npzd iron.in
NPZD-Iron Biological Model Input Script - npzd_iron.in
The npzd_iron.in file sets the parameters for the Fiechter et al. NPZD model. The name of this file is set by the BPARNAM keyword in the ocean.in file. A default npzd_iron.in standard input ASCII file can be found in the User/External subdirectory of the ROMS source code. In order to include the Fiechter et al. NPZD model in ROMS you must set BPARNAM correctly and activate the NPZD_IRON CPP option.
Biological Model Parameters
- Lbiology == T
- BioIter == 1
- BioIni(iNO3_) == 17.0d0 ! nitrate
BioIni(iPhyt) == 1.0d0 ! phytoplankton
BioIni(iZoop) == 1.0d0 ! zooplankton
BioIni(iSDet) == 1.0d0 ! detritus
BioIni(iFdis) == 0.0d0 ! dissolved iron
BioIni(iFphy) == 0.0d0 ! iron in phytoplankton
- Fraction of shortwave radiation that is photosynthetically active, [nondimensional], {0.43d0}.
- PARfrac == 0.43d0
- Light attenuation due to seawater, [1/m], {0.067d0}.
- AttSW == 0.067d0 ! k_ext
- Light attenuation due to phytoplankton, self-shading coefficient, [m2/millimole_N], {0.0095d0}.
- AttPhy == 0.04d0 ! k_extP
- Phytoplankton, initial slope of P-I curve [m2/W], {0.025d0}.
- PhyIS == 0.02d0 ! alpha
- Nitrate uptake rate, [1/day], {1.0d0}.
- Vm_NO3 == 1.0d0 !Vm
- Phytoplankton mortality rate to Detritus pool, [1/day], {0.1d0}.
- PhyMRD == 0.1d0 ! sigmaD
- Phytoplankton mortality rate to Nitrogen pool, [1/day], {0.0d0}.
- PhyMRN == 0.0d0 ! sigmaN
- Half-saturation for phytoplankton nitrate uptake [1/millimole_N m-3], {1.0d0}.
- K_NO3 == 1.0d0 ! k_N
- Ivlev constant for zooplankton grazing parameterization [Nondimensional], {14*0.06=0.84d0}
- Ivlev == 0.84d0
- Zooplankton grazing rate, [1/day], {0.52d0}.
- ZooGR == 0.65d0 ! R_m
- Zooplankton excretion efficiency to Detritus pool [nondimensional], {0.3d0}
- ZooEED == 0.0d0 ! gammaD
- Zooplankton excretion efficiency to Nitrogen pool [nondimensional], {0.3d0}
- ZooEEN == 0.3d0 ! gammaN
- Zooplankton mortality rate to Detritus pool, [1/day], {0.0d0}.
- ZooMRD == 0.145d0 ! zetaD
- Zooplankton mortality rate to Nitrogen pool, [1/day], {0.145d0}.
- ZooMRN == 0.0d0 ! zetaN
- DetRR == 0.1d0 ! delta
- Vertical sinking velocity for phytoplankton, [m/day], {0.0d0}.
- wPhy == 0.0d0 ! wP
- wDet == 5.0d0 ! wD
- Iron uptake timescale, [day], {1.0d0}.
- T_Fe == 1.0d0 ! T_Fe
- Empirical Fe:C power, [nondimensional], {0.6d0}.
- A_Fe == 0.6d0 ! A_Fe
- Empirical Fe:C coefficient, [1/M-C], {64.0d0}.
- B_Fe == 64.0d0 ! B_Fe
- Fe:C at F=0.5, [muM-Fe/M-C], {16.9d0}.
- K_FeC == 16.9d0 ! K_FeC
- Fe remineralization rate, [1/day], {1.0d0}.
- FeRR == 0.5d0 ! FeRR
- If applicable, dissolved Fe relaxation (nudging) parameters to simulate Fe source over the shelf (h <= FeHmin).
- FeHmin == 200.0d0 ! minimum depth(m)
FeNudgTime == 5.0d ! nudging time (days)
FeMax == 2.0d0 ! Fe value (mmole/m3) to nudge
- TNUDG == 6*0.0d0 ! days
- Logical switches to specify which variables to consider on tracers point Sources/Sinks (like river runoff): [1:NBT,Ngrids] values expected.
- LtracerSrc == 6*F
- Logical switches to activate writing of biological tracers into history output file: [1:NBT,Ngrids] values expected.
- Hout(idTvar) == 6*T ! biological tracer
Hout(idTsur) == 6*F ! surface tracer flux
! idTvar(idbio(1))=iNO3_ Nitrate concentration
! idTvar(idbio(2))=iPhyt Phytoplankton biomass
! idTvar(idbio(3))=iZoop Zooplankton biomass
! idTvar(idbio(4))=iSdet Detritus concentration
! idTvar(idbio(5))=iFdis Dissolved iron concentration
! idTvar(idbio(6))=iFphy Phytoplankton Iron concentration - As an example, if you only wanted to write zooplankton biomass and Phytoplankton Iron concentration to the history and averages files you would do the following:
- Hout(idTvar) == 2*F T 2*F T
