npzd Franks.in
1 | iNO3_ | Nitrate concentration | mmol/m3 | idTvar(iNO3_) |
2 | iPhyt | Phytoplankton biomass | mmol/m3 | idTvar(iPhyt) |
3 | iZoop | Zooplankton biomass | mmol/m3 | idTvar(iZoop) |
4 | iSDet | Detritus concentration | mmol/m3 | idTvar(iSDet) |
Biological Model Parameters
- Lbiology == T
- BioIter == 1
- BioIni(iNO3_) == 1.67d0 ! nitrate
BioIni(iPhyt) == 0.08d0 ! phytoplankton
BioIni(iZoop) == 0.06d0 ! zooplankton
BioIni(iSDet) == 0.04d0 ! detritus
- K_ext == 0.06d0
- K_NO3 == 0.1d0
- K_Phy == 0.4d0
- Vm_NO3 == 2.0d0
- PhyMR == 0.05d0
- ZooGR == 0.6d0
- ZooMR == 0.2d0
- ZooMD == 0.05d0
- ZooGA == 0.3d0
- ZooEC == 0.15d0
- DetRR == 0.1d0
- wDet == 5.0d0
- TNUDG == 4*0.0d0 ! days
- Logical switches to specify which variables to consider on tracers point Sources/Sinks (like river runoff): [1:NBT,Ngrids] values expected.The switches correspond to the Variable Index Table at the top of this page.LtracerSrc == 4*FAs an example, if you wanted to exclude zooplankton biomass from the tracers you would do the following:LtracerSrc == 2*T F T
- Logical switches to activate writing of biological tracers into history/average output file: [1:NBT,Ngrids] values expected. The switches correspond to the Variable Index Table at the top of this page.
- Hout(idTvar) == 4*T
