I am running ROMS model on a 10km resolution domain with a 10 sec timestep
I observed that my free surface behaves weirdly like this at about 2 minutes and couldn't figure out why
I have low Rx0 (max 0.5) and Rx1 (only large in a few grid points, less than 5 for most points)
and the large Rx1 points are different from what's shown here.
This is what I get in my temperature after 30 mins, all of the points are along shallow water area
I think this is considered an "upwelling" current as cold bottom water rushes up and replaces the warm surface water and causing my free surface to go wild...
However this also produces unrealistic SSH values up to 12m and u v velocity up to 4 ms-1 ... I am not sure if this is considered normal in ROMS but this looks wrong to me
I tried plotting the bottom u v stresses and they corrsponds to my free surface as well...
Initially I thought this is due to my grid being too steep and I tried using some unrealistic bathy modificiations , then I found out the more shallow water I had ( due to the bathy modifications ) the worse it gets so I used the LP-smoothing in Pyroms instead to produce a smooth grid (although it does take overnight)
This current makes my model very unstable at the beginning and I have to use very small timesteps to avoid the vertical courant number being > than 1, it does go down eventually
Here is a log of my test run
Wednesday - September 8, 2021 - 10:16:09 AM
AAMC
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /work/intel/compilers_and_libraries_2018.5.274/linux/mpi/intel64/bin/mpiifort
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free
Input Script :
SVN Revision : Unversioned directory
Local Root : /avm/home/dev/COAWST/v3.2/COAWST-master
Header Dir : /avm/home/dev/COAWST/v3.2/COAWST-master/Projects/Hongkong
Header file : hongkong_roms.h
Analytical Dir: /avm/home/dev/COAWST/v3.2/COAWST-master/Projects/Hongkong
Resolution, Grid 01: 1248x1098x035, Parallel Nodes: 80, Tiling: 010x008
86400 ntimes Number of timesteps for 3-D equations.
10.000 dt Timestep size (s) for 3-D equations.
180 ndtfast Number of timesteps for 2-D equations between
F LcycleRST Switch to recycle time-records in restart file.
1440 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
10 nHIS Number of timesteps between the writing fields
into history file.
0 nQCK Number of timesteps between the writing fields
into quicksave file.
time-averaged data.
0 nAVG Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
0.0000E+00 rdrg Linear bottom drag coefficient (m/s).
0.0000E+00 Zob Bottom roughness (m).
1.0000E+01 blk_ZT Height (m) of surface air temperature measurement.
1 lmd_Jwt Jerlov water type.
59396.000 dstart Time-stamp assigned to model initialization (days).
18581117.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
9.0000E+01 Tnudg_SSS Nudging/relaxation time scale (days)
for sea surface salinity.
for 3D momentum.
Output Restart File: ocean_rst_2.nc
Input Grid File: Projects/Hongkong/roms_grid.nc
Input Nonlinear Initial File: Projects/Hongkong/roms_ini.nc
Input Forcing File 01: Projects/Hongkong/AAMC20210601-20210630/tide_aamc.nc
Input Forcing File 02: Projects/Hongkong/roms_forc.nc
Input Boundary File 01: Projects/Hongkong/roms_bdy.nc
Tile partition information for Grid 01: 1248x1098x0035 tiling: 010x008
tile Istr Iend Jstr Jend Npts
Number of tracers: 2
0 1 124 1 135 585900
1 125 249 1 135 590625
2 250 374 1 135 590625
3 375 499 1 135 590625
4 500 624 1 135 590625
5 625 749 1 135 590625
6 750 874 1 135 590625
7 875 999 1 135 590625
8 1000 1124 1 135 590625
9 1125 1248 1 135 585900
10 1 124 136 273 598920
11 125 249 136 273 603750
