Is it because the Vwind speed is too high?But in fact, there seemed to be a higher speed before, but it ran smoothly.
By the way, the time step is 60s. Model reselution is about 8km.
Here is the output before it blowed up:
1667880 2007-03-04 06:00:00.00 1.538431E-02 2.705588E+02 2.705742E+02 1.765453E+13
(104,095,32) 5.740918E-04 1.071267E-03 1.655787E-01 9.994749E-01
1667890 2007-03-04 06:10:00.00 1.546097E-02 2.704776E+02 2.704931E+02 1.765144E+13
(104,095,32) 4.842636E-04 1.076456E-03 1.607030E-01 1.002374E+00
1667900 2007-03-04 06:20:00.00 1.557903E-02 2.703980E+02 2.704136E+02 1.764826E+13
(063,117,30) 4.022391E-04 2.680786E-03 1.561503E-01 1.003446E+00
1667910 2007-03-04 06:30:00.00 1.572910E-02 2.703206E+02 2.703363E+02 1.764501E+13
(063,117,30) 3.782827E-04 2.698790E-03 1.563011E-01 1.003125E+00
1667920 2007-03-04 06:40:00.00 1.590136E-02 2.702458E+02 2.702617E+02 1.764172E+13
(063,117,30) 3.561241E-04 2.717476E-03 1.566878E-01 1.001529E+00
1667930 2007-03-04 06:50:00.00 1.608707E-02 2.701742E+02 2.701903E+02 1.763841E+13
(063,117,30) 3.375654E-04 2.735594E-03 1.573522E-01 9.987905E-01
GET_2DFLD_NF90 - surface u-wind component, 2007-03-04 08:00:00.00
(Grid=01, Rec=1497, Index=2, File: BYECS_HINDCAST_bulk_wind_hourly_2007_CFSR.nc)
(Tmin= 1096.0000 Tmax= 1460.9583) t = 1158.3333
(Min = -1.37525229E+01 Max = 1.46642400E+01) regrid = T
GET_2DFLD_NF90 - surface v-wind component, 2007-03-04 08:00:00.00
(Min = -2.21711187E+01 Max = 2.04555164E+01) regrid = T
GET_2DFLD_NF90 - surface air pressure, 2007-03-04 08:00:00.00
(Grid=01, Rec=1497, Index=2, File: BYECS_HINDCAST_bulk_surface_air_hourly_2007_CFSR.nc)
(Min = 9.90562060E+02 Max = 1.01734676E+03) regrid = T
GET_2DFLD_NF90 - solar shortwave radiation flux, 2007-03-04 08:00:00.00
(Grid=01, Rec=1497, Index=2, File: BYECS_HINDCAST_bulk_flux_hourly_2007_CFSR.nc)
(Min = 2.51117417E-06 Max = 6.22807026E-05) regrid = T
GET_2DFLD_NF90 - net longwave radiation flux, 2007-03-04 08:00:00.00
(Min = 6.90479480E-05 Max = 9.74249733E-05) regrid = T
GET_2DFLD_NF90 - surface air temperature, 2007-03-04 08:00:00.00
(Min = -5.02027887E+00 Max = 1.77817922E+01) regrid = T
GET_2DFLD_NF90 - surface air relative humidity, 2007-03-04 08:00:00.00
(Min = 7.61973396E-01 Max = 9.86484414E-01) regrid = T
GET_2DFLD_NF90 - rain fall rate, 2007-03-04 08:00:00.00
(Min = 1.33951269E-06 Max = 2.79875110E-03) regrid = T
GET_2DFLD_NF90 - sea surface temperature climatology, 2007-03-04 08:00:00.00
(Grid=01, Rec=1497, Index=2, File: BYECS_HINDCAST_frc_sst_hourly_2007_CFSR.nc)
(Min = -4.48853350E+00 Max = 1.56885500E+01) regrid = F
GET_2DFLD_NF90 - surface net heat flux sensitivity to SST, 2007-03-04 08:00:00.00
(Min = -1.82112137E-05 Max = -2.64627197E-06) regrid = F
1667940 2007-03-04 07:00:00.00 1.627521E-02 2.701063E+02 2.701226E+02 1.763511E+13
(063,117,30) 3.238365E-04 2.752176E-03 1.582398E-01 9.947457E-01
1667950 2007-03-04 07:10:00.00 1.646089E-02 2.700424E+02 2.700589E+02 1.763183E+13
(063,117,29) 3.044345E-04 2.635372E-03 1.611834E-01 9.909538E-01
1667960 2007-03-04 07:20:00.00 1.663722E-02 2.699829E+02 2.699995E+02 1.762860E+13
(063,117,29) 3.471054E-04 2.666293E-03 1.672286E-01 9.874487E-01
1667970 2007-03-04 07:30:00.00 NaN NaN NaN NaN
(000,000,00) 0.000000E+00 0.000000E+00 0.000000E+00 NaN
Found Error: 01 Line: 321 Source: ROMS/Nonlinear/main3d.F
Found Error: 01 Line: 297 Source: ROMS/Drivers/nl_roms.h, ROMS_run
REASON: KEchar = NaN, PEchar = NaN
WRT_RST_NF90 - wrote re-start fields (Index=1,1) in record = 3
Looking forward to your answer!
