blowing up error
javadi
blowing up error
#1 Unread post by javadi »
Dear users,
I have faced blowing up when running a model based on my domain. I have made my all grid, initial, and forcing files. In the upwelling example, I added my input files and I started running the model. The model has faced blowing up after 5-time steps without any changing in upwelling.in(dt=300). I have changed my dt to 150 s, the model ran for 12-time steps,s and the model run for 25 timesteps after decreasing dt to 75 s. Surprisingly, I have considered dt=15 and 5 s but the model have faced this problem after only 3 timesteps. It means that the dt=75 s is the best choice for me in this case. Without my forcing file, I have faced blowing up too.
Please help with your interesting comments.
Tuesday - December 15, 2020 - 11:44:08 AM
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler flags : -frepack-arrays -O3 -ffast-math -
SVN Revision : 1042
Local Root : /home/jav/Roms/trunk
Header Dir : /home/jav/Test
Header file : upwelling.h
Analytical Dir : /home/javi/Test
Resolution, Grid 01: 236x405x32, Parallel Threads: 1, Tiling: 1x1
10.000 dt Timestep size (s) for 3-D equations.
into restart fields.
to standard output.
into history file.
into quicksave file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
72 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
(m2/s) for momentum.
for tracer 02: salt
7.0000E+00 theta_s S-coordinate surface control parameter.
2.0000E+00 theta_b S-coordinate bottom control parameter.
200.000 Tcline S-coordinate surface/bottom layer width (m) used
20180101.06 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
for 3D momentum.
of State.
T Dout(M2rate) Write out 2D momentum acceleration.
T Dout(M2pgrd) Write out 2D momentum pressure gradient.
T Dout(M2fcor) Write out 2D momentum Coriolis force.
T Dout(M2hadv) Write out 2D momentum horizontal advection.
T Dout(M2xadv) Write out 2D momentum horizontal X-advection.
T Dout(M2yadv) Write out 2D momentum horizontal Y-advection.
T Dout(M2hvis) Write out 2D momentum horizontal viscosity.
T Dout(M2xvis) Write out 2D momentum horizontal X-viscosity.
T Dout(M2yvis) Write out 2D momentum horizontal Y-viscosity.
T Dout(M2sstr) Write out 2D momentum surface stress.
T Dout(M2bstr) Write out 2D momentum bottom stress.
T Dout(M3rate) Write out 3D momentum acceleration.
Output Restart File: roms_rst.nc
Output History File: roms_his.nc
Output Averages File: roms_avg.nc
Output Diagnostics File: roms_dia.nc
Input Grid File: croco_grd.nc
Input Nonlinear Initial File: croco_ini.nc
Input Forcing File 01: gom_cloud_era.nc
Input Forcing File 02: gom_latent_era.nc
Input Forcing File 03: gom_lwrad_era.nc
Input Forcing File 04: gom_Pair_era.nc
Input Forcing File 05: gom_Qair_era.nc
Input Forcing File 06: gom_rain_era.nc
Input Forcing File 07: gom_sensible_era.nc
Input Forcing File 08: gom_shflux_era.nc
Input Forcing File 09: gom_sms_era.nc
Input Forcing File 10: gom_swflux_era.nc
Input Forcing File 11: gom_swrad_era.nc
Input Forcing File 12: gom_Tair_era.nc
Input Forcing File 13: gom_wind_era.nc
ROMS I/O variables Metadata File: varinfo.dat
Tile partition information for Grid 01: 236x405x32 tiling: 1x1
tile Istr Iend Jstr Jend Npts
0 1 236 1 405 3058560
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 -1.50 238.50 0.50 405.50 RHO-points
0 -2.00 238.00 0.50 405.50 U-points
0 -1.50 238.50 0.00 405.00 V-points
Tracer Advection Scheme: NLM
Variable Grid Horizontal Vertical
temp 1 Upstream3 Centered4
salt 1 Upstream3 Centered4
Akima4 Fourth-order Akima advection
Centered2 Second-order centered differences advection
Centered4 Fourth-order centered differences advection
HSIMT Third High-order Spatial Inteporlation at Middle Time Advection with TVD limiter
MPDATA Multidimensional Positive Definite Advection Algorithm, recursive method
Splines Conservative Parabolic Splines Reconstruction Advection (only vertical; not recommended)
Split_U3 Split third-order Upstream Advection
Upstream3 Third-order Upstream-biased Advection (only horizontal)
zeta 1 Periodic Closed Periodic Closed
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
ANA_BSFLUX Analytical kinematic bottom salinity flux
ANA_SSFLUX Analytical kinematic surface salinity flux
ANA_STFLUX Analytical kinematic surface temperature flux
ANA_VMIX Analytical vertical mixing coefficients
AVERAGES Writing out time-averaged nonlinear model fields
DIAGNOSTICS_TS Computing and writing tracer diagnostic terms
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms
DJ_GRADPS Parabolic Splines density Jacobian (Shchepetkin, 2002)
DOUBLE_PRECISION Double precision arithmetic numerical kernel.
