COAWST JOE_TC case compile error
When I tried the JOE_TC example, ./coawst.bash had the following problem
1. RUN - Inlet_test: ROMS+SWAN
parallel pass
2. RUN - JOE_TC: ROMS+WRF
parallel error
mct_coupler_params.f90(2): error #7002: Error in opening the compiled module file. Check INCLUDE paths. [MCT_WRF_COUPLER_PARAMS]
USE mct_wrf_coupler_params
compilation aborted for mct_coupler_params.f90 (code 1)
make: *** [Build/mct_coupler_params.o] Error 1
I think the problem comes from MCT, but ROMS+SWAN compile passed with this MCT. But I have defined MCT_INCDIR and MCT_LIBDIR in bashrc.
export MCT_INCDIR=/home/yxli20/mct/include
export MCT_LIBDIR=/home/yxli20/mct/lib
Please give me some advise!
parallel pass
parallel error
coawst.bash
- (17.6 KiB) Downloaded 1707 times
bashrc.txt
- (3.51 KiB) Downloaded 1685 times
build.log
- (843.68 KiB) Downloaded 1547 times
Re: COAWST JOE_TC case compile error
for coawst issues, specific to compiling or running multiple models together, it is best to post an issue here:
https://github.com/DOI-USGS/COAWST/issues
your issue is that you selected a compiler for openmp and mpi. (dm+sm)
For cowast, you can only use mpi.
if you have further issues please post a message on the site above.
I am using COAWST model (V3.
with ROMS and SWAN couple.
I tried to compile the RIP_CURRENT case and faced with this error. I had no problem compile with ROMS only.
I only get this error when I compile with SWAN only or ROMS & SWAN.
I am using ifort(intel18). Netcdf(4.6.1)
Total log file from compling is attached. I also attach the capture of error.
Please give me any comments regarding this issue.
build_ifort.log
- (29.76 KiB) Downloaded 1357 times
- error_swan.png (282.53 KiB) Viewed 60916 times
Joonho Lee
It looks like your header file mpif.h is either corrupted or located in the wrong path. It could be that it is, compiled with a different compiler/compiler options?
You also have an error in line 402 of your build_coawst.sh script, where you have to delete a space or an extra [.
Hello, I'm currently troubled by another issue.. When I run the Sandy example of COAWST, the compilation process completes, but I encountered the following error during execution. I'm not running it on a cluster; instead, I'm using my own computer with a WSL virtual machine running a Linux environment. How can I resolve this?jcwarner wrote: Fri Nov 24, 2023 2:15 pm for coawst issues, specific to compiling or running multiple models together, it is best to post an issue here:
Abort(537478405) on node 2 (rank 2 in comm 0): Fatal error in PMPI_Comm_rank: Invalid communicator, error stack:
PMPI_Comm_rank(107): MPI_Comm_rank(comm=0x0, rank=0x7ffe3af1d638) failed
PMPI_Comm_rank(64).: Invalid communicator
coawst.bash :
#!/bin/bash
# svn $Id: build.bash 429 2009-12-20 17:30:26Z jcwarner $
# Copyright (c) 2002-2017 The ROMS/TOMS Group :::
# Licensed under a MIT/X style license :::
# See License_ROMS.txt :::
#::::::::::::::::::::::::::::::::::::::::::::::::::::: Hernan G. Arango :::
#::::::::::::::::::::::::::::::::::::::::::::::::::::: John C. Warner :::
# ROMS/TOMS Compiling Script :::
# Modified to configure the COAWST Modeling System :::
# Script to identify locations of application-specific files for :::
# compiling the modeling sytem. :::
# Q: How/why does this script work? :::
# A: The ROMS makefile configures user-defined options with a set of :::
# flags such as ROMS_APPLICATION. Browse the makefile to see these. :::
# If an option in the makefile uses the syntax ?= in setting the :::
# default, this means that make will check whether an environment :::
# variable by that name is set in the shell that calls make. If so :::
# the environment variable value overrides the default (and the :::
# user need not maintain separate makefiles, or frequently edit :::
# the makefile, to run separate applications). :::
# Usage: :::
# ./build.bash [options] :::
# Options: :::
# -j [N] Compile in parallel using N CPUs :::
# omit argument for all available CPUs :::
# -noclean Do not clean already compiled roms objects :::
# -nocleanwrf Do not clean already compiled wrf objects :::
# Notice that sometimes the parallel compilation fail to find MPI :::
# include file "mpif.h". :::
parallel=0
clean=1
cleanwrf=1
while [ $# -gt 0 ]
do
case "$1" in
-j )
shift
parallel=1
test=`echo $1 | grep -P '^\d+$'`
if [ "$test" != "" ]; then
NCPUS="-j $1"
shift
else
NCPUS="-j"
fi
-noclean )
shift
clean=0
-nocleanwrf )
shift
cleanwrf=0
echo ""
echo "$0 : Unknown option [ $1 ]"
echo ""
echo "Available Options:"
echo ""
echo "-j [N] Compile in parallel using N CPUs"
echo " omit argument for all avaliable CPUs"
echo "-noclean Do not clean already compiled objects"
echo "-nocleanwrf Do not clean already compiled wrf objects"
echo ""
