About the causes of high temperature rise
bokyung_kim
#1 Unread post by bokyung_kim »
Dear ROMS Community,
When I constructed the initial and lateral boundary conditions for the model, HYCOM data were interpolated (hot start).
However, the surface temperature of the model was more than 4 degrees Celsius higher than HYCOM after only 5 days of simulation.
I tried turning off all the forcing files (Qair, Pair, Tair, winds, etc.) to find out why the surface temperature was increasing (I actually turned off bulk_fluxes, solar_source, etc. in the .h file), but the surface temperature still increased regardless of the forcing files.
I also simulated setting all initial temperatures to 16 degrees Celsius or 8 degrees Celsius, but this also generated high temperatures that did not come out of the boundary.
All lateral boundary conditions were well interpolated and applied as seen in the vertical profiles (boundary condition type: Clamped).
I have uploaded the input file (roms_ccs.in) andt the header file (ccs.h) I used.
Can someone please tell me why I am getting high temperature even though it is not applied to the boundary and what I should do to fix it?
Best regards,
Bo-Kyung Kim.
** svn $Id: scb.h 1099 2022-01-06 21:01:01Z arango $
** Copyright (c) 2002-2022 The ROMS/TOMS Group                               **
**   Licensed under a MIT/X style license                                    **
**   See License_ROMS.txt                                                    **
** Options for Southern California Bight.
** Application flag:   CCS
** Input script:       roms_ccs.in
#undef  AFT_EIGENMODES          /* Adjoint Finite Time Eigenmodes */
#undef  CORRELATION             /* Background-error Correlation Check */
#undef  FORCING_SV              /* Forcing Singular Vectors */
#undef  FT_EIGENMODES           /* Finite Time Eigenmodes */
#undef  I4DVAR                  /* Incremental, strong constraint 4D-Var */
#define NLM_DRIVER              /* Nonlinear Basic State trajectory */
#undef  OPT_PERTURBATION        /* Optimal perturbations */
#undef  PICARD_TEST             /* Picard Iterations Test */
#undef  RBL4DVAR                /* Strong/Weak constraint RBL4D-Var */
#undef  R4DVAR                  /* Strong/Weak constraint R4D-Var */
#undef  R_SYMMETRY              /* Representer Matrix Symmetry Test */
#undef  SANITY_CHECK            /* Sanity Check */
#undef  SO_SEMI                 /* Stochastic Optimals: Semi-norm */
#undef  TLM_CHECK               /* Tangent Linear Model Check */
**  Nonlinear basic state tracjectory.
#if defined NLM_DRIVER
# define UV_U3ADV_SPLIT
# define UV_COR
# define UV_LDRAG
# define UV_VIS2
# define MIX_S_UV
# undef SPLINES_VDIFF
# undef SPLINES_VVISC
# define DJ_GRADPS
# define TS_U3HADVECTION
# define TS_C4VADVECTION
# undef  TS_U3ADV_SPLIT
# define TS_DIF2
# define MIX_S_TS
# undef  MIX_GEO_TS
# define SALINITY
# define NONLIN_EOS
# define CURVGRID
# define MASKING
# define SOLVE3D
# define AVERAGES
# define AVERAGES_QUADRATIC
# define DIAGNOSTICS_UV
# define DIAGNOSTICS_TS
# define LMD_MIXING
# undef  MY25_MIXING
# ifdef LMD_MIXING
#  undef  SOLAR_SOURCE
#  define LMD_RIMIX
#  define LMD_CONVEC
#  undef  LMD_NONLOCAL
#  undef  LMD_SKPP
#  define RI_SPLINES
# define ANA_BSFLUX
# define ANA_BTFLUX
# define ANA_SMFLUX
# define ANA_STFLUX
# define ANA_SSFLUX
# undef  ANA_RAIN
# undef  FORWARD_MIXING
# undef  FORWARD_READ
# undef  FORWARD_WRITE
# define OUT_DOUBLE
# undef  BULK_FLUXES
# undef  LONGWAVE_OUT
# include "globaldefs.h"
#else
**  Adjoint-based drivers.
# define UV_ADV
# define UV_COR
# define UV_LDRAG
# define UV_VIS2
# define MIX_S_UV
# define SPLINES_VDIFF
# define SPLINES_VVISC
# define DJ_GRADPS
# define TS_DIF2
# define MIX_S_TS
# undef  MIX_GEO_TS
# define SALINITY
# define NONLIN_EOS
# define CURVGRID
# define MASKING
# define SOLVE3D
# define LMD_MIXING
# ifdef LMD_MIXING
#  define SOLAR_SOURCE
#  define LMD_RIMIX
#  define LMD_CONVEC
#  define LMD_NONLOCAL
#  define LMD_SKPP
#  define RI_SPLINES
# define ANA_BSFLUX
# define ANA_BTFLUX
# if defined RBL4DVAR || defined R4DVAR
#  define CONVOLVE
# define VCONVOLUTION
# define IMPLICIT_VCONV
# undef  FULL_GRID
# define OUT_DOUBLE
ini_ccs_BBE_41layers_at_210101_newgrid_240726_v2.nc
(151.11 MiB) Downloaded 808 times
roms_CCS_grid_ver4_240726_41layers_smoothing_depth_v2.nc
(17.37 MiB) Downloaded 778 times
roms_ccs.in
(159.81 KiB) Downloaded 726 times
ccs.h
(3.58 KiB) Downloaded 722 times
