Problems reading the grid netCDF file
birgitrr
#1 Unread post by birgitrr »
Hello everyone!
I'm (still) trying to run the model on my specific case (a freshwater lake). I made a grid using pygridgen, and I have set the path to the grid in the .in-file. yet, it seems like ROMS can't find my grid, by this error message:
GET_GRID - Illegal output type, io_type = 0
Found Error: 03 Line: 90 Source: ROMS/Utility/get_grid.F
Found Error: 03 Line: 82 Source: ROMS/Utility/set_grid.F
GET_STATE - Illegal output type, io_type = 0
Found Error: 03 Line: 151 Source: ROMS/Utility/get_state.F
Found Error: 03 Line: 417 Source: ROMS/Nonlinear/initial.F
Found Error: 03 Line: 200 Source: ROMS/Drivers/nl_roms.h, ROMS_initialize
Thread # 0 CPU: 3.013
Total: 3.013
Allocation and array initialization .............. 3.013 (99.9895 %)
Total: 3.013 99.9895 %
Unique kernel(s) regions profiled ................ 3.013 99.9895 %
Residual, non-profiled code ...................... 0.000 0.0105 %
All percentages are with respect to total time = 3.013
Dynamic and Automatic memory (MB) usage for Grid 01: 150x150x30 tiling: 1x1
tile Dynamic Automatic USAGE
0 270.10 42.40 312.50
TOTAL 270.10 42.40 312.50
Found Error: 03 Line: 85 Source: ROMS/Utility/close_io.F, close_file_nf90
Found Error: 03 Line: 381 Source: ROMS/Utility/close_io.F, close_out
REASON: No error
ERROR STOP
Error termination. Backtrace:
#0 0x7f94f7906d21 in ???
#1 0x7f94f7907869 in ???
#2 0x7f94f7908f97 in ???
#3 0x55a406ea29bf in myroms
at /home/birgit/my_roms_projects/norsjo/Build_romsG/master.f90:101
#4 0x55a406ea2a18 in main
at /home/birgit/my_roms_projects/norsjo/Build_romsG/master.f90:50
Any ideas on how to fix that?
Sincerely,
Birgit
Re: Problems reading the grid netCDF file
#2 Unread post by wilkin »
Are you sure your roms.in is up to date with your code?
When updates are made to the code sometimes they require new entries in roms.in (and varinfo.dat), and if you don't also update those input files it can trigger errors (because ROMS is expecting to read some settings from roms.in).
Recent changes to parallel I/O may be your problem.
diff your roms.in against one of the example case versions.