MIX_S_TS Mixing of tracers along constant S-surfaces
MIX_S_UV Mixing of momentum along constant S-surfaces
NONLINEAR Nonlinear Model
!NONLIN_EOS Linear Equation of State for seawater
SALINITY Using salinity
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity
TS_DIF2 Harmonic mixing of tracers
UV_ADV Advection of momentum
UV_COR Coriolis term
UV_LDRAG Linear bottom stress
Process Information:
Thread # 0 (pid= 13456) is active.
GET_GRID - angle between XI-axis and EAST: angler
(Grid = 01, File: croco_grd.nc)
(Min = 2.05175782E-04 Max = 2.59455950E-04)
GET_GRID - bathymetry at RHO-points: h
(Min = 7.50000000E+01 Max = 1.21280280E+02)
GET_GRID - Coriolis parameter at RHO-points: f
(Min = 8.57239581E-05 Max = 1.08402615E-04)
GET_GRID - reciprocal XI-grid spacing: pm
(Min = 2.78060917E-04 Max = 3.36270552E-04)
GET_GRID - reciprocal ETA-grid spacing: pn
(Min = 2.78118000E-04 Max = 3.36008921E-04)
GET_GRID - x-location of RHO-points: x-rho
(Min = 0.00000000E+00 Max = 8.52331219E+05)
GET_GRID - x-location of U-points: x_u
(Min = 1.48689797E+03 Max = 8.50533052E+05)
GET_GRID - x-location of V-points: x_v
(Min = 0.00000000E+00 Max = 8.52156273E+05)
GET_GRID - x-location of PSI-points: x_psi
(Min = 1.48728387E+03 Max = 8.50358475E+05)
GET_GRID - y-location of RHO-points: y_rho
(Min = 0.00000000E+00 Max = 1.33494208E+06)
GET_GRID - y-location of U-points: y_u
GET_GRID - y-location of V-points: y_v
(Min = 1.79779806E+03 Max = 1.33345403E+06)
GET_GRID - y-location of PSI-points: y-psi
GET_GRID - longitude of RHO-points: lon_rho
(Min = 4.60000000E+01 Max = 5.54800000E+01)
GET_GRID - longitude of U-points: lon_u
(Min = 4.60200000E+01 Max = 5.54600000E+01)
GET_GRID - longitude of V-points: lon_v
GET_GRID - longitude of PSI-points: lon_psi
GET_GRID - latitude of RHO-points lat_rho
(Min = 3.60000000E+01 Max = 4.80121300E+01)
GET_GRID - latitude of U-points: lat_u
GET_GRID - latitude of V-points: lat_v
(Min = 3.60161803E+01 Max = 4.79987436E+01)
GET_GRID - latitude of PSI-points lat_psi
32 0.0000000 -0.0000000 -0.000 -0.000 -0.000 -0.000
31 -0.0312500 -0.0005983 -1.717 -2.387 -2.077 -2.387
30 -0.0625000 -0.0017244 -3.444 -4.798 -4.170 -4.798
29 -0.0937500 -0.0036555 -5.188 -7.245 -6.290 -7.245
28 -0.1250000 -0.0068265 -6.958 -9.750 -8.450 -9.750
27 -0.1562500 -0.0119111 -8.766 -12.342 -10.671 -12.342
26 -0.1875000 -0.0199406 -10.635 -15.069 -12.988 -15.069
25 -0.2187500 -0.0324732 -12.596 -18.002 -15.450 -18.002
24 -0.2500000 -0.0518170 -14.696 -21.247 -18.133 -21.247
23 -0.2812500 -0.0812961 -17.004 -24.956 -21.142 -24.956
22 -0.3125000 -0.1254893 -19.612 -29.338 -24.627 -29.338
21 -0.3437500 -0.1902675 -22.642 -34.663 -28.777 -34.663
20 -0.3750000 -0.2822874 -26.229 -41.236 -33.807 -41.236
19 -0.4062500 -0.4074733 -30.494 -49.326 -39.909 -49.326
18 -0.4375000 -0.5682244 -35.486 -59.045 -47.159 -59.045
17 -0.4687500 -0.7600506 -41.115 -70.187 -55.414 -70.187
16 -0.5000000 -0.9698301 -47.110 -82.150 -64.248 -82.150
15 -0.5312500 -1.1781602 -53.076 -94.047 -73.036 -94.047
14 -0.5625000 -1.3655685 -58.614 -104.986 -81.147 -104.986
13 -0.5937500 -1.5187208 -63.451 -114.357 -88.152 -114.357
12 -0.6250000 -1.6327622 -67.488 -121.938 -93.894 -121.938
11 -0.6562500 -1.7095563 -70.764 -127.813 -98.432 -127.813
10 -0.6875000 -1.7542959 -73.383 -132.220 -101.934 -132.220
9 -0.7187500 -1.7726751 -75.464 -135.421 -104.586 -135.421
8 -0.7500000 -1.7693246 -77.100 -137.627 -106.535 -137.627
7 -0.7812500 -1.7472460 -78.353 -138.976 -107.879 -138.976
6 -0.8125000 -1.7077733 -79.250 -139.528 -108.661 -139.528
5 -0.8437500 -1.6507162 -79.787 -139.275 -108.875 -139.275
