Segmentation fault
zzyfathead
Segmentation fault
#1 Unread post by zzyfathead »
I tried to run a easy case and met a segmentation fault. So I turned on the USER_DEBUG, the results show belows:
I tried to figured out the problem but still have no idea yet.
Hope anyone have met this problem. Thanks lol
zzyfathead
Re: Segmentation fault
#2 Unread post by zzyfathead »
Friday - January 3, 2020 - 4:44:40 PM
test
Operating system : Linux
 CPU/hardware     : x86_64
 Compiler system  : gfortran
 Compiler command : /usr/bin/mpif90
 Compiler flags   : -frepack-arrays -g -fbounds-check -I/usr/include -ffree-form -ffree-form
 Input Script  :
 SVN Root URL  : https:://myroms.org/svn/src
 SVN Revision  : 65M
 Local Root    : /home/ubuntu/app/COAWST_V3.2
 Header Dir    : /home/ubuntu/app/COAWST_V3.2/Projects/test
 Header file   : test.h
 Analytical Dir: /home/ubuntu/app/COAWST_V3.2/Projects/test
 Resolution, Grid 01: 0176x0279x025,  Parallel Nodes:   1,  Tiling: 001x001
      24000  ntimes            Number of timesteps for 3-D equations.
      0.100  dt                Timestep size (s) for 3-D equations.
         10  ndtfast           Number of timesteps for 2-D equations between
        120  nRST              Number of timesteps between the writing of data
                                 into restart fields.
                                 to standard output.
         10  nHIS              Number of timesteps between the writing fields
                                 into history file.
          1  ntsAVG            Starting timestep for the accumulation of output
                                 time-averaged data.
        360  nAVG              Number of timesteps between the writing of
 2.0000E-01  nl_tnu2(01)       NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for tracer 01: temp
 2.0000E-01  nl_tnu2(02)       NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for tracer 02: salt
 1.0000E-01  nl_visc2          NLM Horizontal, harmonic mixing coefficient
                                 (m2/s) for momentum.
          F  LtracerSponge(01) Turning OFF sponge on tracer 01: temp
          F  LtracerSponge(02) Turning OFF sponge on tracer 02: salt
 1.0000E-06  Akt_bak(01)       Background vertical mixing coefficient (m2/s)
 1.0000E-06  Akt_bak(02)       Background vertical mixing coefficient (m2/s)
                                 for tracer 02: salt
 1.0000E-05  Akv_bak           Background vertical mixing coefficient (m2/s)
 5.0000E-06  Akk_bak           Background vertical mixing coefficient (m2/s)
                                 for turbulent energy.
 5.0000E-06  Akp_bak           Background vertical mixing coefficient (m2/s)
      3.000  gls_p             GLS stability exponent.
      1.500  gls_m             GLS turbulent kinetic energy exponent.
     -1.000  gls_n             GLS turbulent length scale exponent.
 7.6000E-06  gls_Kmin          GLS minimum value of turbulent kinetic energy.
 1.0000E-12  gls_Pmin          GLS minimum value of dissipation.
 5.4770E-01  gls_cmu0          GLS stability coefficient.
 1.4400E+00  gls_c1            GLS shear production coefficient.
 1.9200E+00  gls_c2            GLS dissipation coefficient.
-4.0000E-01  gls_c3m           GLS stable buoyancy production coefficient.
 1.0000E+00  gls_c3p           GLS unstable buoyancy production coefficient.
 1.0000E+00  gls_sigk          GLS constant Schmidt number for TKE.
 1.3000E+00  gls_sigp          GLS constant Schmidt number for PSI.
   1400.000  charnok_alpha     Charnok factor for Zos calculation.
      0.500  zos_hsig_alpha    Factor for Zos calculation using Hsig(Awave).
      0.250  sz_alpha          Factor for Wave dissipation surface tke flux .
    100.000  crgban_cw         Factor for Craig/Banner surface tke flux.
      0.000  wec_alpha         WEC factor for roller/breaking energy distribution.
 2.5000E-02  rdrg2             Quadratic bottom drag coefficient.
