Fail to active T and S boundary conditons
cloudy4568
#1 Unread post by cloudy4568 »
I have a confused question. The boundary conditions for T and S are set (RadNud) in .in file:
!                   W       S       E       N
!                   e       o       a       o
!                   s       u       s       r
!                   t       t       t       t
!                           h               h
!                   1       2       3       4
   LBC(isFsur) ==   Clo     Clo     Che     Clo         ! free-surface
   LBC(isUbar) ==   Clo     Clo     Shc     Clo         ! 2D U-momentum
   LBC(isVbar) ==   Clo     Clo     Shc     Clo         ! 2D V-momentum
   LBC(isUvel) ==   Clo     Clo     RadNud  Clo      ! 3D U-momentum
   LBC(isVvel) ==   Clo     Clo     RadNud  Clo      ! 3D V-momentum
   LBC(isMtke) ==   Clo     Clo     Clo     Clo         ! mixing TKE
 LBC(isTvar) ==   Clo     Clo     RadNud  Clo    \    ! temperature
                    Clo     Clo     RadNud  Clo    \    ! salinity
                    Clo     Clo     Clo     Clo    \    ! inert(1)
                    Clo     Clo     Clo     Clo    \    ! inert(2)
                    Clo     Clo     Clo     Clo    \    ! inert(3)
                    Clo     Clo     Clo     Clo    \    ! inert(4)
                    Clo     Clo     Clo     Clo    \    ! inert(5)
                    Clo     Clo     Clo     Clo         ! inert(6)
! Ice boundary conditions
   LBC(isAice) ==   Clo     Clo     Clo     Clo         ! ice concentration
   LBC(isHice) ==   Clo     Clo     Clo     Clo         ! ice thickness
   LBC(isHsno) ==   Clo     Clo     Clo     Clo         ! snow thickness
   LBC(isTice) ==   Clo     Clo     Clo     Clo         ! ice temperature
   LBC(isApond)==   Clo     Clo     Clo     Clo         ! surface water
   LBC(isHpond)==   Clo     Clo     Clo     Clo         ! surface water
   LBC(isSig11)==   Clo     Clo     Clo     Clo         ! sigma-11
   LBC(isSig12)==   Clo     Clo     Clo     Clo         ! sigma-12
   LBC(isSig22)==   Clo     Clo     Clo     Clo         ! sigma-22
   LBC(isUice) ==   Gra     Gra     Gra     Gra         ! ice U-momentum
   LBC(isVice) ==   Gra     Gra     Gra     Gra         ! ice V-momentum
! conditions keywords.
ad_LBC(isFsur) ==   Per     Clo     Per     Clo         ! free-surface
ad_LBC(isUbar) ==   Per     Clo     Per     Clo         ! 2D U-momentum
ad_LBC(isVbar) ==   Per     Clo     Per     Clo         ! 2D U-momentum
ad_LBC(isUvel) ==   Per     Clo     Per     Clo         ! 3D U-momentum
ad_LBC(isVvel) ==   Per     Clo     Per     Clo         ! 3D V-momentum
ad_LBC(isMtke) ==   Per     Clo     Per     Clo         ! mixing TKE
ad_LBC(isTvar) ==   Per     Clo     Per     Clo \       ! temperature
                    Per     Clo     Per     Clo         ! salinity
   VolCons(west)  ==  F                            ! western  boundary
   VolCons(east)  ==  F                            ! eastern  boundary
   VolCons(south) ==  F                            ! southern boundary
   VolCons(north) ==  F                            ! northern boundary
ad_VolCons(west)  ==  F                            ! western  boundary
ad_VolCons(east)  ==  F                            ! eastern  boundary
ad_VolCons(south) ==  F                            ! southern boundary
ad_VolCons(north) ==  F                            ! northern boundary
Data of boundary conditions are well prepared.
But in the log.file, 'temp' and 'salt' boundary conditions are closed:
 zeta                     1   Closed       Closed       Chapman Exp  Closed
 ubar                     1   Closed       Closed       Shchepetkin  Closed
 vbar                     1   Closed       Closed       Shchepetkin  Closed
 u                        1   Closed       Closed       Rad + Nud    Closed
 v                        1   Closed       Closed       Rad + Nud    Closed
 temp                     1   Closed       Closed       Closed       Closed
 salt                     1   Closed       Closed       Closed       Closed
 tke                      1   Closed       Closed       Closed       Closed
 uice                     1   Gradient     Gradient     Gradient     Gradient
 vice                     1   Gradient     Gradient     Gradient     Gradient
 aice                     1   Closed       Closed       Closed       Closed
 hice                     1   Closed       Closed       Closed       Closed
 tisrf                    1   Closed       Closed       Closed       Closed
 snow_thick               1   Closed       Closed       Closed       Closed
 apond                    1   Closed       Closed       Closed       Closed
 hpond                    1   Closed       Closed       Closed       Closed
 sig11                    1   Closed       Closed       Closed       Closed
 sig12                    1   Closed       Closed       Closed       Closed
 sig22                    1   Closed       Closed       Closed       Closed
Do you have any idea about this? Thank you.
Re: Fail to active T and S boundary conditons
You only have two tracers, right?
You need to change this to:
                    Clo     Clo     RadNud  Clo
cloudy4568
#3 Unread post by cloudy4568 »
That's the reason! Thank you, Kate!
