Moderators: arango , robertson
nilodna
Posts: 6 Joined: Thu May 02, 2013 6:38 pm
Location: Oceanographic Institute from University of Sao Pau
#1
Unread post
by nilodna » Fri Jun 19, 2020 5:27 am
I'm trying to use pyroms to create initial and boundary conditions from Mercator (glorys12v1) dataset and following the examples provided in the pyroms Github repository. However, in the Artic_GLORYS example, a mesh grid is called:
src_grd = pyroms_toolbox.CGrid_GLORYS.get_nc_CGrid_GLORYS('/archive/u1/uaf/kate/GLORYS/GL2V1_mesh_mask_new.nc', name='GLORYS', area='npolar', ystart=690)
I'm wondering if someone can help me to generate a similar file or, if available, point me in the right direction to download this file.
Thanks in advance.
Posts: 4091 Joined: Wed Jul 02, 2003 5:29 pm
Unread post
by kate » Fri Jun 19, 2020 5:21 pm
The thing is half a GB in size. Can you ask for it from your source of GLORYS files?
nilodna
#3
Unread post
by nilodna » Sat Jun 20, 2020 11:23 pm
Hi Kate,
I can try that, but I thought there might be a way to create this file.
I tried to create once, but the problem is that glorys12v1 files come only with 'rho-points' coordinates, and my attempt to create u and v grid and use in the interpolation generates a weird field (as in the figure attached for zeta).
Thank you for your help.
zeta fields after interpolation pyroms_zeta_error.png (39.33 KiB) Viewed 19777 times
Unread post
by kate » Sat Jun 20, 2020 11:44 pm
Here is the ncdump of the thing:
chinook02.rcs.alaska.edu 207% ncdump -h GL2V1_mesh_mask_new.nc
netcdf GL2V1_mesh_mask_new {
dimensions:
y = 1021 ;
x = 1442 ;
z = 75 ;
variables:
int y(y) ;
y:axis = "Y" ;
y:standard_name = "projection_y_coordinate" ;
y:units = " " ;
int x(x) ;
x:axis = "X" ;
x:standard_name = "projection_x_coordinate" ;
x:units = " " ;
double e1t(y, x) ;
e1t:standard_name = "grid_cell_length_x_t-point_c-grid" ;
e1t:long_name = "Zonal_scale_factor_at_t_point_for_arakawa_c_grid" ;
e1t:_FillValue = 9.96920996838687e+36 ;
e1t:missing_value = 9.96920996838687e+36 ;
e1t:units = "m" ;
e1t:coordinates = "nav_lon nav_lat" ;
double e1u(y, x) ;
e1u:standard_name = "grid_cell_length_x_u-point_c-grid" ;
e1u:long_name = "Zonal_scale_factor_at_u_point_for_arakawa_c_grid" ;
e1u:_FillValue = 9.96920996838687e+36 ;
e1u:missing_value = 9.96920996838687e+36 ;
e1u:units = "m" ;
e1u:coordinates = "nav_lon nav_lat" ;
double e1v(y, x) ;
e1v:standard_name = "grid_cell_length_x_v-point_c-grid" ;
e1v:long_name = "Zonal_scale_factor_at_v_point_for_arakawa_c_grid" ;
e1v:_FillValue = 9.96920996838687e+36 ;
e1v:missing_value = 9.96920996838687e+36 ;
e1v:units = "m" ;
e1v:coordinates = "nav_lon nav_lat" ;
double e2t(y, x) ;
e2t:standard_name = "grid_cell_length_y_t-point_c-grid" ;
e2t:long_name = "Meridional_scale_factor_at_t_point_for_arakawa_c_grid" ;
e2t:_FillValue = 9.96920996838687e+36 ;
e2t:missing_value = 9.96920996838687e+36 ;
e2t:units = "m" ;
e2t:coordinates = "nav_lon nav_lat" ;
double e2u(y, x) ;
e2u:standard_name = "grid_cell_length_y_u-point_c-grid" ;
e2u:long_name = "Meridional_scale_factor_at_u_point_for_arakawa_c_grid" ;
e2u:_FillValue = 9.96920996838687e+36 ;
e2u:missing_value = 9.96920996838687e+36 ;
e2u:units = "m" ;
e2u:coordinates = "nav_lon nav_lat" ;
double e2v(y, x) ;
e2v:standard_name = "grid_cell_length_y_v-point_c-grid" ;
e2v:long_name = "Meridional_scale_factor_at_v_point_for_arakawa_c_grid" ;
e2v:_FillValue = 9.96920996838687e+36 ;
e2v:missing_value = 9.96920996838687e+36 ;
e2v:units = "m" ;
e2v:coordinates = "nav_lon nav_lat" ;
