The first question, which is a bit basic, what are the priorities for checking the output in .log file?
The second question is that the grid file has 30 vertical layers, but by changing the boundary and time, I could not prevent the model error(in 30 vertical layers), but considering 16 layers (the grid file is the same 30), the model was executed correctly for a year and I do not know where the problem comes from?!
The third question is that How can the following errors occur?
MaxSpeed & MaxDensity
Thanks a lot
grid-tide blowup
grid-tide blowup
- roms-a-year.log
- (55.18 MiB) Downloaded 457 times
- roms.log
- (3.66 MiB) Downloaded 226 times
Re: grid-tide blowup
So the same configuration runs with 16 vertical levels and blows up with 30? This is not surprising. When you add more vertical levels, the vertical advection requires a shorter timestep. Your run ran long enough that it seems fine except for the timestep limitation. Try a smaller DT. Your vertical CFL number got too big here:
(1.111797E+01) Remember, this needs to stay less than one.
20689 0001-01-08 04:24:30.00 9.228638E-02 1.185957E+04 1.185966E+04 1.811791E+14
(292,059,30) 2.852839E-02 1.282760E-02 1.111797E+01 2.098128E+01
Hi kate,
thanks a lot for your response
I'll do it and announce the result.
I face this error when I use a shorter time step with 30 vertical levels:
Saturday - May 15, 2021 - 1:30:09 AM
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /home/siadat/LIBRARIES/mvapich/bin/mpif90
Compiler flags : -fp-model precise -heap-arrays -ip -O3 -traceback -check uninit
OCN Communicator : 1140850688, PET size = 36
Input Script : roms_upwelling.in
GIT Root URL : https://www.myroms.org/git/src
GIT Revision : 766ca53c47d4e26e0329b305ac9cd9caaab44da6
SVN Revision : 1061
Local Root : /home/siadat/AMIR/src
Header Dir : /home/siadat/AMIR/grid-tide-sazman/only-tide-run
Header file : upwelling.h
Analytical Dir : /home/siadat/AMIR/grid-tide-sazman/only-tide-run
Resolution, Grid 01: 296x197x30, Parallel Nodes: 36, Tiling: 9x4
2102400 ntimes Number of timesteps for 3-D equations.
15.000 dt Timestep size (s) for 3-D equations.
3 ndtfast Number of timesteps for 2-D equations between
into restart fields.
to standard output.
into history file.
into quicksave file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
72 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
1.0000E-01 Dcrit Minimum depth for wetting and drying (m).
6.0000E+00 theta_s S-coordinate surface control parameter.
10.000 Tcline S-coordinate surface/bottom layer width (m) used
0.500 dstart Time-stamp assigned to model initialization (days).
*********** tide_start Reference time origin for tidal forcing (days).
20121028.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
for 3D momentum.
2.0000E+00 obcfac Factor between passive and active
of State.
T Dout(M2rate) Write out 2D momentum acceleration.
T Dout(M2pgrd) Write out 2D momentum pressure gradient.
T Dout(M2fcor) Write out 2D momentum Coriolis force.
T Dout(M2hadv) Write out 2D momentum horizontal advection.
T Dout(M2xadv) Write out 2D momentum horizontal X-advection.
T Dout(M2yadv) Write out 2D momentum horizontal Y-advection.
T Dout(M2hvis) Write out 2D momentum horizontal viscosity.
T Dout(M2xvis) Write out 2D momentum horizontal X-viscosity.
T Dout(M2yvis) Write out 2D momentum horizontal Y-viscosity.
T Dout(M2sstr) Write out 2D momentum surface stress.
T Dout(M2bstr) Write out 2D momentum bottom stress.
T Dout(M3rate) Write out 3D momentum acceleration.
