Running error: unable to open existing NetCDF file
Xegone
#1 Unread post by Xegone »
I am trying to run the test case "Validation" and I get the following error
xegone@LAPTOP-1M0U3VET:~/ROMS-Tidal-Array.git/Projects/Validation$ ./oceanS < ocean_validation.in
Thursday - July 2, 2020 - 12:08:33 PM
Simplified Channel
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
SVN Revision : 11M
Local Root : /home/xegone/ROMS-Tidal-Array.git/trunk
Header Dir : /home/xegone/ROMS-Tidal-Array.git/Projects/Validation
Header file : validation.h
Analytical Dir: /home/xegone/ROMS-Tidal-Array.git/Projects/Validation
Resolution, Grid 01: 0420x0091x040, Parallel Threads: 1, Tiling: 008x003
41000 ntimes Number of timesteps for 3-D equations.
0.010 dt Timestep size (s) for 3-D equations.
-1 nrrec Number of restart records to read from disk.
0 nRST Number of timesteps between the writing of data
into restart fields.
2000 ninfo Number of timesteps between print of information
to standard output.
41000 nHIS Number of timesteps between the writing fields
into history file.
0 ntsAVG Starting timestep for the accumulation of output
time-averaged data.
0 nAVG Number of timesteps between the writing of
5.0000E-04 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
3.0000E-06 gls_Kmin GLS minimum value of turbulent kinetic energy.
0.0000E+00 rdrg Linear bottom drag coefficient (m/s).
0.0000E+00 rdrg2 Quadratic bottom drag coefficient.
1.0000E-07 Zob Bottom roughness (m).
0.0000E+00 Zos Surface roughness (m).
3 Vstretching S-coordinate stretching function.
7.0000E-01 theta_s S-coordinate surface control parameter.
7.0000E-01 theta_b S-coordinate bottom control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
1.0000E-03 Znudg Nudging/relaxation time scale (days)
1.0000E-03 M2nudg Nudging/relaxation time scale (days)
1.0000E-03 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
5.0000E+00 obcfac Factor between passive and active
20.000 T0 Background potential temperature (C) constant.
1025.000 R0 Background density (kg/m3) used in linear Equation
of State.
T Hout(idMtke) Write out turbulent kinetic energy.
T Hout(idMtls) Write out turbulent generic length-scale.
Output Restart File: ocean_validation_rst.nc
Output History File: ocean_validation_his.nc
Output Averages File: ocean_validation_avg.nc
Tidal Turbine File: turbine_validation.in
Tile partition information for Grid 01: 0420x0091x0040 tiling: 008x003
tile Istr Iend Jstr Jend Npts
0 1 51 1 30 61200
1 52 104 1 30 63600
2 105 157 1 30 63600
3 158 210 1 30 63600
4 211 263 1 30 63600
5 264 316 1 30 63600
6 317 369 1 30 63600
7 370 420 1 30 61200
8 1 51 31 61 63240
9 52 104 31 61 65720
10 105 157 31 61 65720
11 158 210 31 61 65720
12 211 263 31 61 65720
13 264 316 31 61 65720
14 317 369 31 61 65720
15 370 420 31 61 63240
16 1 51 62 91 61200
17 52 104 62 91 63600
18 105 157 62 91 63600
19 158 210 62 91 63600
20 211 263 62 91 63600
21 264 316 62 91 63600
22 317 369 62 91 63600
23 370 420 62 91 61200
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 422.50 0.50 92.50 RHO-points
1 -0.50 422.50 0.50 92.50 RHO-points
2 -0.50 422.50 0.50 92.50 RHO-points
3 -0.50 422.50 0.50 92.50 RHO-points
4 -0.50 422.50 0.50 92.50 RHO-points
5 -0.50 422.50 0.50 92.50 RHO-points
6 -0.50 422.50 0.50 92.50 RHO-points
7 -0.50 421.50 0.50 92.50 RHO-points
