Hello, i upgrade ROMS to the new version:
run the build_roms_4dvshc.csh file. (gfortran and openmpi)
I have made the libarpack.a and libparpack.a, also have checked my bash.csh .h and .mk files. But still with some trouble like this:
cd /research/home/wuting/test2/Tscompile/Build_roms; /research/home/wuting/software/openmpi-1.6.5/openmpi/bin/mpif90 -c -frepack-arrays -O3 -ffast-math get_hash.f90
get_hash.f90:187.19:
k=IEOR(SHIFTR(k, 1), -306674912_i8b)
1
Error: Function 'shiftr' at (1) has no IMPLICIT type
get_hash.f90:189.14:
k=SHIFTR(k, 1_i8b)
1
get_hash.f90:162.18:
hash=IEOR(SHIFTR(hash, 8_i8b), &
1
By the way, I can't find the ROMS/Utility/get_hash.f90 in the Past version
Any help or suggestion will be highly appreciated.
I4dvar compilation error in new version about get_hash.f90
- wc13.h
- (4.96 KiB) Downloaded 404 times
- Linux-gfortran.mk
- (11.9 KiB) Downloaded 413 times
Re: I4dvar compilation error in new version about get_hash.f90
Yes, your Fortran compiler is too old and not supporting updates to the standard. The intrinsic function SHIFTR was introduced more than a decade ago in the Fortran 2008 Standard. What compiler are you using?
It is highly recommended to keep Fortran compilers up-to-date. Models nowadays use Object Oriented Programming (OOP) and libraries need such updates to be efficient.
Thanks a lot for your fast answer!
my gfortran compiler version is too old.
Thank you !
Thank you !
