Error in extract_bath.m program
manhnt181
#1 Unread post by manhnt181 »
Hi ROMS Community,
I got the problem when I used the extract_bath.m program with the etopo5 data to create the bathymetry data. It was successful for the USeast area like the COAWST manual, but I modified it to another are but it failed without error or warning.
This is my program:
%  EXTRACT_BATH:  Driver script to extract bathymetry data
%  This user modifiable script can extract bathymetry from ETOPO-5 database
%  at the specified coordinates.
% svn $Id: extract_bath.m 996 2020-01-10 04:28:56Z arango $
%  Copyright (c) 2002-2020 The ROMS/TOMS Group                              %
%    Licensed under a MIT/X style license                                   %
%    See License_ROMS.txt                           Hernan G. Arango        %
job='seagrid';          %  prepare bathymetry for seagrid
%job='netcdf';           %  Extract a bathymetry NetCDF file
database='etopo5';
switch job,
  case 'seagrid'
    Oname='vn_bathy.mat';
    %Oname='US_bathy.mat';
  case 'netcdf'
    Oname='uswest_bath.nc';
end,
switch database,
  case 'etopo5'
    Bname='etopo5.nc';
end,
%Llon=-134.0;              % Left   corner longitude     % US west Coast
%Rlon=-118.0;              % Right  corner longitude
%Blat=33.0;                % Bottom corner latitude
%Tlat=49.0;                % Top    corner latitude
%original
Llon=105.0;              % Left   corner longitude
Rlon=125.0;              % Right  corner longitude
Blat=25.0;                % Bottom corner latitude
Tlat=5.0;                % Top    corner latitude
%  Read and extract bathymetry.
%x=ncread('etopo5.nc','topo_lon')
%y=ncread('etopo5.nc','topo_lat')
switch database,
  case 'etopo5'
    [lon,lat,h]=x_etopo(Llon,Rlon,Blat,Tlat,database);
 end
%  Process extracted data for requested task.
switch job,
  case 'seagrid'
    xbathy=reshape(lon,1,prod(size(lon)))';
    ybathy=reshape(lat,1,prod(size(lat)))';
    zbathy=reshape(h,1,prod(size(h)))';
    zbathy=-zbathy;
    ind=find(zbathy<0);
    if (~isempty(ind)),
      zbathy(ind)=0;
    end;
    save(Oname,'xbathy','ybathy','zbathy');
    case 'netcdf'
    [Im,Jm]=size(h);
    status=c_bath(Im,Jm,Oname);
    status=nc_write(Oname,'spherical',1);
    status=nc_write(Oname,'lon',lon);
    status=nc_write(Oname,'lat',lat);
    status=nc_write(Oname,'hraw',h,1);
end,
The detail of this issue was attached in the below.
Please help me to resolve this problem.
Many thanks,
Re: Error in extract_bath.m program
#2 Unread post by wilkin »
Could it be that Blat > Tlat ?
manhnt181
#3 Unread post by manhnt181 »
Hi Wilkin,
Thank you for your help.
This is my typing mistake, I changed that and this error doesn't occur again.
Thank you very much!
