Hello, i upgrade ROMS to the new version:
run the build_roms_4dvshc.csh file.
I have check my bash.csh .h and .mk files. Still with some trouble like this:
i4dvar.f90:319.10:
USE mod_fourdvar
1
Error: 'increment' of module 'mod_fourdvar', imported at (1), is also the name of the current program unit
Any help or suggestion will be highly appreciated.
I4dvar compilation error about i4dvar.f90 and mod_fourdvar
- build_roms_4dvshc.c
- (12.34 KiB) Downloaded 475 times
- wc13 (2).h
- (4.77 KiB) Downloaded 502 times
- Linux-gfortran.mk
- (11.76 KiB) Downloaded 486 times
Re: I4dvar compilation error about i4dvar.f90 and mod_fourdvar
Hi there, I encountered similar error with gfortran 9.3. However, ROMS run well with intel fortran compiler instead of gfortran.
Yes, gfortran is a stricter compiler. Other compilers relax the Fortran standard rule that we cannot have a module, subroutine, or variable with the same name. I missed this one. Thank you for reporting this issue. Please, update your code.
thanks a lot for your fast answer!
Greetings! i was able to solve the problem~