double e3t_0(z) ;
e3t_0:standard_name = "grid_cell_length_z_t-point_c-grid" ;
e3t_0:long_name = "Vertical_scale_factor_at_t_point_for_arakawa_c_grid" ;
e3t_0:_FillValue = 9.96920996838687e+36 ;
e3t_0:missing_value = 9.96920996838687e+36 ;
e3t_0:units = "m" ;
double e3t_ps(y, x) ;
e3t_ps:standard_name = "grid_cell_length_z_t-point_c-grid_partial_cell" ;
e3t_ps:long_name = "Partial_cell_vertical_scale_factor_at_t_point_for_arakawa_c_grid" ;
e3t_ps:_FillValue = 9.96920996838687e+36 ;
e3t_ps:missing_value = 9.96920996838687e+36 ;
e3t_ps:units = "m" ;
e3t_ps:coordinates = "nav_lon nav_lat" ;
double e3w_0(z) ;
e3w_0:standard_name = "grid_cell_length_z_w-point_c-grid" ;
e3w_0:long_name = "Vertical_scale_factor_at_w_point_for_arakawa_c_grid" ;
e3w_0:_FillValue = 9.96920996838687e+36 ;
e3w_0:missing_value = 9.96920996838687e+36 ;
e3w_0:units = "m" ;
double e3w_ps(y, x) ;
e3w_ps:standard_name = "grid_cell_length_z_w-point_c-grid_partial_cell" ;
e3w_ps:long_name = "Partial_cell_vertical_scale_factor_at_w_point_for_arakawa_c_grid" ;
e3w_ps:_FillValue = 9.96920996838687e+36 ;
e3w_ps:missing_value = 9.96920996838687e+36 ;
e3w_ps:units = "m" ;
e3w_ps:coordinates = "nav_lon nav_lat" ;
double gdept_0(z) ;
gdept_0:standard_name = "depth_t-point_c-grid" ;
gdept_0:long_name = "Depth_at_t_point_for_arakawa_c_grid" ;
gdept_0:_FillValue = 9.96920996838687e+36 ;
gdept_0:missing_value = 9.96920996838687e+36 ;
gdept_0:units = "m" ;
double gdepw_0(z) ;
gdepw_0:standard_name = "depth_w-point_c-grid" ;
gdepw_0:long_name = "Depth_at_w_point_for_arakawa_c_grid" ;
gdepw_0:_FillValue = 9.96920996838687e+36 ;
gdepw_0:missing_value = 9.96920996838687e+36 ;
gdepw_0:units = "m" ;
float glamt(y, x) ;
glamt:standard_name = "latitude_t-point_c-grid" ;
glamt:long_name = "Latitude_at_t_point_for_arakawa_c_grid" ;
glamt:_FillValue = 9.96921e+36f ;
glamt:missing_value = 9.96921e+36f ;
glamt:units = "degrees" ;
glamt:coordinates = "nav_lon nav_lat" ;
float glamu(y, x) ;
glamu:standard_name = "latitude_u-point_c-grid" ;
glamu:long_name = "Latitude_at_u_point_for_arakawa_c_grid" ;
glamu:_FillValue = 9.96921e+36f ;
glamu:missing_value = 9.96921e+36f ;
glamu:units = "degrees" ;
glamu:coordinates = "nav_lon nav_lat" ;
float glamv(y, x) ;
glamv:standard_name = "latitude_v-point_c-grid" ;
glamv:long_name = "Latitude_at_v_point_for_arakawa_c_grid" ;
glamv:_FillValue = 9.96921e+36f ;
glamv:missing_value = 9.96921e+36f ;
glamv:units = "degrees" ;
glamv:coordinates = "nav_lon nav_lat" ;
float gphit(y, x) ;
gphit:standard_name = "longitude_t-point_c-grid" ;
gphit:long_name = "Longitude_at_t_point_for_arakawa_c_grid" ;
gphit:_FillValue = 9.96921e+36f ;
gphit:missing_value = 9.96921e+36f ;
gphit:units = "degrees" ;
gphit:coordinates = "nav_lon nav_lat" ;
float gphiu(y, x) ;
gphiu:standard_name = "longitude_u-point_c-grid" ;
gphiu:long_name = "Longitude_at_u_point_for_arakawa_c_grid" ;
gphiu:_FillValue = 9.96921e+36f ;
gphiu:missing_value = 9.96921e+36f ;
gphiu:units = "degrees" ;
gphiu:coordinates = "nav_lon nav_lat" ;
float gphiv(y, x) ;
gphiv:standard_name = "longitude_v-point_c-grid" ;
gphiv:long_name = "Longitude_at_v_point_for_arakawa_c_grid" ;
gphiv:_FillValue = 9.96921e+36f ;
gphiv:missing_value = 9.96921e+36f ;
gphiv:units = "degrees" ;
gphiv:coordinates = "nav_lon nav_lat" ;
double hdept(y, x) ;
hdept:standard_name = "depth_pc_t-point_c-grid" ;
hdept:long_name = "Depth_of_partial_cell_t_point_for_arakawa_c_grid" ;
hdept:_FillValue = 9.96920996838687e+36 ;
hdept:missing_value = 9.96920996838687e+36 ;
hdept:units = "m" ;