12 250 374 136 273 603750
13 375 499 136 273 603750
14 500 624 136 273 603750
15 625 749 136 273 603750
16 750 874 136 273 603750
17 875 999 136 273 603750
18 1000 1124 136 273 603750
19 1125 1248 136 273 598920
20 1 124 274 411 598920
21 125 249 274 411 603750
22 250 374 274 411 603750
23 375 499 274 411 603750
24 500 624 274 411 603750
25 625 749 274 411 603750
26 750 874 274 411 603750
27 875 999 274 411 603750
28 1000 1124 274 411 603750
29 1125 1248 274 411 598920
30 1 124 412 549 598920
31 125 249 412 549 603750
32 250 374 412 549 603750
33 375 499 412 549 603750
34 500 624 412 549 603750
35 625 749 412 549 603750
36 750 874 412 549 603750
37 875 999 412 549 603750
38 1000 1124 412 549 603750
39 1125 1248 412 549 598920
40 1 124 550 687 598920
41 125 249 550 687 603750
42 250 374 550 687 603750
43 375 499 550 687 603750
44 500 624 550 687 603750
45 625 749 550 687 603750
46 750 874 550 687 603750
47 875 999 550 687 603750
48 1000 1124 550 687 603750
49 1125 1248 550 687 598920
50 1 124 688 825 598920
51 125 249 688 825 603750
52 250 374 688 825 603750
53 375 499 688 825 603750
54 500 624 688 825 603750
55 625 749 688 825 603750
56 750 874 688 825 603750
57 875 999 688 825 603750
58 1000 1124 688 825 603750
59 1125 1248 688 825 598920
60 1 124 826 963 598920
61 125 249 826 963 603750
62 250 374 826 963 603750
63 375 499 826 963 603750
64 500 624 826 963 603750
65 625 749 826 963 603750
66 750 874 826 963 603750
67 875 999 826 963 603750
68 1000 1124 826 963 603750
69 1125 1248 826 963 598920
70 1 124 964 1098 585900
71 125 249 964 1098 590625
72 250 374 964 1098 590625
73 375 499 964 1098 590625
74 500 624 964 1098 590625
75 625 749 964 1098 590625
76 750 874 964 1098 590625
77 875 999 964 1098 590625
78 1000 1124 964 1098 590625
79 1125 1248 964 1098 585900
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 124.50 0.50 135.50 RHO-points
1 124.50 249.50 0.50 135.50 RHO-points
2 249.50 374.50 0.50 135.50 RHO-points
3 374.50 499.50 0.50 135.50 RHO-points
4 499.50 624.50 0.50 135.50 RHO-points
5 624.50 749.50 0.50 135.50 RHO-points
6 749.50 874.50 0.50 135.50 RHO-points
7 874.50 999.50 0.50 135.50 RHO-points
8 999.50 1124.50 0.50 135.50 RHO-points
9 1124.50 1248.50 0.50 135.50 RHO-points
10 0.50 124.50 135.50 273.50 RHO-points
11 124.50 249.50 135.50 273.50 RHO-points
12 249.50 374.50 135.50 273.50 RHO-points
13 374.50 499.50 135.50 273.50 RHO-points
14 499.50 624.50 135.50 273.50 RHO-points
15 624.50 749.50 135.50 273.50 RHO-points
16 749.50 874.50 135.50 273.50 RHO-points
17 874.50 999.50 135.50 273.50 RHO-points
18 999.50 1124.50 135.50 273.50 RHO-points
19 1124.50 1248.50 135.50 273.50 RHO-points
20 0.50 124.50 273.50 411.50 RHO-points
21 124.50 249.50 273.50 411.50 RHO-points
22 249.50 374.50 273.50 411.50 RHO-points
23 374.50 499.50 273.50 411.50 RHO-points
24 499.50 624.50 273.50 411.50 RHO-points
25 624.50 749.50 273.50 411.50 RHO-points
26 749.50 874.50 273.50 411.50 RHO-points
27 874.50 999.50 273.50 411.50 RHO-points
28 999.50 1124.50 273.50 411.50 RHO-points
29 1124.50 1248.50 273.50 411.50 RHO-points
30 0.50 124.50 411.50 549.50 RHO-points
31 124.50 249.50 411.50 549.50 RHO-points
32 249.50 374.50 411.50 549.50 RHO-points
33 374.50 499.50 411.50 549.50 RHO-points
34 499.50 624.50 411.50 549.50 RHO-points
35 624.50 749.50 411.50 549.50 RHO-points
36 749.50 874.50 411.50 549.50 RHO-points
37 874.50 999.50 411.50 549.50 RHO-points
38 999.50 1124.50 411.50 549.50 RHO-points
39 1124.50 1248.50 411.50 549.50 RHO-points
40 0.50 124.50 549.50 687.50 RHO-points
41 124.50 249.50 549.50 687.50 RHO-points
42 249.50 374.50 549.50 687.50 RHO-points
43 374.50 499.50 549.50 687.50 RHO-points
