segmentation fault when running coawst_nonesting
agpc
#1 Unread post by agpc »
I have a problem when running the coawst model with nonesting option. The detail of this issue is presented below:
[cloud@igplogin COAWST_NONESTING]$ mpirun -np 3 ./coawstM Projects/Sarika/coupling_sarika.in
 Coupled Input File name = Projects/Sarika/coupling_sarika.in
 Model Coupling:
       Ocean Model MPI nodes: 000 - 000
       Waves Model MPI nodes: 001 - 001
       Atmos Model MPI nodes: 002 - 002
       WAVgrid 01 dt= 180.0 -to- OCNgrid 01 dt=   4.0, CplInt:  1800.0 Steps: 010
       OCNgrid 01 dt=   4.0 -to- WAVgrid 01 dt= 180.0, CplInt:  1800.0 Steps: 450
       ATMgrid 01 dt=  54.0 -to- OCNgrid 01 dt=   4.0, CplInt:  1800.0 Steps: 100
       OCNgrid 01 dt=   4.0 -to- ATMgrid 01 dt=  54.0, CplInt:  1800.0 Steps: ***
       ATMgrid 02 dt=  18.0 -to- OCNgrid 01 dt=   4.0, CplInt:  1800.0 Steps: 100
       OCNgrid 01 dt=   4.0 -to- ATMgrid 02 dt=  18.0, CplInt:  1800.0 Steps: 450
       ATMgrid 01 dt=  54.0 -to- WAVgrid 01 dt= 180.0, CplInt:  1800.0 Steps: 100
       WAVgrid 01 dt= 180.0 -to- ATMgrid 01 dt=  54.0, CplInt:  1800.0 Steps: 030
       ATMgrid 02 dt=  18.0 -to- WAVgrid 01 dt= 180.0, CplInt:  1800.0 Steps: 100
       WAVgrid 01 dt= 180.0 -to- ATMgrid 02 dt=  18.0, CplInt:  1800.0 Steps: 010
 Model Input Parameters:  ROMS/TOMS version 3.8
                          Thursday - November 26, 2020 -  9:01:58 AM
SWAN grid   1 is preparing computation
 module_io_quilt_old.F        2931 F
Quilting with   1 groups of   0 I/O tasks.
 Hurricane Sarika
 Operating system : Linux
 CPU/hardware     : x86_64
 Compiler system  : ifort
 Compiler command : /work/users/cloud/user/manh/COAWST/LIBRARIES/mpich2/bin/mpif90
 Compiler flags   : -fp-model precise -ip -O3 -traceback -check uninit -assume byterecl -I/work/users/cloud/user/manh/COAWST/LIBRARIES/MCT/include -I/work/users/cloud/user/manh/COAWST/COAWST7//WRF/main -I/work/users/cloud/user/manh/COAWST/COAWST7//WRF/external/esmf_time_f90 -I/work/users/cloud/user/manh/COAWST/COAWST7//WRF/frame -I/work/users/cloud/user/manh/COAWST/COAWST7//WRF/share
 MPI Communicator : -2080374780  PET size = 1
 Input Script     :
 SVN Root URL     : https://coawstmodel.sourcerepo.com/coawstmodel/COAWST
 SVN Revision     : 1492
 Local Root       : /work/users/cloud/user/manh/COAWST/COAWST7
 Header Dir       : /work/users/cloud/user/manh/COAWST/COAWST7/Projects/Sandy
 Header file      : sandy.h
 Analytical Dir   : /work/users/cloud/user/manh/COAWST/COAWST7/Projects/Sandy
 Resolution, Grid 01: 300x220x16,  Parallel Nodes: 1,  Tiling: 1x1
      21600  ntimes            Number of timesteps for 3-D equations.
      4.000  dt                Timestep size (s) for 3-D equations.
         28  ndtfast           Number of timesteps for 2-D equations between
          F  LcycleRST         Switch to recycle time-records in restart file.
      43200  nRST              Number of timesteps between the writing of data
                                 into restart fields.
                                 to standard output.
       2700  nHIS              Number of timesteps between the writing fields
                                 into history file.
       2700  ndefHIS           Number of timesteps between creation of new
                                 history files.
          0  nQCK              Number of timesteps between the writing fields
                                 into quicksave file.
          1  ntsAVG            Starting timestep for the accumulation of output
                                 time-averaged data.
