Hi everyone, I'm Andrés Felipe, a physical oceanographer and recently star to work with ROMS.
Trying the installation have a problem:
When I write this command (cp ~/roms/trunk/ROMS/External/varinfo.dat.), My PC cannot find it from my truck (cp: cannot stat ‘/home/rbadpa/roms/trunk/ROMS/External/varinfo.dat’: No such file or directory), I searched for it and found varinfo.yaml (The source code downloaded of ROMS is giving other archive .yaml and not .dat). I tried changed .yaml for .dat and compiler but was wrong.
Somebody could please help me with it problem?
Thanks.
PROBLEM WITH THE INSTALLATIONS ROMS
Re: PROBLEM WITH THE INSTALLATIONS ROMS
In our version of ROMS, we no longer distribute the metadata file varinfo.dat but its equivalent YAML file varinfo.yaml.
Thanks, i undertood, but when i try compile with the .Yaml this is the error.
" Model Input Parameters: ROMS/TOMS version 4.2
Monday - July 10, 2023 - 9:26:11 AM
Found Error: 05 Line: 410 Source: ROMS/Utility/yaml_parser.F, yaml_tree_create
YAML_TREE_CREATE - Unable to open input YAML file: ~/roms_project/test/varinfo.yaml
ERROR: Cannot open file '~/roms_project/test/varinfo.yaml': No such file or directory
Found Error: 05 Line: 354 Source: ROMS/Utility/yaml_parser.F, yaml_initialize
Found Error: 05 Line: 892 Source: ROMS/Utility/get_metadata.F, io_metadata
IO_METADATA - Unable to create YAML object for ROMS I/O metadata file:
Default file is located in source directory.
Found Error: 05 Line: 1344 Source: ROMS/Modules/mod_ncparam.Finitialize_ncparam
Found Error: 05 Line: 3643 Source: ROMS/Utility/read_phypar.F
Found Error: 05 Line: 210 Source: ROMS/Utility/inp_par.F
Found Error: 05 Line: 125 Source: ROMS/Drivers/nl_roms.h, ROMS_initialize
ERROR STOP
Error termination. Backtrace:
#0 0x7f4325182ad0 in ???
#1 0x7f4325183649 in ???
#2 0x7f4325184cb7 in ???
#3 0x557b4a85ab0b in myroms"
Arango, could please help me, what is the problem?
ERROR STOP
It is telling you the problem! Please, read and understand the error that ROMS is giving you:
If you are using gfortran, you must spell out the full path because it does not support ~/
Do you have varinfo.yaml in you home directory ~/roms_project/test?YAML_TREE_CREATE - Unable to open input YAML file: ~/roms_project/test/varinfo.yaml
Dr. Arango thank so much.
I can install of model with your help.
Only change the directory because I'm using gfortran and search and remove the line mnbvc43.
Thanks for all.
Thanks for all.