44 499.50 624.50 549.50 687.50 RHO-points
45 624.50 749.50 549.50 687.50 RHO-points
46 749.50 874.50 549.50 687.50 RHO-points
47 874.50 999.50 549.50 687.50 RHO-points
48 999.50 1124.50 549.50 687.50 RHO-points
49 1124.50 1248.50 549.50 687.50 RHO-points
50 0.50 124.50 687.50 825.50 RHO-points
51 124.50 249.50 687.50 825.50 RHO-points
52 249.50 374.50 687.50 825.50 RHO-points
53 374.50 499.50 687.50 825.50 RHO-points
54 499.50 624.50 687.50 825.50 RHO-points
55 624.50 749.50 687.50 825.50 RHO-points
56 749.50 874.50 687.50 825.50 RHO-points
57 874.50 999.50 687.50 825.50 RHO-points
58 999.50 1124.50 687.50 825.50 RHO-points
59 1124.50 1248.50 687.50 825.50 RHO-points
60 0.50 124.50 825.50 963.50 RHO-points
61 124.50 249.50 825.50 963.50 RHO-points
62 249.50 374.50 825.50 963.50 RHO-points
63 374.50 499.50 825.50 963.50 RHO-points
64 499.50 624.50 825.50 963.50 RHO-points
65 624.50 749.50 825.50 963.50 RHO-points
66 749.50 874.50 825.50 963.50 RHO-points
67 874.50 999.50 825.50 963.50 RHO-points
68 999.50 1124.50 825.50 963.50 RHO-points
69 1124.50 1248.50 825.50 963.50 RHO-points
70 0.50 124.50 963.50 1098.50 RHO-points
71 124.50 249.50 963.50 1098.50 RHO-points
72 249.50 374.50 963.50 1098.50 RHO-points
73 374.50 499.50 963.50 1098.50 RHO-points
74 499.50 624.50 963.50 1098.50 RHO-points
75 624.50 749.50 963.50 1098.50 RHO-points
76 749.50 874.50 963.50 1098.50 RHO-points
77 874.50 999.50 963.50 1098.50 RHO-points
78 999.50 1124.50 963.50 1098.50 RHO-points
79 1124.50 1248.50 963.50 1098.50 RHO-points
0 1.00 124.50 0.50 135.50 U-points
1 124.50 249.50 0.50 135.50 U-points
2 249.50 374.50 0.50 135.50 U-points
3 374.50 499.50 0.50 135.50 U-points
4 499.50 624.50 0.50 135.50 U-points
5 624.50 749.50 0.50 135.50 U-points
6 749.50 874.50 0.50 135.50 U-points
7 874.50 999.50 0.50 135.50 U-points
8 999.50 1124.50 0.50 135.50 U-points
9 1124.50 1248.00 0.50 135.50 U-points
10 1.00 124.50 135.50 273.50 U-points
11 124.50 249.50 135.50 273.50 U-points
12 249.50 374.50 135.50 273.50 U-points
13 374.50 499.50 135.50 273.50 U-points
14 499.50 624.50 135.50 273.50 U-points
15 624.50 749.50 135.50 273.50 U-points
16 749.50 874.50 135.50 273.50 U-points
17 874.50 999.50 135.50 273.50 U-points
18 999.50 1124.50 135.50 273.50 U-points
19 1124.50 1248.00 135.50 273.50 U-points
20 1.00 124.50 273.50 411.50 U-points
21 124.50 249.50 273.50 411.50 U-points
22 249.50 374.50 273.50 411.50 U-points
23 374.50 499.50 273.50 411.50 U-points
24 499.50 624.50 273.50 411.50 U-points
25 624.50 749.50 273.50 411.50 U-points
26 749.50 874.50 273.50 411.50 U-points
27 874.50 999.50 273.50 411.50 U-points
28 999.50 1124.50 273.50 411.50 U-points
29 1124.50 1248.00 273.50 411.50 U-points
30 1.00 124.50 411.50 549.50 U-points
31 124.50 249.50 411.50 549.50 U-points
32 249.50 374.50 411.50 549.50 U-points
33 374.50 499.50 411.50 549.50 U-points
34 499.50 624.50 411.50 549.50 U-points
35 624.50 749.50 411.50 549.50 U-points
36 749.50 874.50 411.50 549.50 U-points
37 874.50 999.50 411.50 549.50 U-points
38 999.50 1124.50 411.50 549.50 U-points
39 1124.50 1248.00 411.50 549.50 U-points
40 1.00 124.50 549.50 687.50 U-points
41 124.50 249.50 549.50 687.50 U-points
42 249.50 374.50 549.50 687.50 U-points
43 374.50 499.50 549.50 687.50 U-points
44 499.50 624.50 549.50 687.50 U-points
45 624.50 749.50 549.50 687.50 U-points
46 749.50 874.50 549.50 687.50 U-points
47 874.50 999.50 549.50 687.50 U-points
48 999.50 1124.50 549.50 687.50 U-points
49 1124.50 1248.00 549.50 687.50 U-points
50 1.00 124.50 687.50 825.50 U-points
51 124.50 249.50 687.50 825.50 U-points
52 249.50 374.50 687.50 825.50 U-points
53 374.50 499.50 687.50 825.50 U-points
