ROMS in MACmini Aple Chip M1
claudio_ccpo
Location: Center for Coastal Physical Oceanography at Old D
#1 Unread post by claudio_ccpo »
After letting a Mac Mini (arm, M1 SONOMA VER 14.6) collect dust on my desk for about two years, I decided to try installing ROMS using a YouTube tutorial. Basically, I started by installing Brew and then ran `brew install gcc netcdf-fortran open-mpi`. I also needed to modify a specific section of the Darwin-gfortran.mk file ...
(*tutorial https://www.youtube.com/watch?v=DCg0u015qek&t=437s)
NF_CONFIG ?= nf-config
NETCDF_INCDIR ?= $(shell $(NF_CONFIG) --includedir)
LIBS += -L/opt/homebrew/Cellar/netcdf-fortran/4.6.1/lib -lnetcdff
INCDIR += $(NETCDF_INCDIR) $(INCDIR)
after that, I run the ./build_roms.sh -j
Clearly, as you can see from the following code-lines, the romS files was not created, I will appreciate any help with this problem
ld: library not found for -ld_classic
make: *** [/Users/cl/Downloads/roms_projects/upwelling/romsM] Error 1
GNU Build script command: build_roms.sh -j
ROMS source directory: /Users/cl/Downloads/roms
ROMS header file: /Users/cl/Downloads/roms_projects/upwelling/upwelling.h
ROMS build directory: /Users/cl/Downloads/roms_projects/upwelling/Build_romsM
ROMS Application: UPWELLING
grep: ./ROMS/Version: No such file or directory
Fortran compiler: gfortran
Fortran flags: -frepack-arrays -fallow-argument-mismatch -O3
Thanks to all!
build_roms.sh
(15.15 KiB) Downloaded 874 times
robertson
Re: ROMS in MACmini Aple Chip M1
#2 Unread post by robertson »
Check that you have the latest non-beta Xcode and command line tools installed.
