I have what I think is an odd problem.
I am simulating a simple planar shore. It goes from ~-8m deep to ~+2m and extends offshore ~1.8 km. I am simulating tides via ANA_FSOBC. (See below for my *.h file contents)
I have been having trouble getting meaningful results from my simulations, so to diagnose things, I started with a small grid (via Seagrid) on a portion of the domain and expanded it to see if there was something funny going on.
I have a 70x70 grid that I can get to run sorta. The odd thing is that when I halt the run by Ctrl+C, I get a good sinusodial signal at the boundary but when I allow it to run to completion, I get a flat signal with a large oscillation near the end of the simulation.
I'm very confused as to why when I break it, I get good results but when I allow it to stop I get something completely different.
Any suggestions as to what's going on and how to start de-bugging it?
drew
My run info is:
Process Information:
Thread # 0 (pid= 0) is active.
Wednesday - April 30, 2008 - 2:56:08 PM
Slope only test case
Operating system : CYGWIN
CPU/hardware : i686
Compiler system : g95
Compiler command : g95
Compiler flags : -fno-second-underscore -O3 -ffast-math -ffree-form
SVN Revision : 161M
Local Root : /ROMS
Header Dir : /ROMS/projects/estuary
Header file : estuary.h
Analytical Dir: /ROMS/projects/estuary/Functionals
Resolution, Grid 01: 0068x0068x005, Parallel Threads: 1, Tiling: 001x001
2750 ntimes Number of timesteps for 3-D equations.
2.000 dt Timestep size (s) for 3-D equations.
1200 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
60 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
60 nAVG Number of timesteps between the writing of
60 nDIA Number of timesteps between the writing of
0.0000E+00 visc2 Horizontal, harmonic mixing coefficient (m2/s)
for tracer 02: salt
5.0000E-06 Akv_bak Background vertical mixing coefficient (m2/s)
5.0000E-02 Dcrit Minimum depth for wetting and drying (m).
1.0000E+00 theta_s S-coordinate surface control parameter.
50.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
34.000 S0 Background salinity (PSU) constant.
of State.
T Hout(idVvis) Write out vertical viscosity coefficient.
T Hout(idTdif) Write out vertical T-diffusion coefficient.
T Hout(idSdif) Write out vertical S-diffusion coefficient.
Output Diagnostics File: ocean_dia.nc
Input Grid File: data/Bathymetry/seagrid_slope_only.nc
Tile partition information for Grid 01: 0068x0068x0005 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 68 1 68 23120
ESTUARY Slope only test case
AVERAGES Writing out time-averaged fields.
EW_PERIODIC East-West periodic boundaries.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTHERN_WALL Wall boundary at Northern edge.
OUT_DOUBLE Double precision output fields in NetCDF files.
SALINITY Using salinity.
SOUTH_FSCHAPMAN Southern edge, free-surface, Chapman condition.
SOUTH_M2GRADIENT Southern edge, 2D momentum, gradient condition.
THREE_GHOST Using three Ghost Points in halo regions.
UV_ADV Advection of momentum.
UV_U3HADVECTION Third-order upstream bias advection of momentum.
Vertical S-coordinate System:
5 0.0000000 0.0000000 -0.000 0.000 0.000
4 -0.2000000 -0.1767149 0.353 -0.599 -1.550
3 -0.4000000 -0.3665746 0.733 -1.242 -3.216
2 -0.6000000 -0.5681794 1.136 -1.924 -4.985
1 -0.8000000 -0.7795007 1.559 -2.640 -6.839
0 -1.0000000 -1.0000000 2.000 -3.387 -8.774
Time Splitting Weights: ndtfast = 20 nfast = 29
3-0.0011514592651645 0.0501156998674241-0.0034654566136461 0.1501639558342180
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649003
6 0.0029141799764308 0.0501428056118168 0.0000580677400948 0.3006719858911027
7 0.0054132615310267 0.0499970966129953 0.0054713292711215 0.3506690825040980
8 0.0084687837865132 0.0497264335364439 0.0139401130576347 0.4003955160405419
9 0.0120633394191050 0.0493029943471183 0.0260034524767397 0.4496985103876602
10 0.0161716623600090 0.0486998273761630 0.0421751148367487 0.4983983377638232
11 0.0207585511322367 0.0478912442581626 0.0629336659689854 0.5462895820219857
12 0.0257765478740990 0.0468533167015507 0.0887102138430844 0.5931428987235364
13 0.0311633730493853 0.0455644893078458 0.1198735868924698 0.6387073880313822
14 0.0368391158442262 0.0440063206553765 0.1567127027366960 0.6827137086867586
15 0.0427031802506397 0.0421643648631652 0.1994158829873357 0.7248780735499238
16 0.0486309868367616 0.0400292058506332 0.2480468698240973 0.7649072794005570
17 0.0544704302037592 0.0375976565087951 0.3025173000278565 0.8025049359093521
18 0.0600380921294286 0.0348741349986072 0.3625553921572851 0.8373790709079593
19 0.0651152103984763 0.0318722303921357 0.4276706025557614 0.8692513013000950
20 0.0694434033194840 0.0286164698722119 0.4971140058752453 0.8978677711723069
21 0.0727201499285570 0.0251442997062377 0.5698341558038024 0.9230120708785446
22 0.0745940258796570 0.0215082922098099 0.6444281816834594 0.9445203630883545
23 0.0746596950216180 0.0177785909158270 0.7190878767050775 0.9622989540041815
24 0.0724526566618460 0.0140456061647461 0.7915405333669234 0.9763445601689277
25 0.0674437485167025 0.0104229733316538 0.8589842818836260 0.9867675335005816
26 0.0590334053485720 0.0070507859058187 0.9180176872321980 0.9938183194064003
27 0.0465456732896125 0.0040991156383901 0.9645633605218105 0.9979174350447904
28 0.0292219798521905 0.0017718319739095 0.9937853403740009 0.9996892670186999
29 0.0062146596259991 0.0003107329813000 1.0000000000000000 0.9999999999999998
Minimum X-grid spacing, DXmin = 2.22740141E-02 km
Maximum X-grid spacing, DXmax = 2.37788760E-02 km
Minimum Y-grid spacing, DYmin = 2.15793592E-02 km
Maximum Y-grid spacing, DYmax = 2.93943967E-02 km
Minimum Z-grid spacing, DZmin = -4.40998655E-01 m
Maximum Z-grid spacing, DZmax = 1.93453005E+00 m
Minimum barotropic Courant Number = 1.51584110E-03
Maximum barotropic Courant Number = 5.25009888E-02
Maximum Coriolis Courant Number = 1.63176677E-04
Maximum grid stiffness ratios: rx0 = 1.184688E+00 (Beckmann and Haidvogel)
rx1 = 9.560814E+00 (Haney)
Initial basin volumes: TotVolume = 8.87846799624389E+06 m3
MinVolume = -2.35267976346406E+02 m3
MaxVolume = 1.29879883961064E+03 m3
Max/Min = -5.52050839974200E+00
NL ROMS/TOMS: started time-stepping:( TimeSteps: 00000001 - 00002750)
STEP time[DAYS] KINETIC_ENRG POTEN_ENRG TOTAL_ENRG NET_VOLUME trd
0 0.00000 0.000000E+00 2.928075E+01 2.928075E+01 9.575246E+06 0
DEF_AVG - creating average file: ocean_avg.nc
DEF_DIAGS - creating diagnostics file: ocean_dia.nc
