Hello everyone, I'm having trouble booting the roms using the forcing blk files generated by CROCO.
The image below describes the problem.
https://ibb.co/qN4cVZb
Can anyone tell me what is wrong with my file? Is there any other option for me to run the roms without the BULK FLUXES option turned on that gives consistent results?
I am attaching the files.
error while inquiring ID for variable: sms_time - ROMS Bullk forcing files
- Location: Instituto Nacional de Pesquisas Espaciais - INPE
ocean_william.in
- (155.23 KiB) Downloaded 706 times
- william_blk.nc
- (163 MiB) Downloaded 783 times
Re: error while inquiring ID for variable: sms_time - ROMS Bullk forcing files
If you are using the myroms.org code then the file varinfo.yaml sets the default names for time coordinate, sms_time, which is not in the file you made with croco tools.
The myroms code also allows over-riding the default name with a "time" attribute for each variable, but you don't have that either.
This file won't work with myroms.org or COAWST without modification to add the "time" attribute, or changes to varinfo.yaml.
See the template in Data/ROMS/CDL/frc_fluxclm.cdl