      43200  nAVG              Number of timesteps between the writing of
      43200  ndefAVG           Number of timesteps between creation of new
                                 time-averaged file.
 2.0000E-01  nl_tnu2(01)       NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for tracer 01: temp
 2.0000E-01  nl_tnu2(02)       NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for tracer 02: salt
 1.0000E-01  nl_visc2          NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for momentum.
          F  LtracerSponge(01) Turning OFF sponge on tracer 01: temp
          F  LtracerSponge(02) Turning OFF sponge on tracer 02: salt
 1.0000E-06  Akt_bak(01)       Background vertical mixing coefficient (m2/s)
 1.0000E-06  Akt_bak(02)       Background vertical mixing coefficient (m2/s)
                                 for tracer 02: salt
 1.0000E-03  Akt_limit(01)     Vertical diffusion upper threshold (m2/s)
 1.0000E-03  Akt_limit(02)     Vertical diffusion upper threshold (m2/s)
                                 for tracer 02: salt
 1.0000E-05  Akv_bak           Background vertical mixing coefficient (m2/s)
 1.0000E-03  Akv_limit         Vertical viscosity upper threshold (m2/s)
 5.0000E-06  Akk_bak           Background vertical mixing coefficient (m2/s)
                                 for turbulent energy.
 5.0000E-06  Akp_bak           Background vertical mixing coefficient (m2/s)
      3.000  gls_p             GLS stability exponent.
      1.500  gls_m             GLS turbulent kinetic energy exponent.
     -1.000  gls_n             GLS turbulent length scale exponent.
 7.6000E-06  gls_Kmin          GLS minimum value of turbulent kinetic energy.
 1.0000E-12  gls_Pmin          GLS minimum value of dissipation.
 5.4770E-01  gls_cmu0          GLS stability coefficient.
 1.4400E+00  gls_c1            GLS shear production coefficient.
 1.9200E+00  gls_c2            GLS dissipation coefficient.
-4.0000E-01  gls_c3m           GLS stable buoyancy production coefficient.
 1.0000E+00  gls_c3p           GLS unstable buoyancy production coefficient.
 1.0000E+00  gls_sigk          GLS constant Schmidt number for TKE.
 1.3000E+00  gls_sigp          GLS constant Schmidt number for PSI.
   1400.000  charnok_alpha     Charnok factor for Zos calculation.
      0.500  zos_hsig_alpha    Factor for Zos calculation using Hsig(Awave).
      0.250  sz_alpha          Factor for Wave dissipation surface tke flux .
    100.000  crgban_cw         Factor for Craig/Banner surface tke flux.
      0.000  wec_alpha         WEC factor for roller/breaking energy distribution.
 2.5000E-02  rdrg2             Quadratic bottom drag coefficient.
 2.0000E-02  Zob               Bottom roughness (m).
 2.0000E-02  Zos               Surface roughness (m).
          1  lmd_Jwt           Jerlov water type.
          1  Vtransform        S-coordinate transformation equation.
          1  Vstretching       S-coordinate stretching function.
 1.0000E+01  theta_s           S-coordinate surface control parameter.
 4.0000E-01  theta_b           S-coordinate bottom  control parameter.
     50.000  Tcline            S-coordinate surface/bottom layer width (m) used
     40.000  dstart            Time-stamp assigned to model initialization (days).
      0.000  tide_start        Reference time origin for tidal forcing (days).
20161216.00  time_ref          Reference time for units attribute (yyyymmdd.dd)
 1.0000E+00  Tnudg(01)         Nudging/relaxation time scale (days)
 1.0000E+00  Tnudg(02)         Nudging/relaxation time scale (days)
                                 for tracer 02: salt
 9.0000E+01  Tnudg_SSS         Nudging/relaxation time scale (days)
                                 for sea surface salinity.
 0.0000E+00  Znudg             Nudging/relaxation time scale (days)
 0.0000E+00  M2nudg            Nudging/relaxation time scale (days)
 1.0000E+00  M3nudg            Nudging/relaxation time scale (days)
                                 for 3D momentum.
 0.0000E+00  obcfac            Factor between passive and active
     10.000  T0                Background potential temperature (C) constant.
     30.000  S0                Background salinity (PSU) constant.
          F  LtracerSrc(01)    Turning OFF point Sources/Sinks on tracer 01: temp
          F  LtracerSrc(02)    Turning OFF point Sources/Sinks on tracer 02: salt
          T  Hout(idUbar)      Write out 2D U-momentum component.