Output Restart File: roms_rst.nc
Output History File: roms_his.nc
Output Averages File: roms_avg.nc
Output Diagnostics File: roms_dia.nc
Input Grid File: Persian_roms_grid.nc
Tidal Forcing File: tide_forc_Persian.nc
ROMS I/O variables Metadata File: /home/siadat/AMIR/grid-tide-sazman/only-tide-run/varinfo.dat
Tile partition information for Grid 01: 296x197x30 tiling: 9x4
tile Istr Iend Jstr Jend Npts
0 1 33 1 49 48510
1 34 66 1 49 48510
2 67 99 1 49 48510
3 100 132 1 49 48510
4 133 165 1 49 48510
5 166 198 1 49 48510
6 199 231 1 49 48510
7 232 264 1 49 48510
8 265 296 1 49 47040
9 1 33 50 99 49500
10 34 66 50 99 49500
11 67 99 50 99 49500
12 100 132 50 99 49500
13 133 165 50 99 49500
14 166 198 50 99 49500
15 199 231 50 99 49500
16 232 264 50 99 49500
17 265 296 50 99 48000
18 1 33 100 149 49500
19 34 66 100 149 49500
20 67 99 100 149 49500
21 100 132 100 149 49500
22 133 165 100 149 49500
23 166 198 100 149 49500
24 199 231 100 149 49500
25 232 264 100 149 49500
26 265 296 100 149 48000
27 1 33 150 197 47520
28 34 66 150 197 47520
29 67 99 150 197 47520
30 100 132 150 197 47520
31 133 165 150 197 47520
32 166 198 150 197 47520
33 199 231 150 197 47520
34 232 264 150 197 47520
35 265 296 150 197 46080
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 33.50 0.50 49.50 RHO-points
1 33.50 66.50 0.50 49.50 RHO-points
2 66.50 99.50 0.50 49.50 RHO-points
3 99.50 132.50 0.50 49.50 RHO-points
4 132.50 165.50 0.50 49.50 RHO-points
5 165.50 198.50 0.50 49.50 RHO-points
6 198.50 231.50 0.50 49.50 RHO-points
7 231.50 264.50 0.50 49.50 RHO-points
8 264.50 296.50 0.50 49.50 RHO-points
9 0.50 33.50 49.50 99.50 RHO-points
10 33.50 66.50 49.50 99.50 RHO-points
11 66.50 99.50 49.50 99.50 RHO-points
12 99.50 132.50 49.50 99.50 RHO-points
13 132.50 165.50 49.50 99.50 RHO-points
14 165.50 198.50 49.50 99.50 RHO-points
15 198.50 231.50 49.50 99.50 RHO-points
16 231.50 264.50 49.50 99.50 RHO-points
17 264.50 296.50 49.50 99.50 RHO-points
18 0.50 33.50 99.50 149.50 RHO-points
19 33.50 66.50 99.50 149.50 RHO-points
20 66.50 99.50 99.50 149.50 RHO-points
21 99.50 132.50 99.50 149.50 RHO-points
22 132.50 165.50 99.50 149.50 RHO-points
23 165.50 198.50 99.50 149.50 RHO-points
24 198.50 231.50 99.50 149.50 RHO-points
25 231.50 264.50 99.50 149.50 RHO-points
26 264.50 296.50 99.50 149.50 RHO-points
27 0.50 33.50 149.50 197.50 RHO-points
28 33.50 66.50 149.50 197.50 RHO-points
29 66.50 99.50 149.50 197.50 RHO-points
30 99.50 132.50 149.50 197.50 RHO-points
31 132.50 165.50 149.50 197.50 RHO-points
32 165.50 198.50 149.50 197.50 RHO-points
33 198.50 231.50 149.50 197.50 RHO-points
34 231.50 264.50 149.50 197.50 RHO-points
35 264.50 296.50 149.50 197.50 RHO-points
0 1.00 33.50 0.50 49.50 U-points
1 33.50 66.50 0.50 49.50 U-points
2 66.50 99.50 0.50 49.50 U-points
3 99.50 132.50 0.50 49.50 U-points
4 132.50 165.50 0.50 49.50 U-points
5 165.50 198.50 0.50 49.50 U-points
6 198.50 231.50 0.50 49.50 U-points
7 231.50 264.50 0.50 49.50 U-points
8 264.50 296.00 0.50 49.50 U-points
9 1.00 33.50 49.50 99.50 U-points
10 33.50 66.50 49.50 99.50 U-points
11 66.50 99.50 49.50 99.50 U-points
12 99.50 132.50 49.50 99.50 U-points
13 132.50 165.50 49.50 99.50 U-points
14 165.50 198.50 49.50 99.50 U-points
15 198.50 231.50 49.50 99.50 U-points
16 231.50 264.50 49.50 99.50 U-points
17 264.50 296.00 49.50 99.50 U-points
18 1.00 33.50 99.50 149.50 U-points
19 33.50 66.50 99.50 149.50 U-points
20 66.50 99.50 99.50 149.50 U-points
21 99.50 132.50 99.50 149.50 U-points
22 132.50 165.50 99.50 149.50 U-points
23 165.50 198.50 99.50 149.50 U-points
24 198.50 231.50 99.50 149.50 U-points