54 499.50 624.50 687.50 825.50 U-points
55 624.50 749.50 687.50 825.50 U-points
56 749.50 874.50 687.50 825.50 U-points
57 874.50 999.50 687.50 825.50 U-points
58 999.50 1124.50 687.50 825.50 U-points
59 1124.50 1248.00 687.50 825.50 U-points
60 1.00 124.50 825.50 963.50 U-points
61 124.50 249.50 825.50 963.50 U-points
62 249.50 374.50 825.50 963.50 U-points
63 374.50 499.50 825.50 963.50 U-points
64 499.50 624.50 825.50 963.50 U-points
65 624.50 749.50 825.50 963.50 U-points
66 749.50 874.50 825.50 963.50 U-points
67 874.50 999.50 825.50 963.50 U-points
68 999.50 1124.50 825.50 963.50 U-points
69 1124.50 1248.00 825.50 963.50 U-points
70 1.00 124.50 963.50 1098.50 U-points
71 124.50 249.50 963.50 1098.50 U-points
72 249.50 374.50 963.50 1098.50 U-points
73 374.50 499.50 963.50 1098.50 U-points
74 499.50 624.50 963.50 1098.50 U-points
75 624.50 749.50 963.50 1098.50 U-points
76 749.50 874.50 963.50 1098.50 U-points
77 874.50 999.50 963.50 1098.50 U-points
78 999.50 1124.50 963.50 1098.50 U-points
79 1124.50 1248.00 963.50 1098.50 U-points
0 0.50 124.50 1.00 135.50 V-points
1 124.50 249.50 1.00 135.50 V-points
2 249.50 374.50 1.00 135.50 V-points
3 374.50 499.50 1.00 135.50 V-points
4 499.50 624.50 1.00 135.50 V-points
5 624.50 749.50 1.00 135.50 V-points
6 749.50 874.50 1.00 135.50 V-points
7 874.50 999.50 1.00 135.50 V-points
8 999.50 1124.50 1.00 135.50 V-points
9 1124.50 1248.50 1.00 135.50 V-points
10 0.50 124.50 135.50 273.50 V-points
11 124.50 249.50 135.50 273.50 V-points
12 249.50 374.50 135.50 273.50 V-points
13 374.50 499.50 135.50 273.50 V-points
14 499.50 624.50 135.50 273.50 V-points
Node # 41 (pid= 77568) is active.
15 624.50 749.50 135.50 273.50 V-points
16 749.50 874.50 135.50 273.50 V-points
17 874.50 999.50 135.50 273.50 V-points
18 999.50 1124.50 135.50 273.50 V-points
19 1124.50 1248.50 135.50 273.50 V-points
20 0.50 124.50 273.50 411.50 V-points
21 124.50 249.50 273.50 411.50 V-points
22 249.50 374.50 273.50 411.50 V-points
23 374.50 499.50 273.50 411.50 V-points
Node # 42 (pid= 77569) is active.
24 499.50 624.50 273.50 411.50 V-points
25 624.50 749.50 273.50 411.50 V-points
26 749.50 874.50 273.50 411.50 V-points
27 874.50 999.50 273.50 411.50 V-points
28 999.50 1124.50 273.50 411.50 V-points
29 1124.50 1248.50 273.50 411.50 V-points
30 0.50 124.50 411.50 549.50 V-points
31 124.50 249.50 411.50 549.50 V-points
32 249.50 374.50 411.50 549.50 V-points
Node # 50 (pid= 77577) is active.
33 374.50 499.50 411.50 549.50 V-points
34 499.50 624.50 411.50 549.50 V-points
35 624.50 749.50 411.50 549.50 V-points
36 749.50 874.50 411.50 549.50 V-points
37 874.50 999.50 411.50 549.50 V-points
38 999.50 1124.50 411.50 549.50 V-points
39 1124.50 1248.50 411.50 549.50 V-points
40 0.50 124.50 549.50 687.50 V-points
41 124.50 249.50 549.50 687.50 V-points
Node # 51 (pid= 77578) is active.
42 249.50 374.50 549.50 687.50 V-points
43 374.50 499.50 549.50 687.50 V-points
44 499.50 624.50 549.50 687.50 V-points
45 624.50 749.50 549.50 687.50 V-points
46 749.50 874.50 549.50 687.50 V-points
47 874.50 999.50 549.50 687.50 V-points
48 999.50 1124.50 549.50 687.50 V-points
49 1124.50 1248.50 549.50 687.50 V-points
50 0.50 124.50 687.50 825.50 V-points
Node # 55 (pid= 77582) is active.
51 124.50 249.50 687.50 825.50 V-points
52 249.50 374.50 687.50 825.50 V-points
53 374.50 499.50 687.50 825.50 V-points
54 499.50 624.50 687.50 825.50 V-points
55 624.50 749.50 687.50 825.50 V-points
56 749.50 874.50 687.50 825.50 V-points
57 874.50 999.50 687.50 825.50 V-points
58 999.50 1124.50 687.50 825.50 V-points
59 1124.50 1248.50 687.50 825.50 V-points
Node # 59 (pid= 77586) is active.