hdept:coordinates = "nav_lon nav_lat" ;
double hdepw(y, x) ;
hdepw:standard_name = "depth_pc_w-point_c-grid" ;
hdepw:long_name = "Depth_of_partial_cell_w_point_for_arakawa_c_grid" ;
hdepw:_FillValue = 9.96920996838687e+36 ;
hdepw:missing_value = 9.96920996838687e+36 ;
hdepw:units = "m" ;
hdepw:coordinates = "nav_lon nav_lat" ;
short mbathy(y, x) ;
mbathy:standard_name = "index_pc_t-point_c-grid" ;
mbathy:long_name = "Index_of_partial_cell_t_point_for_arakawa_c_grid" ;
mbathy:valid_min = 0s ;
mbathy:valid_max = 74s ;
mbathy:_FillValue = -32767s ;
mbathy:missing_value = -32767s ;
mbathy:units = "level" ;
mbathy:coordinates = "nav_lon nav_lat" ;
float nav_lat(y, x) ;
nav_lat:valid_min = -77.0105f ;
nav_lat:valid_max = 89.8876f ;
nav_lat:units = "degrees_north" ;
nav_lat:standard_name = "latitude" ;
nav_lat:_FillValue = 9.96921e+36f ;
nav_lat:missing_value = 9.96921e+36f ;
nav_lat:axis = "Y" ;
float deptht(z) ;
deptht:valid_min = 0.50576f ;
deptht:valid_max = 5902.058f ;
deptht:units = "m" ;
deptht:positive = "down" ;
deptht:_FillValue = 9.96921e+36f ;
deptht:axis = "Z" ;
deptht:missing_value = 9.96921e+36f ;
deptht:standard_name = "depth" ;
float nav_lon(y, x) ;
nav_lon:valid_min = -179.75f ;
nav_lon:valid_max = 180.f ;
nav_lon:units = "degrees_east" ;
nav_lon:standard_name = "longitude" ;
nav_lon:_FillValue = 9.96921e+36f ;
nav_lon:missing_value = 9.96921e+36f ;
nav_lon:axis = "X" ;
byte tmask(z, y, x) ;
tmask:standard_name = "land_sea_t_mask" ;
tmask:long_name = "Land_sea_mask_at_t_point_for_arakawa_c_grid" ;
tmask:_FillValue = -127b ;
tmask:missing_value = -127b ;
tmask:units = "1" ;
tmask:coordinates = "nav_lon nav_lat" ;
byte tmaskutil(y, x) ;
tmaskutil:standard_name = "land_sea_t_mask_no_overlap" ;
tmaskutil:long_name = "Land_sea_mask_at_t_point_without_overlapping_cells_for_arakawa_c_grid" ;
tmaskutil:_FillValue = -127b ;
tmaskutil:missing_value = -127b ;
tmaskutil:units = "1" ;
tmaskutil:coordinates = "nav_lon nav_lat" ;
byte umask(z, y, x) ;
umask:standard_name = "land_sea_u_mask" ;
umask:long_name = "Land_sea_mask_at_u_point_for_arakawa_c_grid" ;
umask:_FillValue = -127b ;
umask:missing_value = -127b ;
umask:units = "1" ;
umask:coordinates = "nav_lon nav_lat" ;
byte umaskutil(y, x) ;
umaskutil:standard_name = "land_sea_u_mask_no_overlap" ;
umaskutil:long_name = "Land_sea_mask_at_u_point_without_overlapping_cells_for_arakawa_c_grid" ;
umaskutil:_FillValue = -127b ;
umaskutil:missing_value = -127b ;
umaskutil:units = "1" ;
umaskutil:coordinates = "nav_lon nav_lat" ;
byte vmask(z, y, x) ;
vmask:standard_name = "land_sea_v_mask" ;
vmask:long_name = "Land_sea_mask_at_v_point_for_arakawa_c_grid" ;
vmask:_FillValue = -127b ;
vmask:missing_value = -127b ;
vmask:units = "1" ;
vmask:coordinates = "nav_lon nav_lat" ;
byte vmaskutil(y, x) ;
vmaskutil:standard_name = "land_sea_v_mask_no_overlap" ;
vmaskutil:long_name = "Land_sea_mask_at_v_point_without_overlapping_cells_for_arakawa_c_grid" ;
vmaskutil:_FillValue = -127b ;
vmaskutil:missing_value = -127b ;
vmaskutil:units = "1" ;
vmaskutil:coordinates = "nav_lon nav_lat" ;
// global attributes:
:convention = "CF1.4" ;
:title = "Native grid GLORYS2V1 mesh and mask" ;
:history = "Release February 2011" ;
:file_name = "GLORYS2V1_ORCA025_R20110216_coordinates.nc" ;
:institution = "MERCATOR OCEAN" ;
:source = "MERCATOR GLORYS2V1" ;
:TimeStamp = "2011-JAN-28 16:36:08 GMT+0100" ;
:references = "http://www.mercator-ocean.fr" ;
:comment = " " ;
nilodna
#5
Unread post
by nilodna » Mon Jun 29, 2020 2:11 pm
Thanks, Kate, that will be very helpful.