25 231.50 264.50 99.50 149.50 U-points
26 264.50 296.00 99.50 149.50 U-points
27 1.00 33.50 149.50 197.50 U-points
28 33.50 66.50 149.50 197.50 U-points
29 66.50 99.50 149.50 197.50 U-points
30 99.50 132.50 149.50 197.50 U-points
31 132.50 165.50 149.50 197.50 U-points
32 165.50 198.50 149.50 197.50 U-points
33 198.50 231.50 149.50 197.50 U-points
34 231.50 264.50 149.50 197.50 U-points
35 264.50 296.00 149.50 197.50 U-points
0 0.50 33.50 1.00 49.50 V-points
1 33.50 66.50 1.00 49.50 V-points
2 66.50 99.50 1.00 49.50 V-points
3 99.50 132.50 1.00 49.50 V-points
4 132.50 165.50 1.00 49.50 V-points
5 165.50 198.50 1.00 49.50 V-points
6 198.50 231.50 1.00 49.50 V-points
7 231.50 264.50 1.00 49.50 V-points
8 264.50 296.50 1.00 49.50 V-points
9 0.50 33.50 49.50 99.50 V-points
10 33.50 66.50 49.50 99.50 V-points
11 66.50 99.50 49.50 99.50 V-points
12 99.50 132.50 49.50 99.50 V-points
13 132.50 165.50 49.50 99.50 V-points
14 165.50 198.50 49.50 99.50 V-points
15 198.50 231.50 49.50 99.50 V-points
16 231.50 264.50 49.50 99.50 V-points
17 264.50 296.50 49.50 99.50 V-points
18 0.50 33.50 99.50 149.50 V-points
19 33.50 66.50 99.50 149.50 V-points
20 66.50 99.50 99.50 149.50 V-points
21 99.50 132.50 99.50 149.50 V-points
22 132.50 165.50 99.50 149.50 V-points
23 165.50 198.50 99.50 149.50 V-points
24 198.50 231.50 99.50 149.50 V-points
25 231.50 264.50 99.50 149.50 V-points
26 264.50 296.50 99.50 149.50 V-points
27 0.50 33.50 149.50 197.00 V-points
28 33.50 66.50 149.50 197.00 V-points
29 66.50 99.50 149.50 197.00 V-points
30 99.50 132.50 149.50 197.00 V-points
31 132.50 165.50 149.50 197.00 V-points
32 165.50 198.50 149.50 197.00 V-points
33 198.50 231.50 149.50 197.00 V-points
34 231.50 264.50 149.50 197.00 V-points
35 264.50 296.50 149.50 197.00 V-points
HaloSizeI(1) = 90
HaloSizeJ(1) = 124
TileSide(1) = 56
TileSize(1) = 2184
Tracer Advection Scheme: NLM
Variable Grid Horizontal Vertical
temp 1 Upstream3 Centered4
salt 1 Upstream3 Centered4
Akima4 Fourth-order Akima advection
Centered2 Second-order centered differences advection
Centered4 Fourth-order centered differences advection
HSIMT Third High-order Spatial Inteporlation at Middle Time Advection with TVD limiter
MPDATA Multidimensional Positive Definite Advection Algorithm, recursive method
Splines Conservative Parabolic Splines Reconstruction Advection (only vertical; not recommended)
Split_U3 Split third-order Upstream Advection
Upstream3 Third-order Upstream-biased Advection (only horizontal)
zeta 1 Closed Radiation Radiation Closed
ubar 1 Closed Radiation Radiation Closed
vbar 1 Closed Radiation Radiation Closed
u 1 Closed Radiation Radiation Closed
v 1 Closed Radiation Radiation Closed
temp 1 Closed Radiation Radiation Closed
salt 1 Closed Radiation Radiation Closed
ANA_BSFLUX Analytical kinematic bottom salinity flux
ANA_FSOBC Analytical free-surface boundary conditions
ANA_INITIAL Analytical initial conditions
ANA_M2OBC Analytical 2D momentum boundary conditions
ANA_SMFLUX Analytical kinematic surface momentum flux
ANA_SSFLUX Analytical kinematic surface salinity flux
ANA_STFLUX Analytical kinematic surface temperature flux
AVERAGES Writing out time-averaged nonlinear model fields
!BOUNDARY_ALLGATHER Using mpi_allreduce in mp_boundary routine
!COLLECT_ALL... Using mpi_isend/mpi_recv in mp_collect routine
DIAGNOSTICS_TS Computing and writing tracer diagnostic terms
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms
DJ_GRADPS Parabolic Splines density Jacobian (Shchepetkin, 2002)
DOUBLE_PRECISION Double precision arithmetic numerical kernel.