exit 1
esac
done
# Set the CPP option defining the particular application. This will
# determine the name of the ".h" header file with the application
# CPP definitions.
export COAWST_APPLICATION=sandy
# Set the ROMS_APPLICATION to be the same as the COAWST_APP. We use the COAWST
# APP for other checks.
export ROMS_APPLICATION=${COAWST_APPLICATION}
# Set a local environmental variable to define the path to the directories
# where all this project's files are kept.
export MY_ROOT_DIR=/mnt/d/coawst
export MY_PROJECT_DIR=${MY_ROOT_DIR}
# The path to the user's local current ROMS source code.
# If using svn locally, this would be the user's Working Copy Path (WCPATH).
# Note that one advantage of maintaining your source code locally with svn
# is that when working simultaneously on multiple machines (e.g. a local
# workstation, a local cluster and a remote supercomputer) you can checkout
# the latest release and always get an up-to-date customized source on each
# machine. This script is designed to more easily allow for differing paths
# to the code and inputs on differing machines.
export MY_ROMS_SRC=${MY_ROOT_DIR}/
# Set path of the directory containing makefile configuration (*.mk) files.
# The user has the option to specify a customized version of these files
# in a different directory than the one distributed with the source code,
# ${MY_ROMS_SRC}/Compilers. If this is the case, the you need to keep
# these configurations files up-to-date.
#export COMPILERS=${MY_ROMS_SRC}/Compilers
# Set tunable CPP options.
# Sometimes it is desirable to activate one or more CPP options to run
# different variants of the same application without modifying its header
# file. If this is the case, specify each options here using the -D syntax.
# Notice also that you need to use shell's quoting syntax to enclose the
# definition. Both single or double quotes work. For example,
#export MY_CPP_FLAGS="-DAVERAGES"
#export MY_CPP_FLAGS="${MY_CPP_FLAGS} -DDEBUGGING"
# can be used to write time-averaged fields. Notice that you can have as
# many definitions as you want by appending values.
#export MY_CPP_FLAGS="-D"
# Other user defined environmental variables. See the ROMS makefile for
# details on other options the user might want to set here. Be sure to
# leave the switches meant to be off set to an empty string or commented
# out. Any string value (including off) will evaluate to TRUE in
# conditional if-statements.
export USE_MPI=on # distributed-memory parallelism
export USE_MPIF90=on # compile with mpif90 script
#export which_MPI=mpich # compile with MPICH library
#export which_MPI=mpich2 # compile with MPICH2 library
export which_MPI=openmpi # compile with OpenMPI library
#export USE_OpenMP=on # shared-memory parallelism
export FORT=mpiifort
#export FORT=gfortran
#export FORT=pgi
export USE_DEBUG= # use Fortran debugging flags
export USE_LARGE= # activate 64-bit compilation
export USE_NETCDF4=on # compile with NetCDF-4 library
#export USE_PARALLEL_IO=on # Parallel I/O with Netcdf-4/HDF5
#export USE_MY_LIBS=on # use my library paths below
# There are several MPI libraries available. Here, we set the desired
# "mpif90" script to use during compilation. This only works if the make
# configuration file (say, Linux-pgi.mk) in the "Compilers" directory
# has the following definition for FC (Fortran Compiler) in the USE_MPI
# section:
# FC := mpif90
# that is, "mpif90" defined without any path. Notice that the path
# where the MPI library is installed is computer dependent. Recall
# that you still need to use the appropriate "mpirun" to execute.
if [ -n "${USE_MPIF90:+1}" ]; then
case "$FORT" in
mpiifort )
if [ "${which_MPI}" = "mpich" ]; then
export PATH=/opt/intelsoft/mpich/bin:$PATH
elif [ "${which_MPI}" = "mpich2" ]; then
export PATH=/opt/intelsoft/mpich2/bin:$PATH
elif [ "${which_MPI}" = "openmpi" ]; then
export PATH=$PATH:/home/yxli/intel/oneapi/mpi/2021.4.0/bin
fi
pgi )
export PATH=/opt/pgisoft/mpich/bin:$PATH
export PATH=/opt/pgisoft/mpich2/bin:$PATH
export PATH=/opt/pgisoft/openmpi/bin:$PATH
fi
gfortran )