60 0.50 124.50 825.50 963.50 V-points
61 124.50 249.50 825.50 963.50 V-points
62 249.50 374.50 825.50 963.50 V-points
63 374.50 499.50 825.50 963.50 V-points
64 499.50 624.50 825.50 963.50 V-points
65 624.50 749.50 825.50 963.50 V-points
66 749.50 874.50 825.50 963.50 V-points
67 874.50 999.50 825.50 963.50 V-points
68 999.50 1124.50 825.50 963.50 V-points
Node # 69 (pid= 77596) is active.
69 1124.50 1248.50 825.50 963.50 V-points
70 0.50 124.50 963.50 1098.00 V-points
71 124.50 249.50 963.50 1098.00 V-points
72 249.50 374.50 963.50 1098.00 V-points
73 374.50 499.50 963.50 1098.00 V-points
74 499.50 624.50 963.50 1098.00 V-points
75 624.50 749.50 963.50 1098.00 V-points
76 749.50 874.50 963.50 1098.00 V-points
77 874.50 999.50 963.50 1098.00 V-points
Node # 74 (pid= 77601) is active.
78 999.50 1124.50 963.50 1098.00 V-points
79 1124.50 1248.50 963.50 1098.00 V-points
HaloSizeI(1) = 417
HaloSizeJ(1) = 456
TileSide(1) = 146
TileSize(1) = 19418
ubar 1 Flather Flather Flather Flather
Node # 40 (pid= 77567) is active.
vbar 1 Flather Flather Flather Flather
temp 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
salt 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
tke 1 Radiation Radiation Radiation Radiation
HONGKONG AAMC
ATM_PRESS Impose atmospheric pressure onto sea surface.
BULK_FLUXES Surface bulk fluxes parameterization.
EMINUSP Compute Salt Flux using E-P.
MASKING Land/Sea masking.
Node # 44 (pid= 77571) is active.
MIX_ISO_TS Mixing of tracers along isopycnal surfaces.
MY25_MIXING Mellor/Yamada Level-2.5 mixing closure.
NONLINEAR Nonlinear Model.
NO_LBC_ATT Not checking NetCDF global attribute NLM_LBC during restart.
K_C4ADVECTION Fourth-order centered differences advection of TKE fields.
Node # 45 (pid= 77572) is active.
READ_WATER Reading data at water points only.
RI_SPLINES Parabolic Spline Reconstruction for Richardson Number.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Node # 46 (pid= 77573) is active.
UV_SMAGORINSKY Smagorinksy-like time-dependent viscosity coefficients.
VISC_3DCOEF Horizontal, time-dependent 3D viscosity coefficient.
CHECKADJ - use caution when activating: UV_SMAGORINSKY
REASON: stability problems, WARNING.
35 0.0000000 0.0000000 0.000 0.000 0.000 0.000
34 -0.0285714 -0.0004918 -0.145 -0.145 -2.050 -3.815
33 -0.0571429 -0.0019703 -0.296 -0.296 -7.641 -14.714
32 -0.0857143 -0.0044449 -0.451 -0.451 -16.808 -32.763
31 -0.1142857 -0.0079314 -0.611 -0.611 -29.607 -58.075
30 -0.1428571 -0.0124518 -0.777 -0.777 -46.116 -90.808
29 -0.1714286 -0.0180347 -0.947 -0.947 -66.438 -131.169
28 -0.2000000 -0.0247149 -1.124 -1.124 -90.699 -179.406
27 -0.2285714 -0.0325342 -1.306 -1.306 -119.049 -235.820
26 -0.2571429 -0.0415407 -1.493 -1.493 -151.659 -300.756
25 -0.2857143 -0.0517896 -1.688 -1.688 -188.729 -374.610
24 -0.3142857 -0.0633428 -1.888 -1.888 -230.480 -457.827
23 -0.3428571 -0.0762693 -2.096 -2.096 -277.159 -550.901
22 -0.3714286 -0.0906450 -2.310 -2.310 -329.041 -654.378
21 -0.4000000 -0.1065532 -2.533 -2.533 -386.422 -768.856
20 -0.4285714 -0.1240840 -2.763 -2.763 -449.627 -894.981
19 -0.4571429 -0.1433350 -3.002 -3.002 -519.006 -1033.454
18 -0.4857143 -0.1644105 -3.251 -3.251 -594.934 -1185.024
17 -0.5142857 -0.1874218 -3.509 -3.509 -677.809 -1350.489
16 -0.5428571 -0.2124868 -3.777 -3.777 -768.056 -1530.696
15 -0.5714286 -0.2397294 -4.056 -4.056 -866.118 -1726.535
14 -0.6000000 -0.2692794 -4.346 -4.346 -972.461 -1938.937
13 -0.6285714 -0.3012713 -4.649 -4.649 -1087.569 -2168.867
12 -0.6571429 -0.3358436 -4.965 -4.965 -1211.939 -2417.319
11 -0.6857143 -0.3731377 -5.294 -5.294 -1346.077 -2685.309
10 -0.7142857 -0.4132962 -5.638 -5.638 -1490.496 -2973.861
9 -0.7428571 -0.4564613 -5.997 -5.997 -1645.706 -3283.995
