Problem with record history file in Ice model
lfelipefm
#1 Unread post by lfelipefm »
Good afternoon, gentlemen.
I am running a simulation with a grid for King George Island, in which I initially ran only with oceanic data from GLORYS and forcings from ERA5. However, when I added the ice module I got a fortran error which I have not been able to solve for days.
This error occurs:
0 2021-01-01 00:00:00.00 4.808256E-03 9.786249E+03 9.786253E+03 3.248832E+13
(63,67,20) 1.962810E-02 1.346390E-02 0.000000E+00 4.006424E-01
DEF_HIS - creating history file, Grid 01: Projects/ATMOS/atmos_his.nc
At line 399 of file lbc.f90
Fortran runtime error: Positive integer required in format
(a,':',t**,a,a,a,a)
I noticed that when I put a very large number to save the history file in NHIS == 1000000, that this number exceeds the simulation time the error does not appear the simulation runs normally.
However, if I set a timestep within the simulation period, the model crashes. Has anyone seen this error?
What I find strange is that if I run the same simulation without the Ice module, it runs normally.
I tried to adjust the lbc.f90 file on the line in question but to no avail.
output_running.txt
(47.76 KiB) Downloaded 129 times
ocean_antartic.in
(146.16 KiB) Downloaded 115 times
ice_antartic.in
(6.7 KiB) Downloaded 130 times
Re: Problem with record history file in Ice model
It is far better to post here than in a PM. Please don't send me PMs asking about ROMS. I am no longer using ROMS and I'm certainly not up to date on the ROMS ice. I don't even know - is Hernan's new ice now available in COAWST and is that what you are using?
#3 Unread post by wilkin »
This is a COAWST specific problem, so you should pose your questions to that group.
That said, it looks like you are running an old version (you still have varinfo.dat, not varinfo.yaml) so it might be time to update in case you are encountering a solved problem.
The myroms.org repository has an ice module based on the same code in COAWST but updated. See https://www.myroms.org/projects/src/ticket/963.
Please consider running this newer code.
lfelipefm
#4 Unread post by lfelipefm »
Dear Kate, I apologize for the inconvenience. As this is an old code, I thought you might have had a similar problem. I didn't want to cause you any inconvenience.
I'll keep my questions here.
Wilkin, thank you for your message. I'll be focusing my efforts on this code this week. I ran the code coupled (WRF+ROMS) successfully before, but now, I want to force it with ERA5 on roms and I'm really having problems.
I'll test with a newer version. If it works we have a version problem.
Thank you for your support and I will come back to this topic soon to inform you.
Translated with DeepL.com (free version)
