River forcing in nested grids
Renato_Cecilio
#1 Unread post by Renato_Cecilio »
Hello all!
I was trying to implement a river forcing in the 3rd level only of a nested grid system.
An error occurred and the inspection with "debug=on" compilation showed a problem with dimensions of "SOURCES" in the file mod_sources.F.
So I changed it to:
157! IF (ng.eq.1) THEN
158! DO mg=1,Ngrids
159 mg=ng
176! END DO
177! END IF
189! IF (ng.eq.1) allocate ( SOURCES(Ngrids) )
190!
191 IF (.not.allocated(SOURCES)) THEN
192 allocate ( SOURCES(Ngrids) )
193 END IF
It is now working. No other change was made.
However: What did I do wrong? ( I wasn't supposed to change the code!)
Thanks.
