ANA HUMIDITY
- ANA_HUMIDITY
- Option to set surface air humidity (moisture) with an analytical expression. There are three types of humidity: i) absolute humidity is the density of water vapor, ii) specific humidity is the ratio of the mass of water vapor to the mass of moist air containing the vapor (g/kg), and iii) relative humidity is the ratio of the actual mixing ratio to saturation mixing ratio of the air at a given temperature and pressure (percentage).
- variable = Hair
- required = ALBEDO, BULK_FLUXES, ECOSIM
- routine = analytical.F (ana_humid)
