How to adjust the high temperature near shore
As soon as my model hits the near shore area, the temperature will be more than 2 degrees Celsius higher than the satellite observation, may I ask what parameters are adjusted to be effective for the high temperature near the shore? I have tried to change the mixing scheme, change the type of water body and adjust the size of the vertical diffusion coefficient, but there is no obvious effect.