8 0.50 422.50 -0.50 92.50 RHO-points
9 -0.50 422.50 -0.50 92.50 RHO-points
10 -0.50 422.50 -0.50 92.50 RHO-points
11 -0.50 422.50 -0.50 92.50 RHO-points
12 -0.50 422.50 -0.50 92.50 RHO-points
13 -0.50 422.50 -0.50 92.50 RHO-points
14 -0.50 422.50 -0.50 92.50 RHO-points
15 -0.50 421.50 -0.50 92.50 RHO-points
16 0.50 422.50 -0.50 91.50 RHO-points
17 -0.50 422.50 -0.50 91.50 RHO-points
18 -0.50 422.50 -0.50 91.50 RHO-points
19 -0.50 422.50 -0.50 91.50 RHO-points
20 -0.50 422.50 -0.50 91.50 RHO-points
21 -0.50 422.50 -0.50 91.50 RHO-points
22 -0.50 422.50 -0.50 91.50 RHO-points
23 -0.50 421.50 -0.50 91.50 RHO-points
0 0.00 422.50 0.50 92.50 U-points
1 -0.50 422.50 0.50 92.50 U-points
2 -0.50 422.50 0.50 92.50 U-points
3 -0.50 422.50 0.50 92.50 U-points
4 -0.50 422.50 0.50 92.50 U-points
5 -0.50 422.50 0.50 92.50 U-points
6 -0.50 422.50 0.50 92.50 U-points
7 -0.50 421.00 0.50 92.50 U-points
8 0.00 422.50 -0.50 92.50 U-points
9 -0.50 422.50 -0.50 92.50 U-points
10 -0.50 422.50 -0.50 92.50 U-points
11 -0.50 422.50 -0.50 92.50 U-points
12 -0.50 422.50 -0.50 92.50 U-points
13 -0.50 422.50 -0.50 92.50 U-points
14 -0.50 422.50 -0.50 92.50 U-points
15 -0.50 421.00 -0.50 92.50 U-points
16 0.00 422.50 -0.50 91.50 U-points
17 -0.50 422.50 -0.50 91.50 U-points
18 -0.50 422.50 -0.50 91.50 U-points
19 -0.50 422.50 -0.50 91.50 U-points
20 -0.50 422.50 -0.50 91.50 U-points
21 -0.50 422.50 -0.50 91.50 U-points
22 -0.50 422.50 -0.50 91.50 U-points
23 -0.50 421.00 -0.50 91.50 U-points
0 0.50 422.50 0.00 92.50 V-points
1 -0.50 422.50 0.00 92.50 V-points
2 -0.50 422.50 0.00 92.50 V-points
3 -0.50 422.50 0.00 92.50 V-points
4 -0.50 422.50 0.00 92.50 V-points
5 -0.50 422.50 0.00 92.50 V-points
6 -0.50 422.50 0.00 92.50 V-points
7 -0.50 421.50 0.00 92.50 V-points
8 0.50 422.50 -0.50 92.50 V-points
9 -0.50 422.50 -0.50 92.50 V-points
10 -0.50 422.50 -0.50 92.50 V-points
11 -0.50 422.50 -0.50 92.50 V-points
12 -0.50 422.50 -0.50 92.50 V-points
13 -0.50 422.50 -0.50 92.50 V-points
14 -0.50 422.50 -0.50 92.50 V-points
15 -0.50 421.50 -0.50 92.50 V-points
16 0.50 422.50 -0.50 91.00 V-points
17 -0.50 422.50 -0.50 91.00 V-points
18 -0.50 422.50 -0.50 91.00 V-points
19 -0.50 422.50 -0.50 91.00 V-points
20 -0.50 422.50 -0.50 91.00 V-points
21 -0.50 422.50 -0.50 91.00 V-points
22 -0.50 422.50 -0.50 91.00 V-points
23 -0.50 421.50 -0.50 91.00 V-points
3 Number of turbines deployed.
Turbines Parameters, Grid: 01
xpos ypos zpos Ct Ctke Cgls Lc Pa Diam
No 1 : 0.401D+01 0.549D+00 0.50 0.92 0.05 4.00 0.00 0.52 0.10
No 2 : 0.401D+01 0.801D+00 0.50 0.92 0.05 4.00 0.00 0.52 0.10
No 3 : 0.431D+01 0.675D+00 0.50 0.92 0.05 4.00 0.00 0.52 0.10
zeta 1 Clamped Closed Clamped Closed
ubar 1 Clamped Closed Reduced Closed
vbar 1 Clamped Closed Reduced Closed
u 1 Radiation Closed Radiation Closed
v 1 Radiation Closed Radiation Closed
temp 1 Radiation Closed Radiation Closed
salt 1 Radiation Closed Radiation Closed
tke 1 Gradient Closed Radiation Closed
VALIDATION Simplified Channel
ANA_M3OBC Analytical 3D momentum boundary conditions.
ANA_MASK Analytical Land/Sea Masking.
TIDAL_TURBINE tidal turbine hydrodynamic effects as body-force and turbulence source.
I_ORIENTATION tidal turbine facing the I direction.
CANUTO_B Canuto B-stability function formulation.
NONLINEAR Nonlinear Model.
PERFECT_RESTART Processing perfect restart variables.
