Internal Plotting Parameters
Internal Plotting Parameters (default.cnt)
The internal plotting parameters of the ROMS plotting package are controlled buy the default.cnt file. This configuration file allows you to adjust things like font size and line thickness. This page is intended as a reference for the options contained in this file. A sample default.cnt can be found in the Data directory of the source code.
Plotting Package Menu |
1. Installation |
2. Contour Plots |
3. Cross-section Plots |
5. Plotting Options |
6. Plotting Fields |
7. Raster Scripts |
- LVPINFO
- Switch to print out viewport information (T/F). If you set this to T the output to the terminal from the ccnt or csec command will include additional information about the dimensions of the resulting plots.
- Default Value: F
- Sample output from csec
- SEC_FRAME - plots/page = 1
SEC_FRAME - current plot = 1
SEC_FRAME - frame left = 0.0909
SEC_FRAME - frame right = 0.8182
SEC_FRAME - frame bottom = 0.1818
SEC_FRAME - frame top = 0.7955
SEC_FRAME - box Xmin = 0.0000
SEC_FRAME - box Xmax = 81.0000
SEC_FRAME - box Zmin = -150.0000
SEC_FRAME - box Zmax = 0.0000
- SDV_FAC
- Standard deviation factor from mean for field range to plot.
- Default Value: 0.0
- GEO_LAB
- Geographic axis labeled as degrees and minutes (T/F).
- Default Value: T
- LOG_CNT
- Switch for logarithmic contour intervals (T/F). If set to T interval between the color bands of a contour plot (there is no affect on a cross-section plot) will be calculated logarithmically rather than linearly.
- Default Value: F
- LNOZERO
- Switch to omit drawing of zero-contour line (T/F) for overlays.
- Default Value: T
- LCNTLAB
- Switch to label contour lines (T/F) for overlays.
- Default Value: T
- CNT_CLL
- Width of labeled contour lines: [0] default, [2] double for overlays.
- Default Value: 0
- LDRWUSR
- Switch to draw user lines (T/F).
- Default Value: T
- LHIGLOW
- Switch to label High/Low contour labels (T/F).
- Default Value: F
- LMODDAY
- Switch to write model day (forecast) in date label (T/F) near the bottom of the plot.
- Default Value: T
- LDOMAIN
- Switch to draw domain box (T/F).
- Default Value: T
- LFRAME
- Switch to draw NCAR frame box (T/F).
- Default Value: T
- LTMARKS
- Switch to draw box tick marks and labels (T/F).
- Default Value: T
- LCLRBAR
- Switch to draw color bar (T/F).
- Default Value: T
- LVECRHO
- Switch to draw vectors at RHO-points (F: at PSI-points).
- Default Value: T
- LVCOLOR
- Switch to paint vectors by their magnitude (T/F).
- Default Value: T
- LROTVEC
- Switch to rotate vector component normal to cross-section.
- Default Value: F
- LZEROZN
- Switch to set surface depth to zero in cross-sections.
- Default Value: T
- THCKUSR
- User polylines thickness.
- Default Value: 2.0
- VEC_VPO
- Vector positioning mode: [<0] head, [0] middle, [>0] tail. This sets what part of the vector is located at the RHO-points (or PSI-points if LVECRHO is F).
- Default Value: 1 (tail)
- VEC_AMN
- Vector arrow minimum size (fraction of viewport width).
- Default Value: 0.0007
- VEC_AMX
- Vector arrow maximum size (fraction of viewport width).
- Default Value: 0.05
- VEC_VLC
- Vector low cutoff percentage.
- VEC_VFR
- Vector fractional minimum.
- Default Value: 0.07
- VEC_VRM
- Vector reference magnitude (if zero, use maximum cutoff).
- VEC_MXX
- Maximum vector text block X-coordinate.
- Default Value: 0.85
- VEC_MXY
- Maximum vector text block Y-coordinate.
- Default Value: -0.07
- SECAXIS
- Section axis coordinate labels: [0] metric, [1] spherical.
- Default Value: 0
- COORSCL
- Cartesian coordinate units: [0] km, [1] m, [2] cm, [3] mm
- Default Value: 0
- HVELSCL
- H velocity: [0] m/s [1] cm/s [2] mm/s [3] -knots [4] -knots/2
- Default Value: 1
- WVELSCL
- V velocity: [0] m/s [1] m/day [2] cm/day
- Default Value: 2
- ZREF
- Reference depth (m) used to compute several quantities.
- SMTHOUT
- Smooth output: [0] no, [1] Bleck's filter, [2] Shapiro filter
- Default Value: 0
- NSAPPL
- Number of applications of smoothing filter. This only has an effect if SMTHOUT is not 0.
- Default Value: 1
- NORD
- Order of Shapiro filter. This only has an effect if SMTHOUT is set to 2.
- Default Value: 4
- FontSz1
- Font size for main header title.
- Default Value: 20.0 plotter units
- FontSz2
- Font size for secondary top/bottom titles.
- Default Value: 10.0 plotter units
- FontSz3
- Font size for colorbar labels.
- FontSz4
- Font size for grid labels.
- Default Value: 9.0 plotter units
- FontSz5
- Font size for Min, Max, CI labels.
- Default Value: 7.0 plotter units
- FontSz6
- Font size for current date label.
- Default Value: 5.0 plotter units
- IFLDS, ILEVS
- Number of fields and levels in contour interval list.
- Default Value: 29,2
← Prev: Cross-section Plots
Next: Plotting Options →
