I4DVAR Observation Impact Tutorial
Incremental, 4-DVar (I4DVAR) Data Assimilation Observation Impact
The various files in the I4DVAR_impact folder are needed to run the primal form of the incremental, strong constraint, 4-Dimensional Variational (4D-Var) data assimilation observation impact in the California Current System, 1/3° resolution, application (WC13).
This page is under construction
Important CPP Options
IS4DVAR_SENSITIVITY I4D-Var observation sensitivity driver
WC13 Application CPP option
Input NetCDF Files
job_i4dvar_sen.sh job configuration script
ocean_wc13.in ROMS standard input script for WC13
Important parameters in standard input ocean_wc13.in script
DendS == 0.0d0 ! ending day
KstrS == 1 ! starting level
KendS == 30 ! ending level
Instructions
- We need to run the model application for a period that is long enough to compute meaningful circulation statistics, like mean and standard deviations for all prognostic state variables (zeta, u, v, T, and S). The standard deviations are written to NetCDF files and are read by the 4D-Var algorithm to convert modeled error correlations to error covariances. The error covariance matrix, D, is very large and not well known. It is modeled by convolving a diffusion equation as in Weaver and Courtier (2001).
In this application, we need standard deviations for initial conditions, surface forcing (ADJUST_WSTRESS and ADJUST_STFLUX), and open boundary conditions (ADJUST_BOUNDARY). The standard deviations for the initial and open boundary conditions are in terms of the unbalanced error covariance(K Du KT) since the balanced operator is activated (BALANCE_OPERATOR and ZETA_ELLIPTIC).
The balance operator imposes a multivariate constraint on the error covariance such that the unobserved variable information is extracted from observed data by establishing balance relationships (i.e., T-S empirical formulas, hydrostactic balance, and geostrophic balance) with other state variables (Weaver et al., 2005).
These standard deviations have already been created for you:../Data/wc13_std_i.nc initial conditions
../Data/wc13_std_f.nc surface forcing (wind stress and
net heat flux) - Since we are modeling the error covariance matrix, D, we need to compute the normalization coefficients to ensure that the diagonal elements of D are equal to unity. There are two methods to compute normalization coefficients: exact and randomization (an approximation).
The exact method is very expensive on large grids. The normalization coefficients are computed by perturbing each model grid cell with a delta function scaled by the area (2D state variables) or volume (3D state variables), and then by convolving with the squared-root adjoint and tangent linear diffusion operators.
The approximated method is cheaper: the normalization coefficients are computed using the randomization approach of Fisher and Courtier (1995). The coefficients are initialized with random numbers having a uniform distribution (drawn from a normal distribution with zero mean and unity variance). Then, they are scaled by the inverse squared-root of the cell area (2D state variable) or volume (3D state variable) and convolved with the squared-root adjoint and tangent diffusion operators over a specified number of iterations, Nrandom.
Check following parameters in the 4D-Var input script s4dvar.in (see input script for details):Nmethod == 0 ! normalization methodThese normalization coefficients have already been computed for you (../Normalization) using the exact method since this application has a small grid (54x53x30):
LdefNRM == F F F F ! Create a new normalization files
LwrtNRM == F F F F ! Compute and write normalization
CnormI(isFsur) = T ! 2D variable at RHO-points
CnormI(isUbar) = T ! 2D variable at U-points
CnormI(isVbar) = T ! 2D variable at V-points
CnormI(isUvel) = T ! 3D variable at U-points
CnormI(isVvel) = T ! 3D variable at V-points
CnormI(isTvar) = T T ! NT tracers
CnormB(isFsur) = T ! 2D variable at RHO-points
CnormB(isUbar) = T ! 2D variable at U-points
CnormB(isVbar) = T ! 2D variable at V-points
CnormB(isUvel) = T ! 3D variable at U-points
CnormB(isVvel) = T ! 3D variable at V-points
CnormB(isTvar) = T T ! NT tracers
CnormF(isUstr) = T ! surface U-momentum stress
CnormF(isVstr) = T ! surface V-momentum stress
CnormF(isTsur) = T T ! NT surface tracers flux../Data/wc13_nrm_i.nc initial conditionsNotice that the switches LdefNRM and LwrtNRM are all .FALSE. (F) since we already computed these coefficients.