PRSGRD31 Standard density Jacobian formulation (Song, 1998).
RHO_SURF Include difference between rho0 and surface density.
UV_ADV Advection of momentum.
Process Information:
Thread # 0 (pid= 19133) is active.
40 0.0000000 0.0000000 0.000 0.000 0.000 0.000
39 -0.0250000 -0.0116821 -0.004 -0.000 -0.004 -0.004
38 -0.0500000 -0.0298123 -0.009 -0.000 -0.009 -0.009
37 -0.0750000 -0.0512639 -0.015 -0.000 -0.015 -0.015
36 -0.1000000 -0.0748774 -0.022 -0.000 -0.022 -0.022
35 -0.1250000 -0.0999581 -0.030 -0.000 -0.030 -0.030
34 -0.1500000 -0.1260325 -0.038 -0.000 -0.038 -0.038
33 -0.1750000 -0.1527582 -0.046 -0.000 -0.046 -0.046
32 -0.2000000 -0.1798801 -0.054 -0.000 -0.054 -0.054
31 -0.2250000 -0.2072055 -0.062 -0.000 -0.062 -0.062
30 -0.2500000 -0.2345894 -0.070 -0.000 -0.070 -0.070
29 -0.2750000 -0.2619234 -0.079 -0.000 -0.079 -0.079
28 -0.3000000 -0.2891297 -0.087 -0.000 -0.087 -0.087
27 -0.3250000 -0.3161563 -0.095 -0.000 -0.095 -0.095
26 -0.3500000 -0.3429732 -0.103 -0.000 -0.103 -0.103
25 -0.3750000 -0.3695705 -0.111 -0.000 -0.111 -0.111
24 -0.4000000 -0.3959554 -0.119 -0.000 -0.119 -0.119
23 -0.4250000 -0.4221506 -0.127 -0.000 -0.127 -0.127
22 -0.4500000 -0.4481916 -0.134 -0.000 -0.134 -0.134
21 -0.4750000 -0.4741239 -0.142 -0.000 -0.142 -0.142
20 -0.5000000 -0.5000000 -0.150 -0.000 -0.150 -0.150
19 -0.5250000 -0.5258761 -0.158 -0.000 -0.158 -0.158
18 -0.5500000 -0.5518084 -0.166 -0.000 -0.166 -0.166
17 -0.5750000 -0.5778494 -0.173 -0.000 -0.173 -0.173
16 -0.6000000 -0.6040446 -0.181 -0.000 -0.181 -0.181
15 -0.6250000 -0.6304295 -0.189 -0.000 -0.189 -0.189
14 -0.6500000 -0.6570268 -0.197 -0.000 -0.197 -0.197
13 -0.6750000 -0.6838437 -0.205 -0.000 -0.205 -0.205
12 -0.7000000 -0.7108703 -0.213 -0.000 -0.213 -0.213
11 -0.7250000 -0.7380766 -0.221 -0.000 -0.221 -0.221
10 -0.7500000 -0.7654106 -0.230 -0.000 -0.230 -0.230
9 -0.7750000 -0.7927945 -0.238 -0.000 -0.238 -0.238
8 -0.8000000 -0.8201199 -0.246 -0.000 -0.246 -0.246
7 -0.8250000 -0.8472418 -0.254 -0.000 -0.254 -0.254
6 -0.8500000 -0.8739675 -0.262 -0.000 -0.262 -0.262
5 -0.8750000 -0.9000419 -0.270 -0.000 -0.270 -0.270
4 -0.9000000 -0.9251226 -0.278 -0.000 -0.278 -0.278
3 -0.9250000 -0.9487361 -0.285 -0.000 -0.285 -0.285
2 -0.9500000 -0.9701877 -0.291 -0.000 -0.291 -0.291
1 -0.9750000 -0.9883179 -0.296 -0.000 -0.296 -0.296
0 -1.0000000 -1.0000000 -0.300 -0.000 -0.300 -0.300
12 0.0043042707117221 0.0335513677379153-0.0022367614257357 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864347 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001212 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565096 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906203 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716642 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402367 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399431 0.6603333185976138
21 0.0256737146312910 0.0297153720153352 0.1342125541712341 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524357 0.7189082721405746
23 0.0316613792205220 0.0279045862015855 0.1945237931729577 0.7468128583421600
24 0.0346736416507075 0.0268492068942347 0.2291974348236651 0.7736620652363948
25 0.0376471948657328 0.0256934188392112 0.2668446296893979 0.7993554840756060
26 0.0405373376992232 0.0244385123436867 0.3073819673886211 0.8237939964192927
27 0.0432936737565711 0.0230872677537126 0.3506756411451922 0.8468812641730054
28 0.0458596469320356 0.0216441452951603 0.3965352880772278 0.8685254094681656
29 0.0481720587108284 0.0201154903974257 0.4447073467880562 0.8886408998655914
30 0.0501605672561820 0.0185097551070648 0.4948679140442381 0.9071506549726561
31 0.0517471682814030 0.0168377361985254 0.5466150823256412 0.9239883911711815
32 0.0528456577069106 0.0151128305891453 0.5994607400325517 0.9391012217603267
33 0.0533610761022577 0.0133513086655816 0.6528218161348094 0.9524525304259084
