npzd Franks.in
Biological Model Parameters
- Lbiology == T
- BioIter == 1
- BioIni(iNO3_) == 1.67d0 ! nitrate
BioIni(iPhyt) == 0.08d0 ! phytoplankton
BioIni(iZoop) == 0.06d0 ! zooplankton
BioIni(iSDet) == 0.04d0 ! detritus
- K_ext == 0.06d0
- K_NO3 == 0.1d0
- K_Phy == 0.4d0
- Vm_NO3 == 2.0d0
- PhyMR == 0.05d0
- ZooGR == 0.6d0
- ZooMR == 0.2d0
- ZooMD == 0.05d0
- ZooGA == 0.3d0
- ZooEC == 0.15d0
- DetRR == 0.1d0
- wDet == 5.0d0
- Lateral, constant, harmonic/biharmonic horizontal diffusion of biological tracer: [1:NBT,Ngrids] values expected.
- AKT_BAK == 4*1.0d-6 ! m2/s
- TNUDG == 4*0.0d0 ! days
- Logical switches to activate writing of biological tracers into history output file: [1:NBT,Ngrids] values expected.