LIMIT_BSTRESS Limit bottom stress to maintain bottom velocity direction
MASKING Land/Sea masking
MIX_S_TS Mixing of tracers along constant S-surfaces
MIX_S_UV Mixing of momentum along constant S-surfaces
MPI MPI distributed-memory configuration
NONLINEAR Nonlinear Model
!NONLIN_EOS Linear Equation of State for seawater
RAMP_TIDES Ramping tidal forcing for one day
REDUCE_ALLREDUCE Using mpi_allreduce in mp_reduce routine
SALINITY Using salinity
SSH_TIDES Add tidal elevation to SSH climatology
TS_DIF2 Harmonic mixing of tracers
UV_ADV Advection of momentum
UV_COR Coriolis term
UV_LDRAG Linear bottom stress
UV_TIDES Add tidal currents to 2D momentum climatologies
WET_DRY Wetting and drying activated
Process Information:
Node # 0 (pid= 15974) is active.
Node # 1 (pid= 15975) is active.
Node # 2 (pid= 15976) is active.
Node # 3 (pid= 15977) is active.
Node # 4 (pid= 15978) is active.
Node # 5 (pid= 15979) is active.
Node # 6 (pid= 15980) is active.
Node # 7 (pid= 15981) is active.
Node # 10 (pid= 15984) is active.
Node # 11 (pid= 15985) is active.
Node # 12 (pid= 15986) is active.
Node # 13 (pid= 15987) is active.
Node # 14 (pid= 15988) is active.
Node # 15 (pid= 15989) is active.
Node # 16 (pid= 15990) is active.
Node # 17 (pid= 15991) is active.
Node # 18 (pid= 15992) is active.
Node # 19 (pid= 15993) is active.
Node # 20 (pid= 15994) is active.
Node # 21 (pid= 15995) is active.
Node # 22 (pid= 15996) is active.
Node # 23 (pid= 15997) is active.
Node # 24 (pid= 15998) is active.
Node # 25 (pid= 15999) is active.
Node # 27 (pid= 16001) is active.
Node # 28 (pid= 16002) is active.
Node # 29 (pid= 16003) is active.
Node # 30 (pid= 16004) is active.
Node # 31 (pid= 16005) is active.
Node # 32 (pid= 16006) is active.
Node # 33 (pid= 16007) is active.
Node # 34 (pid= 16008) is active.
Node # 35 (pid= 16009) is active.
Node # 26 (pid= 16000) is active.
Node # 8 (pid= 15982) is active.
Node # 9 (pid= 15983) is active.
