AVERAGES AKT
Revision as of 01:27, 31 May 2007 by Arango (talk | contribs) (New page: {{#lst:Options|AVERAGES_AKT}})
(change visibility) (diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
AVERAGES_AKT (REMOVED)
This option was removed in revision 462. Option to write out time-averaged vertical diffusion of temperature into output NetCDF file. Use this option when any of the vertical mixing parameterizations is activated.
parameter = nAVG, ndefAVG, ntsAVG
parent = AVERAGES
required = AVERAGES
related = AVERAGES_AKS, AVERAGES_AKV, AVERAGES_BEDLOAD, AVERAGES_FLUXES, AVERAGES_NEARSHORE, AVERAGES_QUADRATIC
routine = def_avg.F, set_avg.F, wrt_AVG.F