 2.0000E-02  Zob               Bottom roughness (m).
 2.0000E-02  Zos               Surface roughness (m).
 1.0000E-01  Dcrit             Minimum depth for wetting and drying (m).
          1  lmd_Jwt           Jerlov water type.
          2  Vtransform        S-coordinate transformation equation.
          4  Vstretching       S-coordinate stretching function.
 6.0000E+00  theta_s           S-coordinate surface control parameter.
 4.0000E-01  theta_b           S-coordinate bottom  control parameter.
     10.000  Tcline            S-coordinate surface/bottom layer width (m) used
      0.000  dstart            Time-stamp assigned to model initialization (days).
       0.00  time_ref          Reference time for units attribute (yyyymmdd.dd)
 0.0000E+00  Tnudg(01)         Nudging/relaxation time scale (days)
 0.0000E+00  Tnudg(02)         Nudging/relaxation time scale (days)
                                 for tracer 02: salt
 0.0000E+00  Tnudg_SSS         Nudging/relaxation time scale (days)
                                 for sea surface salinity.
 0.0000E+00  Znudg             Nudging/relaxation time scale (days)
 0.0000E+00  M2nudg            Nudging/relaxation time scale (days)
 0.0000E+00  M3nudg            Nudging/relaxation time scale (days)
                                 for 3D momentum.
 0.0000E+00  obcfac            Factor between passive and active
     10.000  T0                Background potential temperature (C) constant.
     30.000  S0                Background salinity (PSU) constant.
          F  LtracerSrc(01)    Turning OFF point Sources/Sinks on tracer 01: temp
          F  LtracerSrc(02)    Turning OFF point Sources/Sinks on tracer 02: salt
             Output Restart File:  test_rst.nc
             Output History File:  test_his.nc
            Output Averages File:  test_avg.nc
                 Input Grid File:  /home/ubuntu/app/COAWST_V3.2/Projects/test/test_grid.nc
    Input Nonlinear Initial File:  /home/ubuntu/app/COAWST_V3.2/Projects/test/test_init.nc
 Tile partition information for Grid 01:  0176x0279x0025  tiling: 001x001
 Number of tracers:            2
        0        1      176        1      279  1227600
   (interior points only)
        0     0.50   176.50     0.50   279.50  RHO-points
        0     1.00   176.00     0.50   279.50    U-points
        0     0.50   176.50     1.00   279.00    V-points
               HaloSizeI(1) =     374
               HaloSizeJ(1) =     578
                TileSide(1) =     283
                TileSize(1) =   51223
 zeta                     1   Closed       Closed       Closed       Closed
 ubar                     1   Closed       Closed       Closed       Closed
 vbar                     1   Closed       Closed       Closed       Closed
 u                        1   Closed       Closed       Closed       Closed
 v                        1   Closed       Closed       Closed       Closed
 temp                     1   Closed       Closed       Closed       Closed
 salt                     1   Closed       Closed       Closed       Closed
 tke                      1   Closed       Closed       Closed       Closed
 TEST                test
 CHARNOK             Charnok surface roughness from wind stress.
 GLS_MIXING          Generic Length-Scale turbulence closure.
 MIX_GEO_TS          Mixing of tracers along geopotential surfaces.
 RADIATION_2D        Use tangential phase speed in radiation conditions.
 SOLAR_SOURCE        Solar Radiation Source Term.
 UV_LOGDRAG          Logarithmic bottom stress.
 WET_DRY             Wetting and drying activated.
 Process Information:
 Node #  0 (pid=   15904) is active.