GET_GRID - bathymetry at RHO-points: h
(Grid = 01, File: Persian_roms_grid.nc)
(Min = 1.86978871E+00 Max = 3.47617100E+03)
GET_GRID - Coriolis parameter at RHO-points: f
(Min = 5.69842278E-05 Max = 7.40193949E-05)
GET_GRID - reciprocal XI-grid spacing: pm
(Min = 2.18316466E-04 Max = 2.33234175E-04)
GET_GRID - reciprocal ETA-grid spacing: pn
(Min = 2.37580994E-04 Max = 2.37580994E-04)
GET_GRID - x-location of RHO-points: x-rho
(Min = -7.23213034E+05 Max = 7.23213034E+05)
GET_GRID - y-location of RHO-points: y_rho
(Min = -2.74066636E+06 Max = -1.84531373E+06)
GET_GRID - x-location of PSI-points: x_psi
(Min = -7.20591582E+05 Max = 7.20591582E+05)
GET_GRID - y-location of PSI-points: y-psi
(Min = -2.73842625E+06 Max = -1.84763986E+06)
GET_GRID - x-location of U-points: x_u
(Min = -7.20783957E+05 Max = 7.20783957E+05)
GET_GRID - y-location of U-points: y_u
(Min = -2.74066636E+06 Max = -1.84550147E+06)
GET_GRID - x-location of V-points: x_v
(Min = -7.23020011E+05 Max = 7.23020011E+05)
GET_GRID - y-location of V-points: y_v
(Min = -2.73842625E+06 Max = -1.84745207E+06)
GET_GRID - latitude of RHO-points lat_rho
(Min = 2.30000000E+01 Max = 3.05000000E+01)
GET_GRID - longitude of RHO-points: lon_rho
(Min = 4.77000000E+01 Max = 6.10000000E+01)
GET_GRID - latitude of PSI-points lat_psi
(Min = 2.30189394E+01 Max = 3.04810606E+01)
GET_GRID - longitude of PSI-points: lon_psi
(Min = 4.77223906E+01 Max = 6.09776094E+01)
GET_GRID - latitude of U-points: lat_u
GET_GRID - longitude of U-points: lon_u
GET_GRID - latitude of V-points: lat_v
GET_GRID - longitude of V-points: lon_v
GET_GRID - mask on RHO-points: mask_rho
(Min = 0.00000000E+00 Max = 1.00000000E+00)
GET_GRID - mask on U-points: mask_u
GET_GRID - mask on V-points: mask_v
GET_GRID - mask on PSI-points: mask_psi
(Min = 0.00000000E+00 Max = 2.00000000E+00)
GET_GRID - angle between XI-axis and EAST: angler
30 0.0000000 0.0000000 0.000 0.000 0.000 0.000
29 -0.0333333 -0.0009981 -0.053 -0.172 -2.057 -3.792
28 -0.0666667 -0.0020363 -0.106 -0.344 -4.184 -7.723
27 -0.1000000 -0.0031562 -0.158 -0.516 -6.452 -11.937
26 -0.1333333 -0.0044028 -0.211 -0.689 -8.939 -16.591
25 -0.1666667 -0.0058261 -0.264 -0.862 -11.731 -21.856
24 -0.2000000 -0.0074832 -0.317 -1.037 -14.928 -27.933
23 -0.2333333 -0.0094406 -0.370 -1.214 -18.644 -35.050
22 -0.2666667 -0.0117770 -0.424 -1.392 -23.015 -43.480
21 -0.3000000 -0.0145859 -0.477 -1.573 -28.203 -53.549
20 -0.3333333 -0.0179803 -0.530 -1.757 -34.404 -65.647
19 -0.3666667 -0.0220963 -0.584 -1.944 -41.852 -80.246
18 -0.4000000 -0.0270990 -0.638 -2.135 -50.833 -97.919
17 -0.4333333 -0.0331894 -0.692 -2.333 -61.696 -119.362
16 -0.4666667 -0.0406117 -0.747 -2.536 -74.861 -145.422
15 -0.5000000 -0.0496640 -0.802 -2.748 -90.844 -177.131
14 -0.5333333 -0.0607094 -0.858 -2.970 -110.274 -215.749
13 -0.5666667 -0.0741913 -0.914 -3.204 -133.917 -262.812
12 -0.6000000 -0.0906508 -0.972 -3.453 -162.708 -320.196
11 -0.6333333 -0.1107484 -1.030 -3.720 -197.790 -390.191
10 -0.6666667 -0.1352907 -1.090 -4.010 -240.557 -475.592
9 -0.7000000 -0.1652627 -1.151 -4.326 -292.712 -579.814
8 -0.7333333 -0.2018673 -1.215 -4.676 -356.336 -707.025