          T  Hout(idVbar)      Write out 2D V-momentum component.
          T  Hout(idOvel)      Write out omega vertical velocity.
          T  Hout(idTvar)      Write out tracer 01: temp
          T  Hout(idTvar)      Write out tracer 02: salt
          T  Hout(idUsms)      Write out surface U-momentum stress.
          T  Hout(idVsms)      Write out surface V-momentum stress.
          T  Hout(idUbms)      Write out bottom U-momentum stress.
          T  Hout(idVbms)      Write out bottom V-momentum stress.
          T  Hout(idU2Sd)      Write out 2D u-momentum stokes velocity.
          T  Hout(idV2Sd)      Write out 2D v-momentum stokes velocity.
          T  Hout(idU3Sd)      Write out 3D u-momentum stokes velocity.
          T  Hout(idV3Sd)      Write out 3D v-momentum stokes velocity.
          T  Hout(idW3Sd)      Write out 3D omega-momentum stokes velocity.
          T  Hout(idW3St)      Write out 3D w-momentum stokes velocity.
          T  Hout(idWztw)      Write out WEC quasi-static sea level adjustment.
          T  Hout(idWqsp)      Write out WEC quasi-static pressure.
          T  Hout(idWbeh)      Write out WEC Bernoulli head.
          T  Hout(idWamp)      Write out wave height.
          T  Hout(idWlen)      Write out wavelength.
          T  Hout(idWlep)      Write out peak wavelength.
          T  Hout(idWdir)      Write out mean wave direction.
          T  Hout(idWptp)      Write out wave surface period.
          T  Hout(idWpbt)      Write out wave bottom period.
          T  Hout(idWorb)      Write out wave bottom orbital velocity.
          T  Hout(idUwav)      Wave-avg surface u-velocity.
          T  Hout(idVwav)      Wave-avg surface v-velocity.
          T  Hout(idVvis)      Write out vertical viscosity: AKv.
          T  Hout(idMtke)      Write out turbulent kinetic energy.
          T  Hout(idMtls)      Write out turbulent generic length-scale.
          T  Aout(idSdif)      Write out averaged vertical diffusion: AKt(isalt).
               Output Restart File:  ocean_rst1.nc
          Prefix for History Files:  ocean_hist1
         Prefix for Averages Files:  ocean_avg1
          Physical parameters File:
                   Input Grid File:  Projects/Sarika/ROMS_COAWST_grd1.nc
      Input Nonlinear Initial File:  Projects/Sarika/Sarika_ini.nc
                Tidal Forcing File:  Projects/Sarika/tide_forc_Sarika.nc
 Ntasks in X            1 , ntasks in Y            1
WRF V4.1.5 MODEL
WRF V4.1.5 MODEL
 Parent domain
 ids,ide,jds,jde            1         301           1         221
 ims,ime,jms,jme           -4         306          -4         226
 Parent domain
 ips,ipe,jps,jpe            1         301           1         221
DYNAMICS OPTION: Eulerian Mass Coordinate
coawstM            0000000003C193AA  Unknown               Unknown  Unknown
libpthread-2.17.s  00007F1C3961B5D0  Unknown               Unknown  Unknown
coawstM            000000000090FC93  read_phypar_             3082  read_phypar.f90
coawstM            0000000000796709  inp_par_                   87  inp_par.f90
coawstM            00000000004455D9  ocean_control_mod          90  ocean_control.f90
coawstM            000000000041EE5D  MAIN__                    373  master.f90
coawstM            0000000000418FE2  Unknown               Unknown  Unknown
libc-2.17.so       00007F1C38D5B495  __libc_start_main     Unknown  Unknown
coawstM            0000000000418EE9  Unknown               Unknown  Unknown
I also attach all of my namelist files.
Please help me to address it.
Many thanks!
Best Regards,
Bound_spec_command.txt
(433 Bytes) Downloaded 280 times
namelist.input.txt
(4.67 KiB) Downloaded 242 times
swan_sarika.in
(4.11 KiB) Downloaded 249 times
sarika.h
(2.22 KiB) Downloaded 247 times
ocean_sarika.in
(149.63 KiB) Downloaded 239 times
coupling_sarika.in
(8.44 KiB) Downloaded 243 times
