Dear All,
I'm trying to run ROMs by forcing with wrf output
It was blowing up after running for four hours.
I've already posted this question in the COAWST forum. Because it's related to ROMS error, I'm reposting it here again.
The error:
Diag Speed Trouble
(001,068,01) 3.272224E-03 1.006189E-01 1.642780E-01 2.868435E+01
DIAG speed trouble 28.6843469722120
WRT_RST - wrote re-start fields (Index=1,1) in record = 0000003 01
WRT_RST - wrote re-start fields (Index=1,1) in record = 0000003 02
Node # 0 CPU: 11081.486
Total: 11081.486
Allocation and array initialization .............. 0.153 ( 0.0014 %)
Ocean state initialization ....................... 0.104 ( 0.0009 %)
Reading of input data ............................ 0.185 ( 0.0017 %)
Processing of input data ......................... 0.057 ( 0.0005 %)
Processing of output time averaged data .......... 0.282 ( 0.0025 %)
Computation of vertical boundary conditions ...... 0.229 ( 0.0021 %)
Computation of global information integrals ...... 1.752 ( 0.0158 %)
Writing of output data ........................... 1.597 ( 0.0144 %)
Model 2D kernel .................................. 46.138 ( 0.4164 %)
2D/3D coupling, vertical metrics ................. 1.167 ( 0.0105 %)
Omega vertical velocity .......................... 1.041 ( 0.0094 %)
Equation of state for seawater ................... 2.417 ( 0.0218 %)
Atmosphere-Ocean bulk flux parameterization ...... 0.129 ( 0.0012 %)
GLS vertical mixing parameterization ............. 47.199 ( 0.4259 %)
3D equations right-side terms .................... 4.797 ( 0.0433 %)
3D equations predictor step ...................... 7.606 ( 0.0686 %)
Pressure gradient ................................ 3.755 ( 0.0339 %)
Harmonic mixing of tracers, geopotentials ........ 4.109 ( 0.0371 %)
Harmonic stress tensor, S-surfaces ............... 2.608 ( 0.0235 %)
Corrector time-step for 3D momentum .............. 4.280 ( 0.0386 %)
Corrector time-step for tracers .................. 4.472 ( 0.0404 %)
Total: 134.078 1.2099
Message Passage: 2D halo exchanges ............... 0.384 ( 0.0035 %)
Message Passage: 3D halo exchanges ............... 0.036 ( 0.0003 %)
Message Passage: 4D halo exchanges ............... 0.014 ( 0.0001 %)
Message Passage: data broadcast .................. 0.013 ( 0.0001 %)
Message Passage: data reduction .................. 0.018 ( 0.0002 %)
Message Passage: data gathering .................. 0.191 ( 0.0017 %)
Message Passage: data scattering.................. 0.006 ( 0.0001 %)
Message Passage: boundary data gathering ......... 10276.047 (92.7317 %)
Message Passage: point data gathering ............ 6.168 ( 0.0557 %)
Total: 10282.878 92.7933
All percentages are with respect to total time = 11081.486
Nonlinear ocean model elapsed time profile, Grid: 02
Ocean state initialization ....................... 0.100 ( 0.0009 %)
Reading of input data ............................ 0.004 ( 0.0000 %)
Processing of input data ......................... 0.086 ( 0.0008 %)
Processing of output time averaged data .......... 0.926 ( 0.0084 %)
Computation of vertical boundary conditions ...... 0.772 ( 0.0070 %)
Computation of global information integrals ...... 6.748 ( 0.0609 %)
Writing of output data ........................... 3.185 ( 0.0287 %)
Model 2D kernel .................................. 203.097 ( 1.8328 %)
2D/3D coupling, vertical metrics ................. 3.295 ( 0.0297 %)
Omega vertical velocity .......................... 3.152 ( 0.0284 %)
Equation of state for seawater ................... 9.332 ( 0.0842 %)
Atmosphere-Ocean bulk flux parameterization ...... 0.359 ( 0.0032 %)
GLS vertical mixing parameterization ............. 188.940 ( 1.7050 %)
3D equations right-side terms .................... 19.003 ( 0.1715 %)
3D equations predictor step ...................... 29.087 ( 0.2625 %)
Pressure gradient ................................ 14.677 ( 0.1324 %)
Harmonic mixing of tracers, geopotentials ........ 18.980 ( 0.1713 %)
Harmonic stress tensor, S-surfaces ............... 10.593 ( 0.0956 %)
Corrector time-step for 3D momentum .............. 16.305 ( 0.1471 %)
Corrector time-step for tracers .................. 17.423 ( 0.1572 %)
Total: 546.216 4.9291
Nonlinear model message Passage profile, Grid: 02
Message Passage: 2D halo exchanges ............... 1.041 ( 0.0094 %)
Message Passage: 3D halo exchanges ............... 0.068 ( 0.0006 %)
Message Passage: 4D halo exchanges ............... 0.025 ( 0.0002 %)
Message Passage: data broadcast .................. 0.008 ( 0.0001 %)
Message Passage: data reduction .................. 0.031 ( 0.0003 %)
Message Passage: data gathering .................. 9.487 ( 0.0856 %)
Message Passage: data scattering.................. 0.010 ( 0.0001 %)
Message Passage: boundary data gathering ......... 0.353 ( 0.0032 %)
Message Passage: point data gathering ............ 3.295 ( 0.0297 %)
Total: 14.319 0.1292
All percentages are with respect to total time = 11081.488
number of time records written in HISTORY file = 00000010
number of time records written in RESTART file = 00000010
number of time records written in AVERAGE file = 00000001
ROMS/TOMS - Output NetCDF summary for Grid 02:
number of time records written in AVERAGE file = 00000003
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_stflux.h
blowing up: Diag Speed Trouble
- Sandy_ocean_rst.nc
- (34 MiB) Downloaded 1037 times
- Sandy_ocean_ref3_rst.nc
- (66.81 MiB) Downloaded 1090 times
coupling_sandy.in
- (8.04 KiB) Downloaded 1057 times
ocean_sandy.in
- (131.11 KiB) Downloaded 1100 times
sandy.h
- (1.96 KiB) Downloaded 960 times
build_test02.log.txt
- (893.97 KiB) Downloaded 953 times