7 -0.7666667 -0.2465736 -1.280 -5.066 -433.968 -862.318
6 -0.8000000 -0.3011757 -1.349 -5.506 -528.710 -1051.912
5 -0.8333333 -0.3678650 -1.421 -6.006 -644.353 -1283.403
4 -0.8666667 -0.4493181 -1.498 -6.580 -785.523 -1566.068
3 -0.9000000 -0.5488038 -1.579 -7.244 -957.873 -1911.238
2 -0.9333333 -0.6703150 -1.668 -8.018 -1168.307 -2332.752
1 -0.9666667 -0.8187283 -1.764 -8.927 -1425.256 -2847.515
0 -1.0000000 -1.0000000 -1.870 -10.000 -1739.020 -3476.171
Time Splitting Weights for Grid 01: ndtfast = 3 nfast = 4
1 0.0558333333428837 0.3333333333332940 0.0558333333428837 0.3333333333332940
2 0.2149999999995108 0.3147222222190016 0.2708333333423945 0.6480555555522955
3 0.4024999999719729 0.2430555555525065 0.6733333333143674 0.8911111111048020
4 0.3266666666856327 0.1088888888951980 1.0000000000000000 1.0000000000000000
ndtfast, nfast = 3 4 nfast/ndtfast = 1.33333
1.000000000000 1.085000000007 0.542500000003 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.00000
Minimum X-grid spacing, DXmin = 4.28753633E+00 km Water points = 4.29917804E+00 km
Maximum X-grid spacing, DXmax = 4.58050654E+00 km Water points = 4.58050654E+00 km
Minimum Y-grid spacing, DYmin = 4.20909091E+00 km Water points = 4.20909091E+00 km
Maximum Y-grid spacing, DYmax = 4.20909091E+00 km Water points = 4.20909091E+00 km
Minimum Z-grid spacing, DZmin = 5.28023281E-02 m Water points = 5.58882656E-02 m
Maximum Z-grid spacing, DZmax = 6.28656359E+02 m Water points = 6.28656359E+02 m
Minimum barotropic Courant Number = 7.24874895E-03
Maximum barotropic Courant Number = 2.98941489E-01
Maximum Coriolis Courant Number = 1.10155619E-03
(Grid = 01, Min = 1.40000000E+01 Max = 2.19957770E+01)
ANA_INITIAL - salinity: salt
(Grid = 01, Min = 3.50000000E+01 Max = 3.50000000E+01)
GET_NGFLD - tidal period
(Grid = 01, Min = 2.19720215E+04 Max = 2.38071489E+06)
(Grid = 01, Min = -1.23526398E-14 Max = 8.75923031E-01)
(Grid = 01, Min = -5.49838079E+00 Max = 8.47757976E+00)
(Grid = 01, Min = 0.00000000E+00 Max = 6.28317385E+00)
(Grid = 01, Min = 0.00000000E+00 Max = 6.28316977E+00)
(Grid = 01, Min = 0.00000000E+00 Max = 6.48205227E-01)
(Grid = 01, Min = -1.94831549E-01 Max = 2.54299358E-01)
Maximum grid stiffness ratios: rx0 = 8.094842E-01 (Beckmann and Haidvogel)
rx1 = 1.565248E+01 (Haney)
Initial domain volumes: TotVolume = 1.7663437614E+14 m3
MinCellVol = 1.0197991434E+06 m3
MaxCellVol = 1.1942855421E+10 m3
Max/Min = 1.1710987893E+04
7360 2012-10-29 18:40:00.00 3.382645E-01 1.202837E+04 1.202871E+04 1.781154E+14
(231,058,30) 5.546413E-03 3.282268E-03 4.716395E+01 1.102684E+01
7361 2012-10-29 18:40:15.00 3.248345E-01 1.202846E+04 1.202879E+04 1.781171E+14
(231,058,30) 4.944411E-03 2.938754E-03 5.116505E+01 1.101317E+01
7362 2012-10-29 18:40:30.00 3.311236E-01 1.202853E+04 1.202886E+04 1.781190E+14
(226,061,30) 4.219131E-03 1.991485E-03 4.882558E+01 1.098131E+01
7363 2012-10-29 18:40:45.00 3.514411E-01 1.202864E+04 1.202899E+04 1.781216E+14
(226,061,30) 5.287721E-03 1.984694E-03 4.620421E+01 1.093203E+01
7364 2012-10-29 18:41:00.00 3.661830E-01 1.202879E+04 1.202916E+04 1.781246E+14
(222,030,30) 8.704506E-04 1.984459E-03 4.140152E+01 1.086639E+01
