gmake errors: gmake: *** virtual memory exhausted. Stop. ..
Hi all, I use "gmake" for roms3.0 on IBM AIX 6000, and errors appears as follows:
d35n01:/dgpfs/fs1/wangdk/roms3 $ gmake
makefile:230: INCLUDING FILE Compilers/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
gmake: svnversion: Command not found
Could you tell me what the errors mean and how to solve them?
btw, I check the Compilers file and cann't find make_macros.mk
I think your main problem is the gmake version - you need version 3.81
I can successfully run on an IBM AIX system.
cygnus.arsc.edu 574% make --version
GNU Make 3.81
Hi Kate! thanks a lot for your valuable reply. The gmake version I use is
3.80. I wii ask the IBM controller if he could insall the 3.81 gmake version for my specific requireness.
d35n01:/dgpfs/fs1/wangdk $ gmake --version
GNU Make 3.80
Copyright (C) 2002 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
However,
d35n01:/dgpfs/fs1/wangdk/roms3 $ which svnversion
which 0652-141 there is no svnversion in /user/lpp/. ....
As to the above informations, should I also need an svnversion in th IBM?
By the way, does the file "make_macros.mk" appear after the compile
successfully copmplished?
Many thanks!
GNU Make 3.80
PARTICULAR PURPOSE.
However,
Many thanks!
I believe the svn line is a warning, not an error. If it's an error, comment it out in the makefile.
The last step in compiling removes that other file:
mpxlf95_r -qsuffix=f=f90 -qmaxmem=-1 -qarch=pwr4 -qtune=pwr4 -O3 -qstrict -bmaxdata:0x70000000 Build/master.o Build/ocean_control.o Build/ocean_coupler.o Build/propagator.o -o oceanM Build/libNLM.a Build/libANA.a Build/libICE.a Build/libUTIL.a Build/libMODS.a -L/usr/local/lib -lnetcdf
rm -f -r /gpfsu/u1/uaf/kate/kate_branch/Compilers/make_macros.mk
Re: gmake errors: gmake: *** virtual memory exhausted. Stop. ..
I found a similar error:
/afs/posseidon.dern.ufes.br/usr/angelolemos/src# gmake
makefile:235: INCLUDING FILE /afs/posseidon.dern.ufes.br/usr/angelolemos/src/Compilers/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
How can I solve that?
Thanks!
Thanks!
I have seen that error with an older version of gmake. What version do you have? See above.
Just as what Kate said that gmake3.81 instead of gmake3.80 is necessary for the present version on IBM AIX. I am very lucky to get the gmake3.81 from Kate couple years ago and put it in my home directory. Everything goes pretty well.
People,
I checked it. My version is:
GNU Make 3.80
PARTICULAR PURPOSE.
Nevertheless the problem persists:
/afs/posseidon.dern.ufes.br/usr/angelolemos/src# gmake makefile
Somebody have any ideia?
GNU Make 3.80
PARTICULAR PURPOSE.
I have:
This is newer than yours - you need to get this version too.
I wish most problems were this easy to fix.
GNU Make 3.81
Copyright (C) 2006 Free Software Foundation, Inc.
- m.hadfield
Can anyone suggest how I might obtain Gnu make 3.81 or 3.82 for AIX?feroda wrote:Just as what Kate said that gmake3.81 instead of gmake3.80 is necessary for the present version on IBM AIX. I am very lucky to get the gmake3.81 from Kate couple years ago and put it in my home directory. Everything goes pretty well.
$ uname -a
AIX f2n7 3 5 00CD7D244C00
Do you have a binary, Kate?
Stolen straight from an NCAR IBM, the only one I have access to these days. See attached (just rename it back to gmake).
gmake.txt
- gmake for IBM
- (391.87 KiB) Downloaded 556 times
- m.hadfield
Thanks. Works a treat!kate wrote:Stolen straight from an NCAR IBM, the only one I have access to these days. See attached (just rename it back to gmake).
