RBL4D-Var Analysis Observation Sensitivity Tutorial
4-DVar PSAS Observation Sensitivity
The various files in the PSAS_impact folder are needed to run the Strong/Weak constraint, 4-Dimensional Variational (4D-Var) data assimilation observation sensitivity based on the Physical-space Statistical Analysis System (PSAS) algorithm in the California Current System, 1/3° resolution, application (WC13).
This page is under construction
Important CPP Options
W4DPSAS_SENSITIVITY 4D-PSAS observation sensitivity driver
WC13 Application CPP option
Input NetCDF Files
job_psas_sen.sh job configuration script
ocean_wc13.in ROMS standard input script for WC13
Important parameters in standard input ocean_wc13.in script
DendS == 0.0d0 ! ending day
KstrS == 1 ! starting level
KendS == 30 ! ending level
- FWDNAME == wc13_fwd.nc
HISNAME == wc13_fwd.nc
Instructions
- Before you run this application, you need to run the standard [[PSAS_Tutorial|4D-PSAS) (../PSAS directory) since we need the Lanczos vectors. Notice that in job_psas_sen.sh we have the following operation:cp -p ${Dir}/PSAS/wc13_mod.nc wc13_lcz.ncIn 4D-PSAS (observartion space minimization), the Lanczos vectors are stored in the output 4D-Var NetCDF file wc13_mod.nc.
The adjoint sensitivity functional is defined as the time-averaged transport crossing 37N in the upper 500m. - Customize your preferred build script and provide the appropriate values for:
- Root directory, MY_ROOT_DIR
- Fortran compiler, FORT
- Notice that the most important CPP options for this application are specified in the build script instead of wc13.h:setenv MY_CPP_FLAGS "-DW4DPSAS_SENSITIVITY"This is to allow flexibility with different CPP options.
For this to work, however, any #undef directives MUST be avoided in the header file wc13.h since it has precedence during C-preprocessing. - You MUST use the build script to compile.
- Customize the ROMS input script ocean_wc13.in and specify the appropriate values for the distributed-memory partition. It is set by default to:NtileI == 2 ! I-direction partitionNotice that the adjoint-based algorithms can only be run in parallel using MPI. This is because of the way that the adjoint model is constructed.
NtileJ == 2 ! J-direction partition - Customize the configuration script job_psas_sen.sh and provide the appropriate place for the "substitute" Perl script:set SUBSTITUTE=${ROMS_ROOT}/ROMS/Bin/substituteThis script is distributed with ROMS and it is found in the ROMS/Bin sub-directory. Alternatively, you can define ROMS_ROOT environmental variable in your .cshrc login script. For example, I have:setenv ROMS_ROOT /home/arango/ocean/toms/repository/trunk
- Execute the configuration job_psas_sen.sh BEFORE running the model. It copies the required files and creates psas.in input script from template s4dvar.in. This has to be done EVERY TIME that you run this application. We need a clean and fresh copy of the initial conditions and observation files since they are modified by ROMS during execution.
- Run ROMS with data assimilation:mpirun -np 4 oceanM ocean_wc13.in > & log &
References
Moore, A.M., H.G. Arango, G. Broquet, B.S. Powell, J. Zavala-Garay, and A.T. Weaver, 2010: The Regional Ocean Modeling System (ROMS) 4-dimensional variational data assimilation systems, Part I: System overview, Ocean Modelling, draft.
Moore, A.M., H.G. Arango, and G. Broquet, C. Edwards, M. Veneziani, B.S. Powell, D. Foley, J. Doyle, D. Costa, and P. Robinson, 2010: The Regional Ocean Modeling System (ROMS) 4-dimensional variational data assimilation systems, Part II: Performance and application to the California Current System, Ocean Modelling, Draft.
Moore, A.M., H.G. Arango, and G. Broquet, C. Edwards, M. Veneziani, B.S. Powell, D. Foley, J. Doyle, D. Costa, and P. Robinson, 2010: The Regional Ocean Modeling System (ROMS) 4-dimensional variational data assimilation systems, Part III: Observation Impact and Observation Sensitivity in the California Current System, Ocean Modelling, Draft.