export PATH=/opt/gfortransoft/mpich2/bin:$PATH
export PATH=/opt/gfortransoft/openmpi/bin:$PATH
fi
esac
fi
# If the USE_MY_LIBS is activated above, the path of the libraries
# required by ROMS can be set here using environmental variables
# which take precedence to the values specified in the make macro
# definitions file (Compilers/*.mk). For most applications, only
# the location of the NetCDF library is needed during compilation.
# Notice that when the USE_NETCDF4 macro is activated, we need the
# serial or parallel version of the NetCDF-4/HDF5 library. The
# configuration script NF_CONFIG (available since NetCDF 4.0.1)
# is used to set up all the required libraries according to the
# installed options (openDAP, netCDF4/HDF5 file format). The
# parallel library uses the MPI-I/O layer (usually available
# in MPICH2 and OpenMPI) requiring compiling with the selected
# MPI library.
# In ROMS distributed-memory applications, you may use either the
# parallel version is required when parallel I/O is activated
# (ROMS cpp option PARALLEL_IO and HDF5).
# However, in serial or shared-memory ROMS applications, we need
# to use the serial version of the NetCDF-4/HDF5 to avoid conflicts
# with the compiler. We cannot activate MPI constructs in serial
# or shared-memory ROMS code. Hybrid parallelism is not possible.
# Recall also that the MPI library comes in several flavors:
# MPICH, MPICH2, OpenMPI, etc.
if [ -n "${USE_MY_LIBS:+1}" ]; then
case "$FORT" in
mpiifort )
export ESMF_OS=Linux
export ESMF_COMPILER=mpiifort
export ESMF_BOPT=O
export ESMF_ABI=64
export ESMF_COMM=mpich
export ESMF_SITE=default
export ARPACK_LIBDIR=/opt/intelsoft/serial/ARPACK
if [ -n "${USE_MPI:+1}" ]; then
export ESMF_DIR=/opt/intelsoft/mpich/esmf
export MCT_INCDIR=/home/yxli/Build_COAWST/LIBRARIES/MCT/include
export MCT_LIBDIR=/home/yxli/Build_COAWST/LIBRARIES/MCT/lib
export PARPACK_LIBDIR=/opt/intelsoft/mpich/PARPACK
export ESMF_DIR=/opt/intelsoft/mpich2/esmf
export MCT_INCDIR=/opt/intelsoft/mpich2/mct/include
export MCT_LIBDIR=/opt/intelsoft/mpich2/mct/lib
export PARPACK_LIBDIR=/opt/intelsoft/mpich2/PARPACK
export ESMF_DIR=/opt/intelsoft/openmpi/esmf
#/opt/intelsoft/openmpi/mct/include
#/opt/intelsoft/openmpi/mct/lib
export PARPACK_LIBDIR=/opt/intelsoft/openmpi/PARPACK
fi
fi
if [ -n "${USE_NETCDF4:+1}" ]; then
if [ -n "${USE_PARALLEL_IO:+1}" ] && [ -n "${USE_MPI:+1}" ]; then
export NF_CONFIG=/opt/intelsoft/mpich/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/intelsoft/mpich/netcdf4/include
export NF_CONFIG=/opt/intelsoft/mpich2/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/intelsoft/mpich2/netcdf4/include
export NF_CONFIG=/home/yxli/Build_COAWST/LIBRARIES/netcdf/bin/nf-config
export NETCDF_INCDIR=/home/yxli/Build_COAWST/LIBRARIES/netcdf/include
fi
else
fi
else
export NETCDF_LIBDIR=/home/yxli/Build_COAWST/LIBRARIES/netcdf/lib
fi
pgi )
export ESMF_COMPILER=pgi
export ESMF_BOPT=O
export ESMF_ABI=64
export ARPACK_LIBDIR=/opt/pgisoft/serial/ARPACK
export ESMF_DIR=/opt/pgisoft/mpich/esmf
export MCT_INCDIR=/opt/pgisoft/mpich/mct/include
export MCT_LIBDIR=/opt/pgisoft/mpich/mct/lib
export PARPACK_LIBDIR=/opt/pgisoft/mpich/PARPACK
export ESMF_DIR=/opt/pgisoft/mpich2/esmf
export MCT_INCDIR=/opt/pgisoft/mpich2/mct/include
export MCT_LIBDIR=/opt/pgisoft/mpich2/mct/lib
export PARPACK_LIBDIR=/opt/pgisoft/mpich2/PARPACK
export ESMF_DIR=/opt/pgisoft/openmpi/esmf
export MCT_INCDIR=/opt/pgisoft/openmpi/mct/include
export MCT_LIBDIR=/opt/pgisoft/openmpi/mct/lib
export PARPACK_LIBDIR=/opt/pgisoft/openmpi/PARPACK
fi
fi
