I'm trying to run the ROMS-WRF coupled model, but the data seems to be not exchanged by MCT. In my simulation log, it said:"
## ROMS grid 1 recv data from WRF grid 1
WRFtoROMS Min/Max GSW (Wm-2): 0.000000E+00 0.000000E+00
WRFtoROMS Min/Max GLW (Wm-2): 0.000000E+00 0.000000E+00
WRFtoROMS Min/Max LH (Wm-2): 0.000000E+00 0.000000E+00
WRFtoROMS Min/Max HFX (Wm-2): 0.000000E+00 0.000000E+00
WRFtoROMS Min/Max USTRESS (Nm-2): 0.000000E+00 0.000000E+00
WRFtoROMS Min/Max VSTRESS (Nm-2): 0.000000E+00 0.000000E+00
## ROMS grid 1 sent data to WRF grid 1
ROMStoWRF Min/Max SST (K): 0.000000E+00 0.000000E+00"
I tried to add a line in mct_roms_wrf.h in front of "CALL AttrVect_importRAttr (AttrVect_G(ng)%ocn2atm_AV, "SST", A, Asize)", so that it print out A(ij) before passing to the MCT. It showed that the A(ij) has the actual value instead of 0. But apparently it was not received by the WRF.
Anyone has any idea what was going on? Thank you!
FYI: ROMS/TOMS version 3.9, and I have attached cpp options, coawst.bash, and compile log file.
Bests,
Jiahua
Data not exchanged by MCT for ROMS-WRF coupling
gulfstr.h
- (5.63 KiB) Downloaded 285 times
coawst_build.bash
- (21.08 KiB) Downloaded 293 times
log.txt
- (1.86 MiB) Downloaded 291 times
Re: Data not exchanged by MCT for ROMS-WRF coupling
this really should be posted on the coawst forum here:
https://github.com/DOI-USGS/COAWST/issues
please post it there with the full output.
thanks
thanks
