Contour Plots
Contour Plots
The ROMS plotting package allows you to plot results for most variables at any depth. You can also overlay a reference field.
Table of Contents
1. Installation
2. Contour Plots
3. Cross-section Plots
5. Plotting Options
6. Plotting Fields
7. Raster Scripts
Configuration
  > cd ~/MyPlots
  > cp ~/MyDir/src/External/ccnt.in ccnt_hraw.in
  > cp ~/MyDir/Data/default.cnt default.cnt
  2007 -1      : year and starting year-day (use yearday<0, for no time label)
  ROMS 3.0
  Philippine Archipelago Straits
  Bathymetry (hraw)
  1     NFIELDS: number of fields to plot. Line below, field(s) types:
  63             field identification: FLDID(1:NFIELDS)
Bathymetry is a special case that has only one level so use the following options.
  1     NLEVELS: number of depths/levels/isopycnals to plot (0 for all levels)
  0              depths (<0), levels (>0) or isopycnals (>1000) to plot
  -1    FRSTD  : first day (>0) or time record (<0) to plot
  -1    LASTD  : last day (>0) or time record (<0) to plot
  0     DSKIP  : plot every other DSKIP day/record (see below)
  1     FINDX  : forecast record to process, if any (atmospheric files only).
  0     VINTRP : vertical interpolation scheme: 0=linear, 1:cubic splines
I have chosen to set the next two values because I know my range already. If you do not know the range of your data you should enter 0.0 and the plotting package will calculate the minimum and maximum values. Using the defaults can lead to other problems because the minimum and maximum values are recalculated for each plot. This means you could end up with a different range and color bar for every frame, making visual analysis very difficult.
  -6000 PMIN   : field minimum value for color palette (0.0 for default)
  1000  PMAX   : field maximum value for color palette (0.0 for default)
  1     ICNT   : draw contours between color bands: 0=no, 1=yes
  0.0   ISOVAL : iso-surface value to process (see below)
  1.2   VLWD   : vector line width (1.0 for default)
  4.0   VLSCL  : vector length scale (1.0 for default)
  2     IVINC  : vector grid sampling in the X-direction (1 for default)
  1     JVINC  : vector grid sampling in the Y-direction (1 for default)
The next five values control the overlay or reference field. I want a special overlay of cross-section lines that will be specified in a special file named fort.35. The contents of this file will be shown later in this tutorial. To overlay specified user data from a fort.35 file set IREF to -2. The rest of this section is ignored because IREF is not set to 1 or 2.
  -2     IREF   : secondary or reference field option (see below)
  25    IDOVER : overlay field identification (for IREF=1,2 only)
  1     LEVOVER: level of the overlay field (set to 0 if same as current FLDLEV)
  0.0   RMIN   : overlay field minimum value to consider (0.0 for default)
  0.0   RMAX   : overlay field maximum value to consider (0.0 for default)
This determines the spacing between grid lines in the plot. 2.0 is good for this example.
  2.0   LGRID  : Desired longitude/latitude grid spacing (degrees)
  2     IPROJ  : map projection (see below).
  0.0   PLON   : projection Pole longitude (west values are negative).
  0.0   PLAT   : projection Pole latitude (south values are negative).
  0.0   ROTA   : projection rotation angle (clockwise; degrees).
  0     LMSK   : flag to color mask land: [0] no, [>0] yes  (see below)
  -1   NPAGE  : number of plots per page (currently 1, 2, or 4)
I don't want grid positions computed from the specified grid or history file.
  F     READGRD: logical switch to read in positions from grid NetCDF file.
I don't know what this does.
  F     PLTLOGO: logical switch draw Logo.
  F     WRTHDR : logical switch to write out the plot header titles.
  F     WRTBLAB: logical switch to write out the plot bottom title.
  F     WRTRANG: logical switch to write out data range values and CI.
  F     WRTFNAM: logical switch to write out input primary filename.
  F     WRTDATE: logical switch to write out current date.
  T     CST    : logical switch to read and plot coastlines and islands.
     6.0  14.0  : bottom and top map latitudes (south values are negative).
   118.0 128.0  : left and right map longitudes (west values are negative).
  ~/Mydir/Data/varid.dat
  ~/Mydir/Palettes/gebco1.pal
  ~/Mydir/Data/default.cnt
The fourth file is your primary NetDCF file. I have my bathymetry in a separate NetCDF file.
  philip_hraw_b.nc
The fifth file is you secondary NetCDF file. Some times the data you want to overlay will be in a different file. If that is the case you would set IREF to 2, then put the name of the file your overlay data should come from here. However, my overlay data is in a special fort.35file so it doesn't matter what I set this to so I'll set it to be the same as my primary NetCDF file. For more information about IREF check the Plotting Options page.
  philip_hraw_b.nc
The sixth file is your grid NetCDF file. As mentioned above, I don't want my grid positions computed from a grid file so it doesn't matter what I put here because it will be ignored. I will use my primary NetCDF file again.
  philip_hraw_b.nc
The seventh file is you coastlines file. There are several coastline files in the Data directory. My coastline file is named philip_high.cst. If CST is set to F this line will be ignored.
  philip_high.cst
Save the ccnt_hraw.in file. Now we just need our fort.35 file specifying our cross-section lines.
fort.35
Open your favorite editor. The format of the fort.35 is pretty simple. Each shape block begins with 999.000000 then an RGB color specification (i.e. 0 255 0 would be green).
   999.000000                  0  255    0
all between that and the next shape block beginning line (999.000000) are ordered pairs of points. You need at least 2 lines here for anything to show up. The following 3 lines tell the plotting package to overlay a horizontal green (0 255 0) line from 8.8°N, 118°E to 8.8°N, 128°E.
   999.000000                  0  255    0
     8.800000   118.000000
     8.800000   128.000000
   999.000000                  0  255    0
     8.800000   118.000000
     8.800000   128.000000
   999.000000                237  107  172
    11.300000   119.650000
    11.300000   122.010000
   999.000000                153    0  204
    12.200000   120.250000
    12.200000   121.050000
   999.000000                255  255    0
     6.000000   121.300000
    12.250000   121.300000
   999.000000                255  255  255
     8.550000   123.100000
     9.030000   123.100000
   999.000000                255    0    0
     9.000000   125.320000
    10.500000   125.320000
   999.000000   999.000000
   999.000000                255    0    0
     9.000000   125.320000
    10.500000   124.000000
     9.000000   124.000000
     9.000000   125.320000
Plotting
  > which ccnt
  /home/robertson/bin/ccnt
  > which idt
  > printenv NCARG_ROOT
  > ccnt < ccnt_temp.in
You will see some information about each frame scroll by. When the program finishes you will have a file named gmeta in the current directory. Now you can use idt to view your plots.
  > idt gmeta &
Clicking the button repeatedly will advance to the frames of the gmeta file if you plotted more than one record and/or field. I suggest you take some time to experiment with the controls in the idt window.
Prev: Installation