export NF_CONFIG=/opt/pgisoft/mpich/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/pgisoft/mpich/netcdf4/include
export NF_CONFIG=/opt/pgisoft/mpich2/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/pgisoft/mpich2/netcdf4/include
export NF_CONFIG=/opt/pgisoft/openmpi/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/pgisoft/openmpi/netcdf4/include
fi
else
export NF_CONFIG=/opt/pgisoft/serial/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/pgisoft/serial/netcdf4/include
fi
else
export NETCDF_INCDIR=/opt/pgisoft/serial/netcdf3/include
export NETCDF_LIBDIR=/opt/pgisoft/serial/netcdf3/lib
fi
gfortran )
export ESMF_COMPILER=gfortran
export ESMF_BOPT=O
export ESMF_ABI=64
export ARPACK_LIBDIR=/opt/gfortransoft/serial/ARPACK
export ESMF_DIR=/opt/gfortransoft/mpich2/esmf
export MCT_INCDIR=/opt/gfortransoft/mpich2/mct/include
export MCT_LIBDIR=/opt/gfortransoft/mpich2/mct/lib
export PARPACK_LIBDIR=/opt/gfortransoft/mpich2/PARPACK
export ESMF_DIR=/opt/gfortransoft/openmpi/esmf
export MCT_INCDIR=/opt/gfortransoft/openmpi/mct/include
export MCT_LIBDIR=/opt/gfortransoft/openmpi/mct/lib
export PARPACK_LIBDIR=/opt/gfortransoft/openmpi/PARPACK
fi
fi
export NF_CONFIG=/opt/gfortransoft/mpich2/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/gfortransoft/mpich2/netcdf4/include
export NF_CONFIG=/opt/gfortransoft/openmpi/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/gfortransoft/openmpi/netcdf4/include
fi
else
export NF_CONFIG=/opt/gfortransoft/serial/netcdf4/bin/nf-config
export NETCDF_INCDIR=/opt/gfortransoft/serial/netcdf4/include
fi
else
export NETCDF_INCDIR=/opt/gfortransoft/serial/netcdf3/include
export NETCDF_LIBDIR=/opt/gfortransoft/serial/netcdf3/lib
fi
esac
fi
# The rest of this script sets the path to the users header file and
# analytical source files, if any. See the templates in User/Functionals.
# If applicable, use the MY_ANALYTICAL_DIR directory to place your
# customized biology model header file (like fennel.h, nemuro.h, ecosim.h,
# etc).
# export MY_HEADER_DIR=${MY_PROJECT_DIR}/ROMS/Include
# export MY_ANALYTICAL_DIR=${MY_PROJECT_DIR}/ROMS/Functionals
export MY_HEADER_DIR=${MY_PROJECT_DIR}/Projects/Sandy
export MY_ANALYTICAL_DIR=${MY_PROJECT_DIR}/Projects/Sandy
# Put the binary to execute in the following directory.
# export BINDIR=${MY_PROJECT_DIR}
export BINDIR=./
# Put the f90 files in a project specific Build directory to avoid conflict
# with other projects.
# export SCRATCH_DIR=${MY_PROJECT_DIR}/Build
export SCRATCH_DIR=./Build
# Go to the users source directory to compile. The options set above will
# pick up the application-specific code from the appropriate place.
cd ${MY_ROMS_SRC}
# Remove build directory.
if [ $clean -eq 1 ]; then
make clean
fi
# Compile (the binary will go to BINDIR set above).
export WRF_DIR=${MY_ROMS_SRC}/WRF
if [ $cleanwrf -eq 1 ]; then
make wrfclean
cd ${MY_ROMS_SRC}
fi
make wrf
if [ $parallel -eq 1 ]; then
make $NCPUS
else
make
fi
it would be best to post this on the coawst issue site:
and include the full output, not just those last few lines.
The complete run.log is as follows:
run.log
- (30.1 KiB) Downloaded 1480 times
Thank you for the reminder. I have posted the same content on the website you provided.jcwarner wrote: Tue Mar 05, 2024 1:01 pm it would be best to post this on the coawst issue site:
run.log
- (30.1 KiB) Downloaded 1297 times
build.log
- (1012 KiB) Downloaded 1376 times
I have solved this problem, it should still be an issue with the mpi compiler selection.jcwarner wrote: Tue Mar 05, 2024 1:01 pm it would be best to post this on the coawst issue site:
