Model blows up before it starts
zhaolv
Location: Changsha University of Science and Technology
#1 Unread post by zhaolv »
I'm using roms for a month of simulations. But the model crashes just as it starts to run and I would like to know why this is. logs prompts me with:
Maximum grid stiffness ratios.
rx0 = 9.648683E-01 (Beckmann and Haidvogel)
rx1 = 8.844612E+00 (Haney)
Where did this go wrong? Is my simulation area too large or is it a data problem?
log.txt
(37.23 KiB) Downloaded 588 times
Re: Model blows up before it starts
the last line of your file says
"Could not read valid record axe from file"
i had to search for this one.
it is in SWAN, call agnc_set_error( 'Could not read valid record axe from file')
looks like you are trying to read a netcdf file.
I suggest you use SWAN by itself, try to run that application, and then move back to a coupled system.
If you keep having trouble then post an issue on the coawst site