8 -0.7714286 -0.5027728 -6.371 -6.371 -1812.209 -3616.714
7 -0.8000000 -0.5523651 -6.762 -6.762 -1990.486 -3972.983
6 -0.8285714 -0.6053646 -7.170 -7.170 -2180.994 -4353.711
5 -0.8571429 -0.6618863 -7.595 -7.595 -2384.142 -4759.721
4 -0.8857143 -0.7220296 -8.039 -8.039 -2600.289 -5191.727
3 -0.9142857 -0.7858738 -8.501 -8.501 -2829.719 -5650.300
2 -0.9428571 -0.8534736 -8.982 -8.982 -3072.628 -6135.831
1 -0.9714286 -0.9248530 -9.481 -9.481 -3329.103 -6648.493
0 -1.0000000 -1.0000000 -10.000 -10.000 -3599.100 -7188.199
ndtfast, nfast = 180 241 nfast/ndtfast = 1.33889
1.000000000000 1.011547989092 0.505773994546 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.26822
Minimum X-grid spacing, DXmin = 1.08226339E+01 km
Maximum X-grid spacing, DXmax = 1.08234832E+01 km
Minimum Y-grid spacing, DYmin = 1.07500622E+01 km
Maximum Y-grid spacing, DYmax = 1.08209760E+01 km
Minimum Z-grid spacing, DZmin = 1.45316090E-01 m
Maximum Z-grid spacing, DZmax = 5.39706365E+02 m
Minimum barotropic Courant Number = 7.19051938E-05
Maximum barotropic Courant Number = 1.93400940E-03
Maximum Coriolis Courant Number = 1.27985656E-03
Minimum horizontal viscosity coefficient = 8.98857253E+01 m2/s
Maximum horizontal viscosity coefficient = 9.01852461E+01 m2/s
NLM: GET_STATE - Read state initial conditions, t = 59448 00:00:00
(Grid 01, File: roms_ini.nc, Rec=0001, Index=1)
- free-surface
(Min = -5.23771516E-01 Max = 1.68767574E+00)
(Min = -5.88693481E-01 Max = 8.93720017E-01)
(Min = -8.99220987E-01 Max = 8.94592932E-01)
- u-momentum component
(Min = -1.64256394E+00 Max = 2.86598516E+00)
- v-momentum component
(Min = -2.28817463E+00 Max = 1.81433034E+00)
- potential temperature
(Min = -1.89512908E+00 Max = 3.59746475E+01)
- salinity
(Min = 0.00000000E+00 Max = 4.39164734E+01)
GET_2DFLD - surface u-wind component, t = 59448 00:00:00
(Rec=0000001, Index=1, File: roms_forc.nc)
(Tmin= 59448.0000 Tmax= 59451.2500)
(Min = -2.12692261E+01 Max = 1.47474135E+01)
GET_2DFLD - surface v-wind component, t = 59448 00:00:00
(Min = -1.65383660E+01 Max = 2.22907516E+01)
GET_2DFLD - surface air pressure, t = 59448 00:00:00
(Min = 5.02593040E+02 Max = 1.02620879E+03)
GET_2DFLD - surface air temperature, t = 59448 00:00:00
(Min = -1.72279855E+01 Max = 4.12276120E+01)
GET_2DFLD - surface air relative humidity, t = 59448 00:00:00
(Min = 8.67188807E-02 Max = 9.99982713E-01)
GET_2DFLD - solar shortwave radiation flux, t = 59448 00:00:00
(Min = 0.00000000E+00 Max = 2.26388896E-04)
GET_2DFLD - net longwave radiation flux, t = 59448 00:00:00
(Min = -6.33245609E-05 Max = 2.18022298E-06)
GET_2DFLD - rain fall rate, t = 59448 00:00:00
(Min = 0.00000000E+00 Max = 4.18852894E-03)
GET_NGFLD - free-surface western boundary condition, t = 59448 00:00:00
(Rec=0000001, Index=2, File: roms_bdy.nc)
(Min = 0.00000000E+00 Max = 9.18808910E-01)
GET_NGFLD - free-surface eastern boundary condition, t = 59448 00:00:00
(Min = -3.72236876E-01 Max = 9.85347354E-01)
GET_NGFLD - free-surface southern boundary condition, t = 59448 00:00:00
(Min = 0.00000000E+00 Max = 9.30096322E-01)
GET_NGFLD - free-surface northern boundary condition, t = 59448 00:00:00
(Min = -1.54842855E-01 Max = 0.00000000E+00)
GET_NGFLD - 2D u-momentum western boundary condition, t = 59448 00:00:00
(Min = -1.93881100E-01 Max = 3.98690294E-01)
GET_NGFLD - 2D v-momentum western boundary condition, t = 59448 00:00:00
(Min = -1.24536020E-01 Max = 5.05757189E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 59448 00:00:00
(Min = -2.22985159E-01 Max = 1.69643588E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 59448 00:00:00
(Min = -2.49782698E-01 Max = 2.32015508E-01)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 59448 00:00:00