net heat flux)
The normalization coefficients need to be computed only once for a particular application provided that the grid, land/sea masking (if any), and decorrelation scales (HdecayI, VdecayI, HdecayB, VdecayV, and HdecayF) remain the same. Notice that large spatial changes in the normalization coefficient structure are observed near the open boundaries and land/sea masking regions. - Before you run this application, you need to run the standard I4D-VAR (../I4DVAR directory) since we need the Lanczos vectors. Notice that in job_i4dvar_sen.sh we have the following operation:cp -p ${Dir}/I4DVAR/wc13_adj_001.nc wc13_lcz.ncIn 4D-Var (observartion space minimization), the Lanczos vectors are stored in the output 4D-Var NetCDF file wc13_adj_001.nc.
The adjoint sensitivity functional is defined as the time-averaged transport crossing 37N in the upper 500m. - Customize your preferred build script and provide the appropriate values for:
- Root directory, MY_ROOT_DIR
- Fortran compiler, FORT
- Notice that the most important CPP options for this application are specified in the build script instead of wc13.h:setenv MY_CPP_FLAGS "-DIS4DVAR_SENSITIVITY"This is to allow flexibility with different CPP options.
setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DOBS_IMPACT"
setenv MY_CPP_FLAGS "${MY_CPP_FLAGS} -DOBS_IMPACT_SPLIT"
For this to work, however, any #undef directives MUST be avoided in the header file wc13.h since it has precedence during C-preprocessing. - You MUST use the build script to compile.
- Customize the ROMS input script ocean_wc13.in and specify the appropriate values for the distributed-memory partition. It is set by default to:Notice that the adjoint-based algorithms can only be run in parallel using MPI. This is because of the way that the adjoint model is constructed.
- Customize the configuration script job_i4dvar_sen.sh and provide the appropriate place for the "substitute" Perl script:set SUBSTITUTE=${ROMS_ROOT}/ROMS/Bin/substituteThis script is distributed with ROMS and it is found in the ROMS/Bin sub-directory. Alternatively, you can define ROMS_ROOT environmental variable in your .cshrc login script. For example, I have:setenv ROMS_ROOT /home/arango/ocean/toms/repository/trunk
- Execute the configuration job_i4dvar_sen.sh BEFORE running the model. It copies the required files and creates i4dvar.in input script from template s4dvar.in. This has to be done EVERY TIME that you run this application. We need a clean and fresh copy of the initial conditions and observation files since they are modified by ROMS during execution.
- Run ROMS with data assimilation:mpirun -np 4 oceanM ocean_wc13.in > & log &
References
Moore, A.M., H.G. Arango, G. Broquet, B.S. Powell, J. Zavala-Garay, and A.T. Weaver, 2010: The Regional Ocean Modeling System (ROMS) 4-dimensional variational data assimilation systems, Part I: System overview, Ocean Modelling, draft.
Moore, A.M., H.G. Arango, and G. Broquet, C. Edwards, M. Veneziani, B.S. Powell, D. Foley, J. Doyle, D. Costa, and P. Robinson, 2010: The Regional Ocean Modeling System (ROMS) 4-dimensional variational data assimilation systems, Part II: Performance and application to the California Current System, Ocean Modelling, Draft.
Moore, A.M., H.G. Arango, and G. Broquet, C. Edwards, M. Veneziani, B.S. Powell, D. Foley, J. Doyle, D. Costa, and P. Robinson, 2010: The Regional Ocean Modeling System (ROMS) 4-dimensional variational data assimilation systems, Part III: Observation Impact and Observation Sensitivity in the California Current System, Ocean Modelling, Draft.
