blowup when activating SED_MORPH
iwaking
#1 Unread post by iwaking »
I am trying to reproduce the migrating trench morphodynamic simulation as documented in Warner et al. 2008 in Computers & Geosciences. The hydrodynamics and sediment transport modules run well (with CPP flags SEDIMENT, SUSPLOAD, BEDLOAD_MPM activated).
However, when I further activated SED_MORPH, the model always blows up in the first time step and shows the following error:
"MAIN: Abnormal termination: BLOWUP.
REASON: MaxDensity = 1.0E+05"
Even when morph_fac is set to 0, this error still persists. The error will only disappear when initial bed thickness is set to 0, i.e. not any sediment in the simulation.
After some model tuning, I am still unable to get around this issue.
Your help would be much appreciated. The model input and run log files are attached below.
Thanks in advance,
Jay
log.txt
run log file
(27.96 KiB) Downloaded 509 times
sediment_trench.in
sediment input
(54.25 KiB) Downloaded 518 times
roms_trench.in
hydro input
(163.75 KiB) Downloaded 514 times