(Min = -1.27306205E-01 Max = 1.45040155E-01)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 59448 00:00:00
(Min = -3.59970067E-01 Max = 1.85509109E-01)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 59448 00:00:00
(Min = -8.55978581E-02 Max = 3.09511009E-02)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 59448 00:00:00
(Min = -1.53482416E-01 Max = 5.01764663E-02)
GET_NGFLD - 3D u-momentum western boundary condition, t = 59448 00:00:00
(Min = -8.56141626E-01 Max = 7.60081740E-01)
GET_NGFLD - 3D v-momentum western boundary condition, t = 59448 00:00:00
(Min = -8.91905015E-01 Max = 9.14233817E-01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 59448 00:00:00
(Min = -1.11849057E+00 Max = 8.93760105E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 59448 00:00:00
(Min = -1.23631883E+00 Max = 5.82368326E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 59448 00:00:00
(Min = -5.19719120E-01 Max = 7.16236399E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 59448 00:00:00
(Min = -7.65520368E-01 Max = 7.96315578E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 59448 00:00:00
(Min = -1.61467013E-01 Max = 9.47605396E-02)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 59448 00:00:00
(Min = -1.91182274E-01 Max = 9.12230464E-02)
GET_NGFLD - temperature western boundary condition, t = 59448 00:00:00
(Min = 0.00000000E+00 Max = 3.38317888E+01)
GET_NGFLD - salinity western boundary condition, t = 59448 00:00:00
(Min = 0.00000000E+00 Max = 4.05570047E+01)
GET_NGFLD - temperature eastern boundary condition, t = 59448 00:00:00
(Min = 0.00000000E+00 Max = 3.00975357E+01)
GET_NGFLD - salinity eastern boundary condition, t = 59448 00:00:00
(Min = 0.00000000E+00 Max = 3.59606162E+01)
GET_NGFLD - temperature southern boundary condition, t = 59448 00:00:00
(Min = 0.00000000E+00 Max = 2.28045448E+01)
GET_NGFLD - salinity southern boundary condition, t = 59448 00:00:00
(Min = 0.00000000E+00 Max = 3.60215520E+01)
GET_NGFLD - temperature northern boundary condition, t = 59448 00:00:00
(Min = 0.00000000E+00 Max = 1.16957574E+01)
GET_NGFLD - salinity northern boundary condition, t = 59448 00:00:00
(Min = 0.00000000E+00 Max = 3.27917837E+01)
Maximum grid stiffness ratios: rx0 = 5.189205E-01 (Beckmann and Haidvogel)
rx1 = 1.641224E+01 (Haney)
Initial basin volumes: TotVolume = 2.7396633652E+17 m3
MinVolume = 1.6906680057E+07 m3
MaxVolume = 6.2809235998E+10 m3
Max/Min = 3.7150543919E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00449281 - 00086400)
GET_2DFLD - surface u-wind component, t = 59448 06:00:00
(Rec=0000002, Index=2, File: roms_forc.nc)
(Min = -1.62967982E+01 Max = 1.49250742E+01)
GET_2DFLD - surface v-wind component, t = 59448 06:00:00
(Min = -1.42649994E+01 Max = 2.24804682E+01)
GET_2DFLD - surface air pressure, t = 59448 06:00:00
(Min = 5.03315126E+02 Max = 1.02483943E+03)
GET_2DFLD - surface air temperature, t = 59448 06:00:00
(Min = 9.44074498E-02 Max = 6.65694407E+01)
GET_2DFLD - surface air relative humidity, t = 59448 06:00:00
(Min = 3.59224866E-02 Max = 1.00000000E+00)
GET_2DFLD - solar shortwave radiation flux, t = 59448 06:00:00
(Min = 5.05144004E-07 Max = 2.26292645E-04)
GET_2DFLD - net longwave radiation flux, t = 59448 06:00:00
(Min = -8.55175232E-05 Max = 1.92112509E-06)
GET_2DFLD - rain fall rate, t = 59448 06:00:00
(Min = 0.00000000E+00 Max = 3.67907220E-03)
GET_NGFLD - free-surface western boundary condition, t = 59448 06:00:00
(Rec=0000002, Index=1, File: roms_bdy.nc)
(Min = 0.00000000E+00 Max = 9.13595725E-01)
GET_NGFLD - free-surface eastern boundary condition, t = 59448 06:00:00
(Min = -3.80341571E-01 Max = 1.00688323E+00)
GET_NGFLD - free-surface southern boundary condition, t = 59448 06:00:00
(Min = 0.00000000E+00 Max = 9.21159827E-01)
GET_NGFLD - free-surface northern boundary condition, t = 59448 06:00:00
(Min = -1.47869733E-01 Max = 0.00000000E+00)
GET_NGFLD - 2D u-momentum western boundary condition, t = 59448 06:00:00
(Min = -1.94615663E-01 Max = 3.86651699E-01)
GET_NGFLD - 2D v-momentum western boundary condition, t = 59448 06:00:00
(Min = -1.23470110E-01 Max = 5.13688864E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 59448 06:00:00
(Min = -2.25827859E-01 Max = 1.70569687E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 59448 06:00:00
(Min = -2.53845765E-01 Max = 2.28138624E-01)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 59448 06:00:00
(Min = -1.28899920E-01 Max = 1.42907998E-01)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 59448 06:00:00
(Min = -3.63704986E-01 Max = 1.85439025E-01)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 59448 06:00:00
(Min = -7.87085736E-02 Max = 3.78793816E-02)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 59448 06:00:00
(Min = -1.53680235E-01 Max = 5.56665103E-02)
GET_NGFLD - 3D u-momentum western boundary condition, t = 59448 06:00:00
(Min = -8.73040843E-01 Max = 7.62176647E-01)
GET_NGFLD - 3D v-momentum western boundary condition, t = 59448 06:00:00
(Min = -9.38988573E-01 Max = 8.87503651E-01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 59448 06:00:00
(Min = -1.25736728E+00 Max = 8.33861637E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 59448 06:00:00
(Min = -1.07589611E+00 Max = 5.47690883E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 59448 06:00:00
(Min = -5.72394462E-01 Max = 8.20241750E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 59448 06:00:00
(Min = -7.96319550E-01 Max = 7.89201078E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 59448 06:00:00
(Min = -1.60715406E-01 Max = 8.72553923E-02)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 59448 06:00:00
(Min = -1.97438264E-01 Max = 8.77242500E-02)
GET_NGFLD - temperature western boundary condition, t = 59448 06:00:00
(Min = 0.00000000E+00 Max = 3.37482743E+01)
GET_NGFLD - salinity western boundary condition, t = 59448 06:00:00
GET_NGFLD - temperature eastern boundary condition, t = 59448 06:00:00
(Min = 0.00000000E+00 Max = 3.02205660E+01)
GET_NGFLD - salinity eastern boundary condition, t = 59448 06:00:00
(Min = 0.00000000E+00 Max = 3.59577041E+01)
GET_NGFLD - temperature southern boundary condition, t = 59448 06:00:00
(Min = 0.00000000E+00 Max = 2.31599658E+01)
GET_NGFLD - salinity southern boundary condition, t = 59448 06:00:00
(Min = 0.00000000E+00 Max = 3.60048515E+01)
GET_NGFLD - temperature northern boundary condition, t = 59448 06:00:00
(Min = 0.00000000E+00 Max = 1.17224400E+01)
GET_NGFLD - salinity northern boundary condition, t = 59448 06:00:00
(Min = 0.00000000E+00 Max = 3.27933619E+01)
449280 59448 00:00:00 6.330212E-03 2.194455E+04 2.194456E+04 2.747863E+17
(0139,0370,34) 1.823549E-03 1.992562E-03 0.000000E+00 2.914745E+00
WRT_HIS - wrote history fields (Index=1,1) in record = 0000001
449281 59448 00:00:10 6.330793E-03 2.194455E+04 2.194456E+04 2.747863E+17
(0858,0349,24) 6.361238E-04 2.791231E-04 3.430988E-03 2.914673E+00
449282 59448 00:00:20 6.332671E-03 2.194455E+04 2.194456E+04 2.747863E+17
(1080,0197,35) 2.285632E-04 3.417999E-04 5.214773E-01 2.914633E+00
449283 59448 00:00:30 6.335590E-03 2.194455E+04 2.194456E+04 2.747863E+17
(0865,0399,35) 4.783167E-05 1.043398E-05 6.417421E-01 2.914633E+00
449284 59448 00:00:40 6.339342E-03 2.194455E+04 2.194456E+04 2.747863E+17
(0953,0375,35) 5.513642E-05 4.775511E-05 8.049609E-01 2.914690E+00
449285 59448 00:00:50 6.343717E-03 2.194455E+04 2.194456E+04 2.747863E+17
(0953,0375,35) 6.610631E-05 3.569643E-05 9.157686E-01 2.914818E+00
