I am trying to simulate Indian Ocean region using ROMS-2.2. I would like to know how can I distribute the river discharge over some grid points. I am using matlab code to force my model with rivers. Presently I am including 11 rivers in my model. Since the discharge is not spreading, the fresh water is constrained to one point in my salinity pattern. How can I spread it?
All suggestions are welcome.
Thanks in advance.
With regards,
G.NageswaraRao.
horizontal distribution of river discharge
spreading the river flow
u can put some velocity activating the uv-psource.
I had already switched on that option. River discharge was not distributing over the domain so that I am not getting climatological pattern of salinity good. Near river source the salinity is low and it is not distributing over the domain to some points. I am using salinity surfaces for horizontal mixing and Third-order upstream bias advection scheme for momentum and tracers. How can I distribute the river discharge over some points in the domain ?
Thanks in advance.
Thanks in advance.
river spread
is it the strong mixing is the cause?!!
The problem basically is when I am putting a river as a point source defined with ANA_Psource, TS_Psource and UV_psource. while integrating salinity field is not spreading out but stays where it is. I tried switching on ana_smflux and also prescribed wind-stress assimilation the salinity does not spread out as is seen in nature.
I am using the east china sea as my domain and the mixing is LMD_mixing process.
can anybody forward some suggestion!!! thanks in advance.