4 -0.8750000 -1.5745057 -79.933 -138.145 -108.470 -138.145
3 -0.9062500 -1.4762679 -79.628 -136.007 -107.354 -136.007
2 -0.9375000 -1.3518043 -78.787 -132.668 -105.391 -132.668
1 -0.9687500 -1.1954774 -77.294 -127.870 -102.398 -127.870
0 -1.0000000 -1.0000000 -75.000 -121.280 -98.140 -121.280
12 0.0043042707117221 0.0335513677379153-0.0022367614257357 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864347 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001212 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565096 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906203 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716642 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402367 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399431 0.6603333185976138
21 0.0256737146312910 0.0297153720153352 0.1342125541712341 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524357 0.7189082721405746
23 0.0316613792205220 0.0279045862015855 0.1945237931729577 0.7468128583421600
24 0.0346736416507075 0.0268492068942347 0.2291974348236651 0.7736620652363948
25 0.0376471948657328 0.0256934188392112 0.2668446296893979 0.7993554840756060
26 0.0405373376992232 0.0244385123436867 0.3073819673886211 0.8237939964192927
27 0.0432936737565711 0.0230872677537126 0.3506756411451922 0.8468812641730054
28 0.0458596469320356 0.0216441452951603 0.3965352880772278 0.8685254094681656
29 0.0481720587108284 0.0201154903974257 0.4447073467880562 0.8886408998655914
30 0.0501605672561820 0.0185097551070648 0.4948679140442381 0.9071506549726561
31 0.0517471682814030 0.0168377361985254 0.5466150823256412 0.9239883911711815
32 0.0528456577069106 0.0151128305891453 0.5994607400325517 0.9391012217603267
33 0.0533610761022577 0.0133513086655816 0.6528218161348094 0.9524525304259084
34 0.0531891349131379 0.0115726061288397 0.7060109510479473 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213234 0.9738247715198165
36 0.0503158038019031 0.0080591141492892 0.8085423793232265 0.9818838856691057
37 0.0473537721847153 0.0063819206892258 0.8558961515079418 0.9882658063583315
38 0.0431818225418188 0.0048034616164019 0.8990779740497606 0.9930692679747335
39 0.0376397765791564 0.0033640675316746 0.9367177506289170 0.9964333355064081
40 0.0305543017255206 0.0021094083123694 0.9672720523544377 0.9985427438187775
41 0.0217382098544505 0.0010909315881854 0.9890102622088881 0.9996336754069629
42 0.0109897377911119 0.0003663245930371 1.0000000000000000 1.0000000000000000
Minimum X-grid spacing, DXmin = 2.97379593E+00 km
Maximum X-grid spacing, DXmax = 3.59633426E+00 km
Minimum Y-grid spacing, DYmin = 2.97611146E+00 km
Maximum Y-grid spacing, DYmax = 3.59559612E+00 km
Minimum Z-grid spacing, DZmin = -6.59006007E+00 m
Maximum Z-grid spacing, DZmax = 1.19634782E+01 m
Minimum barotropic Courant Number = 3.55584979E-03
Maximum barotropic Courant Number = 5.03180240E-03
Maximum Coriolis Courant Number = 1.08402615E-03
NLM: GET_STATE - Reading state initial conditions, 2018-01-01 01:30:00.00
(Grid 01, t = 0.0000, File: croco_ini.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 7.05641875E-02 Max = 2.01933636E+01)
- salinity
(Min = 1.01258829E+01 Max = 1.46311805E+01)
GET_2DFLD - surface u-momentum stress, 2018-01-01 01:30:00.00
(Grid=01, Rec=1, Index=1, File: gom_sms_era.nc)
(Tmin= 0.0000 Tmax= 30.8750) t = 0.0000
(Min = -1.22882390E-04 Max = 2.05808057E-04) regrid = T
GET_2DFLD - surface v-momentum stress, 2018-01-01 01:30:00.00
(Min = -3.57454272E-05 Max = 3.87079847E-04) regrid = T
Maximum grid stiffness ratios: rx0 = 7.632490E-02 (Beckmann and Haidvogel)