    25   0.0000000   0.0000000        0.000       0.000       0.000       0.000
    24  -0.0400000  -0.0001749       -0.004      -0.201      -0.461      -0.538
    23  -0.0800000  -0.0007098       -0.008      -0.404      -1.066      -1.368
    22  -0.1200000  -0.0016353       -0.012      -0.608      -1.829      -2.516
    21  -0.1600000  -0.0030046       -0.016      -0.815      -2.770      -4.025
    20  -0.2000000  -0.0048963       -0.020      -1.024      -3.921      -5.960
    19  -0.2400000  -0.0074189       -0.024      -1.237      -5.326      -8.407
    18  -0.2800000  -0.0107165       -0.028      -1.454      -7.042     -11.485
    17  -0.3200000  -0.0149770       -0.032      -1.675      -9.145     -15.347
    16  -0.3600000  -0.0204424       -0.036      -1.902     -11.733     -20.189
    15  -0.4000000  -0.0274214       -0.040      -2.137     -14.930     -26.262
    14  -0.4400000  -0.0363057       -0.044      -2.382     -18.892     -33.886
    13  -0.4800000  -0.0475899       -0.048      -2.638     -23.819     -43.462
    12  -0.5200000  -0.0618955       -0.052      -2.909     -29.961     -55.497
    11  -0.5600000  -0.0799996       -0.056      -3.200     -37.630     -70.622
    10  -0.6000000  -0.1028685       -0.060      -3.514     -47.214     -89.623
     9  -0.6400000  -0.1316956       -0.063      -3.858     -59.194    -113.473
     8  -0.6800000  -0.1679410       -0.067      -4.240     -74.157    -143.358
     7  -0.7200000  -0.2133714       -0.071      -4.667     -92.812    -180.716
     6  -0.7600000  -0.2700910       -0.076      -5.150    -116.006    -227.259
     5  -0.8000000  -0.3405555       -0.080      -5.703    -144.725    -284.985
     4  -0.8400000  -0.4275481       -0.084      -6.338    -180.090    -356.158
     3  -0.8800000  -0.5340940       -0.088      -7.070    -223.315    -443.241
     2  -0.9200000  -0.6632759       -0.092      -7.916    -275.642    -548.740
     1  -0.9600000  -0.8179050       -0.096      -8.890    -338.198    -674.944
     0  -1.0000000  -1.0000000       -0.100     -10.000    -411.797    -823.494
 Time Splitting Weights for Grid 01:    ndtfast =  10    nfast =  15
  1 0.0014850648765542 0.1000000000000000 0.0014850648765542 0.1000000000000000
  2 0.0059386031399402 0.0998514935123446 0.0074236680164944 0.1998514935123445
  3 0.0133457074936657 0.0992576331983506 0.0207693755101601 0.2991091267106951
  4 0.0236484051180389 0.0979230624489840 0.0444177806281990 0.3970321891596791
  5 0.0366959666818608 0.0955582219371801 0.0811137473100598 0.4925904110968592
  6 0.0521753389587947 0.0918886252689940 0.1332890862688545 0.5844790363658532
  7 0.0695217010484137 0.0866710913731145 0.2028107873172682 0.6711501277389678
  8 0.0878091442019233 0.0797189212682732 0.2906199315191915 0.7508690490072409
  9 0.1056214752525633 0.0709380068480808 0.3962414067717548 0.8218070558553218
 10 0.1209031436506851 0.0603758593228245 0.5171445504224399 0.8821829151781463
 11 0.1307902921035067 0.0482855449577560 0.6479348425259466 0.9304684601359023
 12 0.1314219308195445 0.0352065157474053 0.7793567733454911 0.9656749758833076
 13 0.1177312353577226 0.0220643226654509 0.8970880087032138 0.9877392985487585
 14 0.0832169680811588 0.0102911991296786 0.9803049767843727 0.9980304976784371
 15 0.0196950232156274 0.0019695023215627 1.0000000000000000 0.9999999999999999
 ndtfast, nfast =   10  15   nfast/ndtfast =  1.50000
    1.000000000000 1.083803072626 0.541901536313 1.000000000000 1.000000000000
 Power filter parameters, Fgamma, gamma =  0.28400   0.00000
 Minimum X-grid spacing, DXmin =  1.00256452E-01 km
 Maximum X-grid spacing, DXmax =  1.00262565E-01 km
 Minimum Y-grid spacing, DYmin =  9.95247380E-02 km
 Maximum Y-grid spacing, DYmax =  9.95366015E-02 km
 Minimum Z-grid spacing, DZmin =  3.96056923E-03 m
 Maximum Z-grid spacing, DZmax =  1.48550344E+02 m
 Minimum barotropic Courant Number =  3.66827761E-04
 Maximum barotropic Courant Number =  1.27240519E-02
 Maximum Coriolis   Courant Number =  2.26677842E-07
                   (Grid 01, File: test_init.nc, Rec=0001, Index=1)
                - free-surface
                - u-momentum component
                - v-momentum component
                - potential temperature
                   (Min =  2.00000000E+01 Max =  2.00000000E+01)
                - salinity
                   (Min =  3.50000000E+01 Max =  3.50000000E+01)
At line 101 of file get_data.f90
Fortran runtime error: Index '1' of dimension 2 of array 'frc' above upper bound of 0
Error termination. Backtrace:
[b]#0  0x7ff3e1bdf2da in ???