34 0.0531891349131379 0.0115726061288397 0.7060109510479473 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213234 0.9738247715198165
36 0.0503158038019031 0.0080591141492892 0.8085423793232265 0.9818838856691057
37 0.0473537721847153 0.0063819206892258 0.8558961515079418 0.9882658063583315
38 0.0431818225418188 0.0048034616164019 0.8990779740497606 0.9930692679747335
39 0.0376397765791564 0.0033640675316746 0.9367177506289170 0.9964333355064081
40 0.0305543017255206 0.0021094083123694 0.9672720523544377 0.9985427438187775
41 0.0217382098544505 0.0010909315881854 0.9890102622088881 0.9996336754069629
42 0.0109897377911119 0.0003663245930371 1.0000000000000000 1.0000000000000000
Minimum X-grid spacing, DXmin = 4.76190476E-05 km
Maximum X-grid spacing, DXmax = 4.76190476E-05 km
Minimum Y-grid spacing, DYmin = 1.48351648E-05 km
Maximum Y-grid spacing, DYmax = 1.48351648E-05 km
Minimum Z-grid spacing, DZmin = 3.50462374E-03 m
Maximum Z-grid spacing, DZmax = 8.21514706E-03 m
Minimum barotropic Courant Number = 4.03734573E-02
Maximum barotropic Courant Number = 4.03734573E-02
Maximum Coriolis Courant Number = 0.00000000E+00
ocean_ini.nc
call from: checkvars.F
Thread # 0 CPU: 1.359
Total: 1.359
Allocation and array initialization .............. 1.328 (97.7011 %)
Total: 1.328 97.7011
All percentages are with respect to total time = 1.359
Analytical header files used:
ROMS/Functionals/ana_grid.h
REASON: No such file or directory
I says that the file "ocean_ini.nc" cannot be opened. I tried to find that file and is not in my directory. The weird thing is that in the upwelling case which I managed to run successfully in "upwelling.in" file it also appears "ININAME == ocean_ini.nc" but no error appear when running it.
Any ideas?
Xegone
Re: Running error: unable to open existing NetCDF file
i am wondering if your ocean.in files are older. because all the ocean.in were renamed to roms_ini.nc a while ago.
#3 Unread post by kate »
Weird, you've got ANA_INITIAL so it shouldn't have a reason to read a file instead.
Xegone
#4 Unread post by Xegone »
I forgot to mention I am working with an older ROMS version (3.6), that is why files are named still with ocean instead of roms.
Xegone
#5 Unread post by Xegone »
I think the error might be in the output instead of the input file:
How can I know more info about the error?
Xegone
#6 Unread post by kate »
There is a dying art known as "debugging". The lucky few have access to interactive debuggers such as totalview, ddt, ddd. Many have access to gdb, without a gui. If you compile ROMS with USE_DEBUG then you can run it within one of these debuggers and watch what's going on line by line. The fancy debuggers work with parallel execution as well as serial.
One alternative is to add print statements all over the place, like 'print *, "before reading initial file"' or even 'if (Master) print *, "before reading file", file'. The benefit of that is that you can still run it optimized (not USE_DEBUG).
Xegone
#7 Unread post by Xegone »
I will give it a try but I think is off my capabilities. Thanks anyway
shiyf
#8 Unread post by shiyf »
Have you solved this problem? I have the same problem
Kosa
#9 Unread post by Kosa »
I think I know what went wrong in the original post by Xegone. If ANA_INITIAL is activated, an initial conditions netcdf file is not considered as long as NRREC=0 to indicate that we are starting a new solution. But in this case NRREC=-1 so ROMS looked for an initial conditions file, and since it was defined as the placeholder ocean_ini.nc which did not exist on their local path, an error was returned.
shiyf wrote: Wed Dec 29, 2021 2:57 am Have you solved this problem? I have the same problem
If this is not the same scenario as you then I'd recommend posting the complete output like the original post.