rx1 = 1.934840E+04 (Haney)
Initial domain volumes: TotVolume = 7.7739947385E+13 m3
MinCellVol = -6.8815918813E+07 m3
MaxCellVol = 1.2492719892E+08 m3
Max/Min = -1.8153822702E+00
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 000000000001 - 000000001440)
GET_2DFLD - surface u-momentum stress, 2018-01-01 04:30:00.00
(Grid=01, Rec=2, Index=2, File: gom_sms_era.nc)
(Tmin= 0.0000 Tmax= 30.8750) t = 0.1250
(Min = -1.75362703E-04 Max = 1.57320342E-04) regrid = T
GET_2DFLD - surface v-momentum stress, 2018-01-01 04:30:00.00
(Min = -3.97578254E-05 Max = 4.33428997E-04) regrid = T
0 2018-01-01 01:30:00.00 0.000000E+00 3.691321E+02 3.691321E+02 7.773995E+13
DEF_HIS - creating history file, Grid 01: roms_his.nc
WRT_HIS - wrote history fields (Index=1,1) in record = 1
DEF_AVG - creating average file, Grid 01: roms_avg.nc
DEF_DIAGS - creating diagnostics file, Grid 01: roms_dia.nc
1 2018-01-01 01:30:10.00 2.874661E-09 3.691321E+02 3.691321E+02 7.773995E+13
(147,236,05) 9.764726E-05 1.403401E-05 -0.000000E+00 4.519250E-02
2 2018-01-01 01:30:20.00 -5.907644E-07 3.691321E+02 3.691321E+02 7.773995E+13
(147,236,06) 3.261724E-02 7.156293E-04 3.810380E-03 1.740675E+01
3 2018-01-01 01:30:30.00 -7.108906E-02 3.691321E+02 3.690610E+02 7.773995E+13
(147,236,06) 1.160866E+01 6.953663E-02 1.320967E+00 6.188637E+03
Found Error: 01 Line: 313 Source: ROMS/Nonlinear/main3d.F
Found Error: 01 Line: 300 Source: ROMS/Drivers/nl_ocean.h
REASON: MaxSpeed = 6.2E+03
WRT_RST - wrote re-start fields (Index=1,2) in record = 1
Thread # 0 CPU: 61.562
Total: 61.562
Allocation and array initialization .............. 10.423 (16.9308 %)
Ocean state initialization ....................... 1.948 ( 3.1647 %)
Reading of input data ............................ 0.156 ( 0.2528 %)
Processing of input data ......................... 0.084 ( 0.1357 %)
Processing of output time averaged data .......... 13.829 (22.4642 %)
Computation of vertical boundary conditions ...... 0.004 ( 0.0073 %)
Computation of global information integrals ...... 0.383 ( 0.6225 %)
Writing of output data ........................... 1.327 ( 2.1562 %)
Model 2D kernel .................................. 9.668 (15.7039 %)
2D/3D coupling, vertical metrics ................. 0.449 ( 0.7291 %)
Omega vertical velocity .......................... 0.141 ( 0.2291 %)
Equation of state for seawater ................... 0.254 ( 0.4132 %)
3D equations right-side terms .................... 2.974 ( 4.8307 %)
3D equations predictor step ...................... 7.901 (12.8342 %)
Pressure gradient ................................ 1.611 ( 2.6167 %)
Harmonic mixing of tracers, S-surfaces ........... 1.014 ( 1.6467 %)
Harmonic stress tensor, S-surfaces ............... 0.813 ( 1.3212 %)
Corrector time-step for 3D momentum .............. 2.695 ( 4.3779 %)
Corrector time-step for tracers .................. 3.327 ( 5.4040 %)
Total: 59.002 95.8409 %
Unique kernel(s) regions profiled ................ 59.002 95.8409 %
Residual, non-profiled code ...................... 2.560 4.1591 %
All percentages are with respect to total time = 61.562
Dynamic and Automatic memory (MB) usage for Grid 01: 236x405x32 tiling: 1x1
tile Dynamic Automatic USAGE
0 3724.86 184.06 3908.92
TOTAL 3724.86 184.06 3908.92
number of time records written in HISTORY file = 1
number of time records written in RESTART file = 1
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_stflux.h
ROMS/Functionals/ana_vmix.h
Note: The following floating-point exceptions are signalling: IEEE_INVALID_FLAG IEEE_DIVIDE_BY_ZERO
ERROR STOP
Error termination. Backtrace:
#0 0x7efd361ffdf1 in ???
#1 0x7efd36200939 in ???
#2 0x7efd36202047 in ???
#3 0x403994 in ???
#4 0x7efd35e61041 in ???
#5 0x4039ed in ???
#6 0xffffffffffffffff in ???
[root@localhost Test]#
roms_rst.nc
(8.87 MiB) Downloaded 1124 times
roms_his.nc
(81.58 MiB) Downloaded 1299 times
Re: blowing up error
This is when you need to start looking at the model's netCDF output as well as just the text. Where is the model blowing up and in what way? Is it a boundary problem or not?
hezhi
#3 Unread post by hezhi »
hi kate
The surface velocity is always 1.4 m/s at boundary。I want to konw whether .h file is important for simulation or not。For example I choose TS_U3HADVECTION and
TS_A4HADVECTION or TS_A4VADVECTION and TS_C4VADVECTION.THere are different for result u and result v?I am newer。
good luck
You don't have an open boundary. Where is the velocity always 1.4 m/s? Do you expect it to be less? Is that where the blow-up is happening or not? Actually, it reports: REASON: MaxSpeed = 6.2E+03
Rather a larger velocity. So where is that and why?
I usually use U3H advection and some fourth-order vertical advection. I use the new HSIMT for bio tracers to keep them well-behaved. My typical mode of blowing up is a vertical advection problem, mid-depth, something that can be fixed with a smaller timestep.
Your cppdefs look fine except that I would only use MIX_S_TS over a flat bottom. Try one of the rotated mixing tensor options instead.
If you want, you can try a quadratic bottom drag if you turn on the bottom drag limiter. I forget, is that an option in Hernan's code? It should be.
javadi
#5 Unread post by javadi »
Dear kate and hezi
I try to run upwelling example and here is my upwelling.h file. I guess that the problem comes from my initial condition. Without initial condition, the model ran without any problem using ANA file. Surprisingly, when I apply my grid file, the minimum z grid and minimum volume are positive. However, after using the initial condition both parameters are negative(?).
Sincerely Javad Babagoli
upwelling.h
(1.65 KiB) Downloaded 1059 times
roms_ini.nc
(96.65 MiB) Downloaded 1362 times
#6 Unread post by kate »
I bet you have some vertically unstable T and S profiles. If they are what you want, you should turn on a vertical mixing scheme like GLS or LMD.
javadi
#7 Unread post by javadi »
Dear kate
Thank you so much for your response. I have another question in this case. As there is not GLS or LMD flags in my upwelling.h, I should copy this flag in cppdefs and add this flag in my upwelling.h like this:
#define LMD_MIXING
Or should I another action.
Please help me in this case
#8 Unread post by kate »
Yes, exactly. However, you know how you have the #ifdef GLS_MIXING... section? Here's what I have for LMD:
# define LMD_MIXING
# ifdef LMD_MIXING
#  define LMD_RIMIX
#  define LMD_CONVEC
#  define LMD_SKPP
#  define LI_FOX_KEMPER
#  undef LMD_BKPP
#  define LMD_NONLOCAL
#  define LMD_SHAPIRO
#  define LMD_DDMIX
#  define LIMIT_VDIFF
You might want to turn off DDMIX (double diffusion), depending. Oh, and I believe the trunk code won't have LI_FOX_KEMPER.
javadi
#9 Unread post by javadi »
Dear Kate
Thank you so much for your cooperation. I have applied your suggestion and I have changed my upwelling.h. However, I have faced this error:
CHECKDEFS - only one vertical closure scheme is allowed.
