Hi all
I have a model domain that will require 2 different wind fields to be applied to different parts of the domain. I understand that if I have a global wind field in the forcing file, the global wind will be interpolated and rotated to fit the whole domain; and if I have a fully gridded wind field then the model will use the fully gridded wind in the forcing file directly.
Is it possible that ROMS can read 2 wind fields from forcing file, and interpolate or assign the winds automatically or based on certain specification? Or do I still have to assign/interpolate the 2 wind fields and rotate to xi/eta direction for each grid cell, and generate fully gridded wind field in the forcing file?
Thanks ahead for anyone who can help.
Multiple Wind Field
Re: Multiple Wind Field
You can merge them before having ROMS read them and regrid/rotate them if they are both on lat/lon grids of the same resolution.
You can copy the ROMS code for reading then regrid/rotating winds to also read/rotate/regrid say Unwind2 and Vwind2. Then you can come up with some means of merging them inside the model, but you'll have to do that coding yourself.
Thanks. I think it will be a bit easier to regrid with pre-processing.kate wrote: ↑Thu Aug 12, 2021 6:54 pm You can merge them before having ROMS read them and regrid/rotate them if they are both on lat/lon grids of the same resolution.
Another question, is it ok to put regridded wind forcing and other global meteorology forcing in the same file as they are in different dimensions?
Yes, it doesn't care if you have one file or five. The variable names and dimensions all have to be appropriate to their fields.