7365 2012-10-29 18:41:15.00 3.613346E-01 1.202898E+04 1.202934E+04 1.781277E+14
(217,031,30) 1.188826E-04 3.934099E-03 3.474698E+01 1.078582E+01
7366 2012-10-29 18:41:30.00 3.422162E-01 1.202917E+04 1.202951E+04 1.781308E+14
(290,055,30) 6.375751E-03 2.577218E-03 4.430922E+01 1.069207E+01
7367 2012-10-29 18:41:45.00 3.278931E-01 1.202934E+04 1.202967E+04 1.781341E+14
(290,055,30) 5.785064E-03 1.180376E-03 4.433389E+01 1.058723E+01
7368 2012-10-29 18:42:00.00 3.316144E-01 1.202947E+04 1.202980E+04 1.781374E+14
(219,061,30) 3.756705E-03 2.511664E-03 4.667482E+01 1.047369E+01
7369 2012-10-29 18:42:15.00 3.483822E-01 1.202954E+04 1.202988E+04 1.781404E+14
(219,061,30) 4.099640E-03 1.219892E-03 4.800742E+01 1.035414E+01
7370 2012-10-29 18:42:30.00 3.615934E-01 1.202957E+04 1.202993E+04 1.781428E+14
(226,060,30) 4.365490E-03 1.548314E-04 3.778717E+01 1.023151E+01
7371 2012-10-29 18:42:45.00 3.597649E-01 1.202964E+04 1.203000E+04 1.781451E+14
(208,042,30) 4.137802E-04 1.567138E-03 3.598323E+01 1.010889E+01
Found Error: 01 Line: 315 Source: ROMS/Nonlinear/main3d.F
Found Error: 01 Line: 303 Source: ROMS/Drivers/nl_ocean.h, ROMS_run
REASON: MaxDensity = 9.2E+02
WRT_RST - wrote re-start fields (Index=1,2) in record = 3
Node # 0 CPU: 2011.695
Node # 1 CPU: 2104.411
Node # 2 CPU: 2085.632
Node # 3 CPU: 2105.727
Node # 4 CPU: 2105.241
Node # 5 CPU: 2044.155
Node # 6 CPU: 2103.442
Node # 7 CPU: 2098.814
Node # 8 CPU: 2106.134
Node # 9 CPU: 2105.983
Node # 10 CPU: 2104.696
Node # 11 CPU: 2104.578
Node # 12 CPU: 2105.703
Node # 13 CPU: 2089.597
Node # 14 CPU: 2106.216
Node # 15 CPU: 2104.822
Node # 16 CPU: 2105.390
Node # 17 CPU: 2105.465
Node # 18 CPU: 2081.495
Node # 19 CPU: 2105.477
Node # 20 CPU: 2087.576
Node # 21 CPU: 2105.457
Node # 22 CPU: 2105.259
Node # 23 CPU: 2086.149
Node # 24 CPU: 2071.530
Node # 25 CPU: 2096.574
Node # 26 CPU: 2106.401
Node # 27 CPU: 2106.110
Node # 28 CPU: 2105.914
Node # 29 CPU: 2104.901
Node # 30 CPU: 2105.715
Node # 31 CPU: 2104.445
Node # 32 CPU: 2105.697
Node # 33 CPU: 2105.275
Node # 34 CPU: 2105.748
Node # 35 CPU: 2105.149
Total: 75492.572
Average: 2097.016
Minimum: 2011.695
Maximum: 2106.401
Allocation and array initialization .............. 5.881 ( 0.0078 %)
Ocean state initialization ....................... 0.743 ( 0.0010 %)
Reading of input data ............................ 14.296 ( 0.0189 %)
Processing of input data ......................... 281.244 ( 0.3725 %)
Processing of output time averaged data .......... 10469.466 (13.8682 %)
Computation of vertical boundary conditions ...... 57.113 ( 0.0757 %)
Computation of global information integrals ...... 770.025 ( 1.0200 %)
Writing of output data ........................... 17555.355 (23.2544 %)
Model 2D kernel .................................. 7408.343 ( 9.8133 %)
Tidal forcing .................................... 1492.521 ( 1.9770 %)
2D/3D coupling, vertical metrics ................. 1654.458 ( 2.1916 %)
Omega vertical velocity .......................... 984.658 ( 1.3043 %)
Equation of state for seawater ................... 831.253 ( 1.1011 %)
3D equations right-side terms .................... 3756.312 ( 4.9757 %)