Found Error: 05 Line: 1255 Source: ROMS/Utility/inp_par.F
Found Error: 05 Line: 112 Source: ROMS/Drivers/nl_ocean.h
upwelling.h file:
** svn $Id: upwelling.h 1001 2020-01-10 22:41:16Z arango $
** Copyright (c) 2002-2020 The ROMS/TOMS Group **
** See License_ROMS.txt **
** Options for Upwelling Test.
** Application flag: UPWELLING
** Input script: roms_upwelling.in
#define UV_LDRAG
#undef MIX_GEO_UV
#define SPLINES_VDIFF
#define SPLINES_VVISC
#undef TS_DIF4
#undef MIX_GEO_TS
#define MIX_S_TS
# define LMD_MIXING
# ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# define LMD_SKPP
# undef LMD_BKPP
# define LMD_DDMIX
#define DIAGNOSTICS_TS
#define DIAGNOSTICS_UV
#undef ANA_GRID
#undef ANA_INITIAL
#undef ANA_SMFLUX
#define ANA_STFLUX
#define ANA_SSFLUX
# define RI_SPLINES
#else
# define ANA_VMIX
#if defined BIO_FENNEL || defined ECOSIM || \
defined NPZD_POWELL || defined NEMURO
# define ANA_BIOLOGY
# define ANA_SPFLUX
# define ANA_BPFLUX
# define ANA_SRFLUX
#if defined NEMURO
# define HOLLING_GRAZING
# undef IVLEV_EXPLICIT
#ifdef BIO_FENNEL
# define CARBON
# define DENITRIFICATION
# define BIO_SEDIMENT
# define DIAGNOSTICS_BIO
#ifdef PERFECT_RESTART
# undef AVERAGES
# undef DIAGNOSTICS_BIO
# undef DIAGNOSTICS_TS
# undef DIAGNOSTICS_UV
# define OUT_DOUBLE
#10 Unread post by wilkin »
You have defined LMD_MIXING, but then you also have this block of definitions ...
# define RI_SPLINES
#else
# define ANA_VMIX
The else clause activates #define ANA_VMIX, so you have a conflict, both LMD_MIXING and ANA_VMIX are defined, hence the error from CHECKDEFS.
javadi
#11 Unread post by javadi »
Dear wikin
Thank you so much for your help.I have reformed my .h based on new conditions and I have turned ANA_VMIX off but the model is unstable too.
#12 Unread post by wilkin »
Is this supposed to a real ocean, or something idealized? You have some odd looking ranges of initial temperature and salinity:
- salinity
0.7 C to 20 C for temperature.
10 to 14 for salinity.
Are these backwards?
javadi
#13 Unread post by javadi »
Dear wikin
Yes. It is a real area. The values for temperature and salinity are correct based on my previous experiences.
javadi
#14 Unread post by javadi »
It can lead to instability as we do not consider ice in the model(?)The water converts to ice when the temperature is approximately zero. The observation supports this; however, in the model, I do not consider ice. If this leads to instability, how can I add ice to the model?
#15 Unread post by kate »
Do you want to have ice in the model? There are numerous options to do so, including my branch, COAWST, Metroms, and Scott Durski's branch. Metroms (on github) has a version coupled to the community CICE model, the most complete/mature of the ice models.
On the other hand, before I had ice in the model, it was happily running with temperatures down to -20 C. No problem, except the equation of state isn't valid there.
#16 Unread post by wilkin »
Then I'm out of suggestions.
But I add a few comments ...
The code base you are using must be extremely old because in roms_ini.nc you have a variable scrum_time, in addition to ocean_time. The SCRUM model went away a decade or more ago, so you should be careful you have not inherited some outdated code in preparing your inputs.
Also, the negative dz is a worry. You need to track that down.
And finally, the combination of Vtransform = 2 with Vstretching = 1 is an odd one. The Vtransform = 2 coordinate was never a part of SCRUM, so I worry that your code to make the initial conditions is not interpreting the vertical coordinate correctly.
Since you are starting out, why not make small incremental changes on the UPWELLING test case? So, keep Vtransform etc. the same as in the analytical case, and only change your initial conditions at first. Maybe keep the ANA surface forcing too until you know your initial conditions are not the problem.