#1  0x7ff3e1bdfec5 in ???
#2  0x7ff3e1be0297 in ???
#3  0x555ef59c8e30 in get_data_
	at /home/ubuntu/app/COAWST_V3.2/Build/get_data.f90:101
#4  0x555ef59c5c3e in initial_
	at /home/ubuntu/app/COAWST_V3.2/Build/initial.f90:296
#5  0x555ef57bfbbd in __ocean_control_mod_MOD_roms_initialize
	at /home/ubuntu/app/COAWST_V3.2/Build/ocean_control.f90:131
#6  0x555ef57bec15 in ocean
	at /home/ubuntu/app/COAWST_V3.2/Build/master.f90:95
#7  0x555ef57bede1 in main
	at /home/ubuntu/app/COAWST_V3.2/Build/master.f90:50[/b]
Primary job  terminated normally, but 1 process returned
  Process name: [[1340,1],0]
  Exit code:    2
#3 Unread post by kate »
What is on this line?
Oops, didn't see this:
Did you tell it NFFILES before the list of forcing files?
zzyfathead
#4 Unread post by zzyfathead »
kate wrote: Fri Jan 03, 2020 5:32 pm What is on this line?
Hi Kate,
Thanks for your reply.
I don't want to input any forcing file, so I use '!' to comment out the code, as shown in the figure below. And the problem happend.
Then I delete '!' and change this code to 'NFFILES=0' , but ROMS told me NFFILES must be greater than 1.
I wonder that if it's necessay to input forcing files.
Thanks!
zzyfathead
#5 Unread post by zzyfathead »
zzyfathead wrote: Sat Jan 04, 2020 6:57 am
Hi Kate,
I don't want to input any forcing file, so I use '!' to comment out the code, as shown in the figure below. And the problem happened.
I wonder that if it's necessay to input forcing files (Because I don't want to do that).
Thanks!
#6 Unread post by kate »
Well, you could try submitting a bug report for this case of no forcing files, but most of us just set NFFILES to 1 and move on.
zzyfathead
#7 Unread post by zzyfathead »
kate wrote: Sat Jan 04, 2020 7:34 am Well, you could try submitting a bug report for this case of no forcing files, but most of us just set NFFILES to 1 and move on.
Kate
Thanks for your reply, you really help me out! So people usually input at least one forcing file, my case is not common.
By the way, where can I submit a bug report?
#8 Unread post by kate »
If you log into: https://www.myroms.org/projects/src you can submit a bug report.
#9 Unread post by arango »
This is not a bug. It always has to be equal or greater than one by design. If no input forcing files are needed, ROMS will ignore those values on standard input. I don't understand what it is the Fuzz about it. There are a lot of parameters in ROMS standard input that will be only relevant for a specific configuration. If not, they will be IGNORED!
NFFILES is needed to allocate an internal ROMS structure and initialize several parameters even if it is not used.
zzyfathead
#10 Unread post by zzyfathead »
arango wrote: Sat Jan 04, 2020 7:35 pm This is not a bug. It always has to be equal or greater than one by design. If no input forcing files are needed, ROMS will ignore those values on standard input. I don't understand what it is the Fuzz about it. There are a lot of parameters in ROMS standard input that will be only relevant for a specific configuration. If not, they will be IGNORED!
Thanks, I set NFFILES = 1 and input forcing file(though values = 0), it works now. :D