3D equations predictor step ...................... 9434.468 (12.4972 %)
Pressure gradient ................................ 1416.116 ( 1.8758 %)
Harmonic mixing of tracers, S-surfaces ........... 1105.157 ( 1.4639 %)
Harmonic stress tensor, S-surfaces ............... 1010.786 ( 1.3389 %)
Corrector time-step for 3D momentum .............. 9252.722 (12.2565 %)
Corrector time-step for tracers .................. 7012.643 ( 9.2892 %)
Total: 74513.559 98.7032 %
Unique kernel(s) regions profiled ................ 74513.559 98.7032 %
Residual, non-profiled code ...................... 979.012 1.2968 %
All percentages are with respect to total time = 75492.572
MPI communications profile, Grid: 01
Message Passage: 2D halo exchanges ............... 3358.061 ( 4.4482 %)
Message Passage: 3D halo exchanges ............... 2212.833 ( 2.9312 %)
Message Passage: 4D halo exchanges ............... 1446.070 ( 1.9155 %)
Message Passage: data broadcast .................. 4277.199 ( 5.6657 %)
Message Passage: data reduction .................. 131.596 ( 0.1743 %)
Message Passage: data gathering .................. 5572.557 ( 7.3816 %)
Message Passage: data scattering.................. 8.030 ( 0.0106 %)
Message Passage: point data gathering ............ 0.002 ( 0.0000 %)
Message Passage: synchronization barrier ......... 0.544 ( 0.0007 %)
Total: 17006.890 22.5279 %
Dynamic and Automatic memory (MB) usage for Grid 01: 296x197x30 tiling: 9x4
tile Dynamic Automatic USAGE MPI-Buffers
0 69.04 29.41 98.45 19.50
1 70.93 29.41 100.34 19.50
2 70.93 29.41 100.34 19.50
3 70.93 29.41 100.34 19.50
4 70.93 29.41 100.34 19.50
5 70.93 29.41 100.34 19.50
6 70.93 29.41 100.34 19.50
7 70.93 29.41 100.34 19.50
8 69.04 29.41 98.45 19.50
9 71.66 29.41 101.07 19.50
10 73.62 29.41 103.03 19.50
11 73.62 29.41 103.03 19.50
12 73.62 29.41 103.03 19.50
13 73.62 29.41 103.03 19.50
14 73.62 29.41 103.03 19.50
15 73.62 29.41 103.03 19.50
16 73.62 29.41 103.03 19.50
17 71.66 29.41 101.07 19.50
18 71.66 29.41 101.07 19.50
19 73.62 29.41 103.03 19.50
20 73.62 29.41 103.03 19.50
21 73.62 29.41 103.03 19.50
22 73.62 29.41 103.03 19.50
23 73.62 29.41 103.03 19.50
24 73.62 29.41 103.03 19.50
25 73.62 29.41 103.03 19.50
26 71.66 29.41 101.07 19.50
27 67.73 29.41 97.15 19.50
28 69.59 29.41 99.00 19.50
29 69.59 29.41 99.00 19.50
30 69.59 29.41 99.00 19.50
31 69.59 29.41 99.00 19.50
32 69.59 29.41 99.00 19.50
33 69.59 29.41 99.00 19.50
34 69.59 29.41 99.00 19.50
35 67.73 29.41 97.15 19.50
TOTAL 2574.46 1058.90 3633.35 701.96
number of time records written in HISTORY file = 103
number of time records written in RESTART file = 26
number of time records written in AVERAGE file = 102
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_fsobc.h
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_smflux.h
ROMS/Functionals/ana_stflux.h
SVN Revision : 1061
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
of State.
0 1 33 1 49 48510
1 34 66 1 49 48510
2 67 99 1 49 48510
9 1 33 50 99 49500
HaloSizeI(1) = 90
HaloSizeJ(1) = 124
TileSide(1) = 56
TileSize(1) = 2184
Total: 75492.572
Average: 2097.016
Minimum: 2011.695
Maximum: 2106.401
