I just downloaded the latest version of ROMS. While most of the compilers do not have a problem, the IBM xlf90 and xlf90_r has a problem with the syntax and the compilation stops with an error
! If blowing-up, save latest model state into RESTART NetCDF file.
! If cycling restart records, write solution into the next record.
IF (exit_flag.eq.1) THEN
DO ng=1,Ngrids
IF (LwrtRST(ng)) THEN
IF (Master) WRITE (stdout,10), TRIM(blowup_string)
The comma after (stdout,10) should not be there or something is missing before the comma.
Small fortran bug in nl_ocean.h
Re: Small fortran bug in nl_ocean.h
Yes, thank you!
