question about density anomaly
ocean_qian
#1 Unread post by ocean_qian »
The density anomaly from my output history file is always in the range of 25-45. If this is normal for ROMS file then can anybody tell me how to convert it to normal potential density (sigma-t or sigma-0 in the range of 23-28)?
Qian
#2 Unread post by wilkin »
ROMS outputs in situ density (anomaly) because this is the quantity that is integrated vertically to obtain pressure via the hydrostatic relation.
Density is not a state variable of the model, so there is no real need to work in terms of potential density (ROMS does not advect or diffuse density as such, so a conservative density quantity is not required for any computation).
ROMS state variables are salinity and potential temperature, and by equating depth with pressure in decibars you can use one of many possible codes to compute potential density from S and T. See for example options at http://sam.ucsd.edu/sio210/propseawater/ppsw.html
