dndx(datum) ;
dndx:units = "meter" ;
dndx:_FillValue = 1.e+37 ;
double dmde(datum) ;
dmde:units = "meter" ;
dmde:_FillValue = 1.e+37 ;
double angle(datum) ;
angle:units = "radians" ;
angle:_FillValue = 1.e+37 ;
double mask(datum) ;
mask:flag_values = 0., 1. ;
global attributes:
:grid_files = " \n",
The strategy here is to pack the contact points information for each contact region in a long vector. Several indices are available to unpack the data into the Fortran-90 contact structures for ρ-, u-, and v-points. Although NetCDF-4 supports derived type structures via the HDF5 library, a simpler Metadata model is chosen for interoperability. Notice that the contact points NetCDF file contains also the values for the various grid metrics needed in ROMS numerical kernel. Only the horizontal interpolation weights are provided here since they are always the same for a particular configuration. The vertical interpolation weights are computed internally in ROMS at each time step because of the time dependency of the vertical coordinates to the evolution of the free-surface.
</wikitex>
