Ran into an issue:IEEE_INVALID_FLAG, IEEE_DIVIDE_BY_ZERO
tao
#1 Unread post by tao »
Hello everyone,
I’m encountering a confusing error. I initially built an inaccurate model, so I replaced the original grid, ini file, obc file, and tide file. However, I encountered the following error right at the first step of running the model:
Note: The following floating-point exceptions are signalling: IEEE_INVALID_FLAG, IEEE_DIVIDE_BY_ZERO
To address this issue, I have tried the following:
Checked each input file carefully and found no NaN values
Reduced DT to 50/10
Increased NDTFAST to 40
Set all boundaries to clo
Removed the tide and station sections from the .h file and recompiled
Unfortunately, none of these attempts resolved the problem.
I’m attaching my run log, .in file, and .h file below. I would really appreciate any suggestions you might have. :D
Apologies if my English is not very good, and I hope I haven’t caused any offense.
log.txt
(60.27 KiB) Downloaded 377 times
Re: Ran into an issue:IEEE_INVALID_FLAG, IEEE_DIVIDE_BY_ZERO
#2 Unread post by wilkin »
Estimated maximum CFL values U∆t/∆x for u,v,w velocity are reported in the log as Cu,Cv,Cw. At the start of your run,
Cv = NaN so you have v velocity values that are NaN (in your initial conditions) which via continuity equation make w also NaN. You
cannot have NaN values in initial (or boundary) conditions, even in the land. ROMS computes on the land values and
then masks them out by multiplying by zero, but NaN times zero is NaN. You need to ensure there are no NaN in the
initial conditions.
         0 2022-01-01 00:00:00.00           NaN           NaN           NaN           NaN
                     (350,067,35)  1.582168E-02  2.485128E-02  0.000000E+00  1.742121E+00
 Found Error: 01   Line: 321      Source: ROMS/Nonlinear/main3d.F
 Found Error: 01   Line: 298      Source: ROMS/Drivers/nl_roms.h, ROMS_run
tao
#3 Unread post by tao »
wilkin wrote: Wed May 28, 2025 2:22 pm Estimated maximum CFL values U∆t/∆x for u,v,w velocity are reported in the log as Cu,Cv,Cw. At the start of your run,
initial conditions.
Dear Mr. Wilkin,
Thank you very much for your kind response. Unfortunately, I had already verified this issue earlier. I used the following MATLAB script to check all of my NetCDF files, and the results showed that there are no NaN values in them. I believe the error must be caused by something else, but I have no clue what it might be.
Thank you again for your help. :D
find_nan.m
(707 Bytes) Downloaded 371 times
#4 Unread post by arango »
Check your bathymetry. It cannot be zero, since the governing equations involve division by it. There is an issue with your configuration or grid.
#5 Unread post by wilkin »
I agree with Hernan that there might be a problem with your grid. The TOTAL VOLUME is reported as NaN at initialization, so there must be a cell where ∆x*∆y*(h+zeta) is NaN. You have WET_DRY defined, so this should have taken care of any h=0, and min(∆z) on water points is > 0.
But do you really want WET_DRY in a grid with ~7 km resolution? If not, you might save yourself a lot of trouble by setting h = some constant (positive) value in the land mask, and #undef WET_DRY.
Your XI and ETA grid spacings vary very little, suggesting the grid is almost rectangular, and DNDX is very small. But the min DMDE is very large at -4.
 GET_GRID_NF90    - reciprocal XI-grid spacing: pm
                      (Grid = 01, File: scs_2022_grid.nc)
                      (Min =  1.15250738E-04 Max =  1.30760506E-04)
  GET_GRID_NF90    - reciprocal ETA-grid spacing: pn
                      (Min =  1.08936005E-04 Max =  1.40130211E-04)
  GET_GRID_NF90    - XI-derivative of inverse metric factor pn: dndx
                      (Min = -9.47014087E-07 Max =  9.29923772E-07)
  GET_GRID_NF90    - ETA-derivative of inverse metric factor pm: dmde
                      (Min = -4.58576771E+00 Max =  0.00000000E+00)
I notice you have some boundary condition temperatures and salinity = 0, so you might check that also.
tao
#6 Unread post by tao »
Thank you both very much for your kind help. I checked the grid file and, as expected, found the presence of zeros. I will proceed to modify the file. Thanks again! :D
tao
#7 Unread post by tao »
Sadly, I tried modifying my grid file and the h file today, and also made corresponding changes to other related files. However, the error still hasn't gone away. That said, I believe the cause of the error lies within the grid. This is my grid file—hopefully the issue can be identified.
#8 Unread post by wilkin »
I suggest you try setting h = 10 where mask_rho = 0 and #undef WET_DRY. You have very small (10^-4) values of h in the land that might cause trouble.
I notice that your land/sea mask is such that the Malaysia Peninsula connects to the southern boundary. The Singapore Strait is closed.
tao
#9 Unread post by tao »
wilkin wrote: Fri May 30, 2025 3:23 pm I suggest you try setting h = 10 where mask_rho = 0 and #undef WET_DRY. You have very small (10^-4) values of h in the land that might cause trouble.
Thank you very much, Mr. Wilkin. After following your suggestions, the model started running properly. I would also like to thank Mr. arango who pointed out the issue. I truly appreciate your kind help and valuable advice. Wishing you a happy Dragon Boat Festival! :D
tao
#10 Unread post by tao »
My model has encountered a new problem—it blew up after running for over nine months.
(273,054,35) 1.360096E-02 1.134846E-02 1.208489E-01 3.810625E+00
493932 2022-10-13 20:10:00.00 2.261205E-02 1.616870E+04 1.616872E+04 1.026477E+16
(274,054,31) 1.138465E-02 1.370948E-02 1.102423E-01 3.910384E+00
493933 2022-10-13 20:10:50.00 2.262155E-02 1.616871E+04 1.616873E+04 1.026477E+16
(272,054,25) 1.419255E-02 1.498117E-02 1.830570E-01 4.117852E+01
Found Error: 1 Line: 361 Source: ROMS/Nonlinear/main3d.F
Found Error: 1 Line: 312 Source: ROMS/Drivers/nl_roms.h, ROMS_run
REASON: MaxSpeed = 4.1E+01
WRT_RST_NF90 - writing re-start fields (Index=2,2) in record = 286
In fact, this had happened before, which led me to change the time step (DT) from 150 to 50 to prevent the model from crashing right at the beginning.
Now I’m wondering whether I should further reduce the DT value or if I should modify my input files instead.
tao
#11 Unread post by tao »
I hope to perform a hot start from a certain point before the model crash, but this brings up several questions.
In my restart file, I noticed there are multiple ocean_time entries, and each ocean_time appears to contain two sets of data. Does this mean I can restart the model directly from a single ocean_time?
Also, I want the model to generate his and avg files with the same output frequency as before. Do I need to reset parameters such as NDEFHIS, NDEFAVG, etc., to ensure consistency?
